I built ZM from the git repo yesterday and everything works fine with one exception: Events are being saved and show up in the individual monitor view but they are not listed in the main web UI. I am assuming this is just a bug that was in the repository when I cloned it yesterday AM but figured I would check to see if anyone has a fix. I haven't had the time to look into it in much detail but nothing stood out in the logs when I took a peek.
https://dl.dropboxusercontent.com/u/6511963/zm01.png
Events saved but not showing up in main web UI
- Contact:
Re: Events saved but not showing up in main web UI
I have the same problem, after upgrade to 1.27.
- Contact:
Just wanted to post here for those that don't follow the changes on github. Making this change to functions.php fixes this issue. You can find the commit here:
https://github.com/ZoneMinder/ZoneMinde ... c0bfee1d97
Thanks for posting this... you guys just saved me at least one or two hours!
