Only 2 Columns in Montage
rrichards_gnaps
Post by rrichards_gnaps »
I just completed the install of 1.21 and I cannot display more than two colums in the montage view. I have tried changing the number in the setup but it does not change the view.
cordel
Post by cordel »
Have you tried refreashing the browser window or closing the browser after you have made the change?
rrichards_gnaps
That question almost hurts :) I did. I was thinking that same thing but I'm getting the same result from different clients.
cordel
Post by cordel »
Sorry, you hadn't said that you tried and I have to get the basics out of the way before trying more elaborate stuff :wink:
One more of those is If you check the setting does it show what you had set it to?
I know sometimes I forget to click save before moving to another tab and lose the choices that I had made in the previous tab.
Also a little more info about your install:
Web server and version?
PHP Version?
MySQL Version?
And of course Linux version and any thing else that could be relative to the issue you can think of (error logs).
Sorry, I know I could probably search your posts and deciminate this info but we're lazy. A good thing to do is put this info in your signature that way when you begin a post like this you can just check the attatch signature box :D
Regards,
Cordel
rrichards_gnaps
I was running 1.20.1 on this same server without a problem. I'm not big on upgrades so I performed a fresh install of 1.21 I did delete the old database as I no longer needed any of the information.
I'm running on
SUSE 9.2 (build 2.6.8-24.14)
Apache 2.0.5
MySql 4.0.21
Hope this helps!!!!
zoneminder
Site Admin
Post by zoneminder »
I think this is a bug. I'll try and figure out why it's working.
Phil
