new install of 1.26.5 not working
darkpaw
Post by darkpaw »
So after quite some time trying to get this working on Fedora 20, I bailed on it and tried Ubuntu. The most recent doc lists it for 12.10, but that's long outdated. I downloaded 14.04 LTS, and the docs for 12.10 seemed to work fine.
However, I can't view any of my cams. When I select any of them (or try with cycle or montage) I just get an empty window. No error message or red X showing a broken link. When I close the window I get an error message in the event logs saying:
"socket_sendto( /tmp/zm/zms-XXXXXXs.sock ) failed: No such file or directory"
What might be wrong?
Re: new install of 1.26.5 not working
Did you follow this procedure?
http://www.zoneminder.com/wiki/index.ph ... e_easy_way
Likely you need to enable the CGI in Apache
darkpaw
Post by darkpaw »
Bingo! That was it. Yes, I followed that procedure, but must have missed that step.
It's working great now, thanks.
coppit
Post by coppit »
I had a similar problem even though I enabled cgi-bin. How essential are the resolv.conf and ntp changes steps? I skipped the resolv.conf one because I'm setting up ZM in a docker container, where a reboot doesn't work. I skipped the ntp change for now since my clock seems fine.
Edit: I should mention that I'm using cameras on my LAN, I can stream from them using rtsp to VLC on another computer, and I can ping them from my ZM docker container.
Painterbrain
Post by Painterbrain »
Hi there.... sorry my english is not the best.. but i try to decsribe my problem.
I have installed 1.26.5 on ubuntu 14.04 LTS and i have big problem.
My logfile says:
2014-08-22 20:52:52.230637 zma_m2 25257 WAR Waiting for capture daemon zm_monitor.cpp 556
2014-08-22 20:52:52.223350 zmdc 25217 INF 'zmaudit.pl -c' exited, signal 14 zmdc.pl
2014-08-22 20:52:52.174935 zma_m6 25306 WAR Waiting for capture daemon zm_monitor.cpp 556
2014-08-22 20:52:52.165820 zmdc 25217 INF 'zmaudit.pl -c' stopping at 14/08/22 20:52:52 zmdc.pl
2014-08-22 20:52:52.088480 zmdc 25217 INF 'zma -m 8' exited normally zmdc.pl
2014-08-22 20:52:52.032155 zma_m8 25328 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2014-08-22 20:52:51.920850 zmdc 25217 INF 'zma -m 8' stopping at 14/08/22 20:52:51 zmdc.pl
2014-08-22 20:52:51.908159 zma_m5 25290 WAR Waiting for capture daemon zm_monitor.cpp 556
2014-08-22 20:52:51.867740 zmdc 25217 INF 'zmfilter.pl ' exited, signal 14 zmdc.pl
2014-08-22 20:52:51.783140 zmdc 25217 INF 'zmfilter.pl ' stopping at 14/08/22 20:52:51 zmdc.pl
2014-08-22 20:52:51.607958 zma_m4 25278 WAR Waiting for capture daemon zm_monitor.cpp 556
2014-08-22 20:52:51.552391 zma_m1 25244 WAR Waiting for capture daemon zm_monitor.cpp 556
2014-08-22 20:52:51.531150 zmpkg 25408 INF Command: stop zmpkg.pl
2014-08-22 20:52:51.496614 zma_m7 25316 WAR Waiting for capture daemon zm_monitor.cpp 556
2014-08-22 20:52:51.421450 zmdc 25217 ERR 'zmc -d /dev/video1' exited abnormally, exit status 255 zmdc.pl
2014-08-22 20:52:51.364284 zmc_dvideo1 25405 FAT Failed to stat video device /dev/video1: No such file or directory zm_local_camera.cpp 669
2014-08-22 20:52:51.312798 zmc_dvideo1 25405 INF Starting Capture zmc.cpp 195
2014-08-22 20:52:51.258943 zmc_dvideo1 25405 INF No direct match for the selected palette and target colorspace. Format conversion is required, performance penalty expected zm_local_camera.cpp 408
2014-08-22 20:52:51.174298 zma_m2 25257 WAR Waiting for capture daemon zm_monitor.cpp 556
2014-08-22 20:52:51.121280 zmdc 25405 INF 'zmc -d /dev/video1' started at 14/08/22 20:52:
I use Kodicom 8800 and in /etc/modprobe.d/bttv.conf
options i2c-algo-bit bit_test=1
options bttv gbuffers=16 card=102,102,102,102,102,102,102,102 radio=0,0,0,0,0,0,0,0 tuner=4,4,4,4,4,4,4,4 chroma_agc=1 combfilter=2 full_luma_range=1 coring=1 autoload=0
No pic at all :cry:
If i delete /etc/modprobe.d/bttv.conf
Can i get some pic. but the pic is crash... I live in Denmark and use PAL... but if i change to NTSC i get at pic. in black and white.. but not very good....
What i wrong ?? :?:
Best regards Kurt
