I have a strange problem, I have zm 1.25 installed on ubuntu server and working fine over the lan. Cambozola fires and works without issue, when I try an alternate port, the webpages are served and everything is fine UNTIL I try and view the cameras, of which nothing shows but whats in the SS.
I have modified my ports.conf file to Listen 8080 as well as Listen 80
Everything is working EXCEPT viewing the cams while on port 8080
Im sure its something silly I am overlooking, can any help?
Alternate port?
Alternate port?
- Screenshot of camera display
- Untitled.png (15.1 KiB) Viewed 1431 times
Re: Alternate port?
I did search before I posted and didn't find anything related to my issue, (or so I thought) after posting I was searching and found this thread
http://www.zoneminder.com/forums/viewto ... rts#p82527
which is the solution to this problem.
thank you and sorry for making an additional thread
