shared memory, socket, or general startup errors
teddy
Post by teddy »
I installed ZM to FC3 for the first time and thought FC3 was causing a problem that made it so ZM could not connect to a socket.
The socket is the file /tmp/zmdc.sock
With no connection to the socket, ZM could not startup.
Since ZM did not startup, shared memory failed to initialize.
So what was the problem???
the owner of the /tmp/zmdc.sock file was root.
I deleted the /tmp/zmdc.sock file.
Then I was able to startup ZM. ZM created a new /tmp/zmdc.sock file as user apache. Now, finally, everything works.
bschelst
Post by bschelst »
Teddy,
The sock file must always be readable/writeable by the webserver user.
It is strange that it was owned by root. You probably made a mistake during the configuration of the zoneminder. (apache user/apache group)
Bart
