when I go away to http://localhost/zm requests username and password to me entrance the one that forms in /etc/zm.conf and click login, and it does not pass anything, it does not enter any screen
thanks....
I don't enter????????????
I think I have the same error here. I get to the login page and use admin:admin to login. Then the login page just reloads itself.
I have disabled selinux and checked to make sure:
and I restarted the system to be sure that it is disabled.
I have run yum update to be sure all dependencies have been met and packages are up to date (using dag instead of fedora.us)
I am running Fedora Core 3 with the following versions installed:
zm-1.21.0-10.FC3.SEL.CTU
httpd-2.0.52-3.1
mysql-server-3.23.58-16.FC3.1
I don't see any errors in my httpd/error_log or any zm/ logs, in fact nothing is added when I try to login.
The only thing that seems to get added to the logs is to httpd/access_log:
Is there a debug option I can turn on to see more errors, or is there a simple solution to this problem.
Any help is greatly appreciated
# selinuxconf
selinux state="disabled"
httpd-2.0.52-3.1
64.122.61.238 - - [26/May/2005:14:43:10 -0500] "POST /zm/index.php HTTP/1.1" 200 1064 "http://64.122.63.53/zm/index.php" "Mozilla/5.0 (Windows; U; Windows NT 5.0; en-US; rv:1.7.7) Gecko/20050414 Firefox/1.0.3"
I know I have seen that before but for the life of me I can't remember what. If you had SELinux enabled when you first built the database you may want to look in the users table to make sure admin got populated. If I remember the other thing I had incountered I'll post it.
Regards,
Cordel
PS There is also some debug you can turn on detailed in the README
Regards,
Cordel
