Hi all,
I have upgraded to ZM 1.27 but it ha made a mess of my database and keeps failing with various errors.
Would it be possible for anybody to export their database and share it with me so i can import it and start fresh? Hoping this will fix the issue and allow ZM to start. I will delete any user info if you havent already
Kind Regards
JPL
ZM 1.27 DB
- knight-of-ni
Re: ZM 1.27 DB
Why not just follow the documentation to create a new database???
Re: ZM 1.27 DB
i couldnt find the guide for creating the database for 1.27 and the one for the older versions didnt work. if there is a guide that will be great.
thank you for the reply
- knight-of-ni
Re: ZM 1.27 DB
Here you go:
http://www.zoneminder.com/wiki/index.ph ... rom_Source
Note that the path to the zm_create.sql may be different on your system depending on your distro and how you built/installed zoneminder.
