First time post, new to zm.
ZM running on Centos 6.5
When browser is pointed to zm, control panel opens, but it is "stopped". Using the control to "start" fails to start.
Any help that will point me to a resolution is welcome.
Unable to start zm control panel
- knight-of-ni
Re: Unable to start zm control panel
Did you follow the steps to create (new systems) or upgrade (existing systems) your database?dbrandt wrote:First time post, new to zm.
Fresh install
- knight-of-ni
Yes, but did you follow the steps to create the database?dbrandt wrote:Fresh install
I recommend you take a look the README and make sure you've got everything set up right:
https://github.com/ZoneMinder/ZoneMinde ... DME.CentOS
The target audience is for CentOS users installing zoneminder via rpm. If you have chosen to install from source, then you should disable selinux as the source install will not configure selinux like the rpm package does.
