some Grandstream IP camera not show
This is first time on ZM and I have problam I have 16 IP cameras but some camera NOT show on monitor just blank screen. How can I do? Please help me. Thank you.
Re: some Grandstream IP camera not show
here is a link to some info that may help:
http://www.zoneminder.com/wiki/index.php/Grandstream
I recommend you use the low resolution stream and set the camera resolution low to begin with. 16 IP cameras could tax a lower end PC running ZM. Also, use the ffmpeg setting if you can.
You did not say which Linux you are using. Get as much memory in the PC as you can. I'm running 15 cameras on a quad core with 8 GIG of RAM and it works well.
bb
bb
Thank you for your info. all camera working.
more question now all cameras can work on low resolution. Why cannot work on high resolution? How can I do? please share me.
I have 5 Grandstream IP cameras, all are set up for a lowdef and a hidef feed. On a Core I7, 3.4GHz, 16GB memory setup I have no issues so far. My load average is usually around 1.5. If you tell us what hardware you're working with we might be able to have some better advice.
