All
What sort of server spec do I need to run 15 cameras? I have two currently running on an old laptop which runs between 1.3 and 1.7 on a dual core machine.
Some of the cameras will be in alert mode most of the time as they will be in a showroom with customers coming and going all the time so I suspect they will take more resources than those in the warehouses.
I am happy calculating the disk space required but what method should I be using to calculate the server power needed?
Matt Houldsworth
Digitalquill
Server Spec to run 15 cameras
Re: Server Spec to run 15 cameras
It really depends on what video format you'll be using. Zoneminder isn't terribly processor intensive. It's more about throughput and bandwidth.
Example:
Personally, I'm running 34 cameras that see a lot of action during the day. While I am running an 8-core AMD processor, it's running at about 30% max. I've got 4 - 2TB SATA 6 drives running in RAID 10 formation and that runs at about 30% as well. This is with 8 gigs of memory and running on Ubuntu Server 12.04 LTS.
Each camera is running at a resolution of 640 x 400 using H.264 at 10 FPS for about 1-Mbit per sec.
Remember that the Hard Disks are going to take the most abuse here, so try getting some industrial grade drives if you want them to last a good long time. Ensure your case has adequate cooling for that same reason.
For a similar setup using only 15 cameras, you could get away with a 4 core processor with ease. A two core might do it if it's high end enough.
Example:
Thanks captainarcain, that really helps
I am currently running two cameras into a dual core laptop and it is running at 2.84, the cameras can do full HD but I am like you running at 640 x 360 due really to space.
We want to keep 30 days worth of footage where some areas have virtual constant movement so it is a good call on higher grade disks.
Matt
Matt
Digitalquill wrote:I am currently running two cameras into a dual core laptop and it is running at 2.84, the cameras can do full HD but I am like you running at 640 x 360 due really to space.
Digitalquill wrote:laptop
Unless that laptop is equipped with an SSD, that laptop's disk is almost guaranteed to be the cause of your high load. I've never seen a 2.5" spinning disk that wasn't molasses-in-january slow. And when ZM is recording it's doing tons of file access! I'm willing to bet most your CPU is spending most of its time in IOWAIT!Digitalquill wrote:laptop
My current specs:
Core i7-3770 quad core 3.4GHz
16G memory
4x WD 2TB drives set up as RAID5
Scientific Linux 6.5
4x IP cameras putting out 1920x1080 video
3x Analog cameras being pulled off a remote system, 640x480
The IP cameras and the zoneminder system are all plugged into a POE switch, so the camera network traffic is mostly isolated from the rest of my network.
Here's a graph of the load average over the last week on the zoneminder system. Mostly under 2.0
I got a couple more cameras to get mounted and hooked in, but from what I see so far, it looks like I shouldn't run into any issues just by added two more IP cameras.
16G memory
- Load average over the last week.
- zm-loadavg.png (37.16 KiB) Viewed 3438 times
Thanks all, agreed the current setup is not ideal, it was an emergency to catch a thief! It worked but now looking to implement a more permanent solution so thanks for the help and input.
Matt
Matt
