Shared data not initialised by capture daemon
ThomasNovin
Post by ThomasNovin »
I think this is a new problem for me, and it does not look like the old classic problem with too low settings on shared memory, found in FAQ etc?
2014-08-20 15:25:30.971068 zmu 19837 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results zm_monitor.cpp 424
Aug 20 15:50:43 stik zms[22402]: INF [Authenticated user 'admin']
Aug 20 15:50:43 stik zms[22402]: WAR [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
Aug 20 15:50:47 stik zms[22402]: INF [Got signal 15 (Terminated), exiting]
Aug 20 15:50:50 stik zms[22006]: INF [Got signal 15 (Terminated), exiting]
Aug 20 15:50:50 stik zms[22006]: ERR [Unable to send stream frame: Broken pipe]
# ipcs -l
------ Shared Memory Limits --------
max number of segments = 4096
max seg size (kbytes) = 524288
max total shared memory (kbytes) = 8388608
min seg size (bytes) = 1
------ Semaphore Limits --------
max number of arrays = 128
max semaphores per array = 250
max semaphores system wide = 32000
max ops per semop call = 32
semaphore max value = 32767
------ Messages Limits --------
max queues system wide = 1652
max size of message (bytes) = 8192
default max size of queue (bytes) = 16384
# apt-cache policy zoneminder
zoneminder:
Installed: 1.27.99+1-trusty-SNAPSHOT2014080402
Candidate: 1.27.99+1-trusty-SNAPSHOT2014080402
Version table:
*** 1.27.99+1-trusty-SNAPSHOT2014080402 0
500 http://ppa.launchpad.net/iconnor/zonemi ... er/ubuntu/ trusty/main i386 Packages
100 /var/lib/dpkg/status
1.26.5-1ubuntu3 0
500 http://se.archive.ubuntu.com/ubuntu/ trusty/universe i386 Packages
ThomasNovin
Re: Shared data not initialised by capture daemon
Interesting observation, this only happens when I'm logged into the web gui. During the night there has been no shared data errors but there has been successfully recorded events.
Some log after logging in
2014-08-21 11:16:16.335816	zms	17415	ERR	Unable to send raw frame 35: Broken pipe	zm_event.cpp	1316
2014-08-21 11:16:16.327198	zms	17415	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2014-08-21 11:16:11.846473	zms	17415	WAR	Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results	zm_monitor.cpp	424
2014-08-21 11:16:11.834254	zms	17415	INF	Authenticated user 'admin'	zm_user.cpp	241
2014-08-21 11:16:10.106079	zms	17413	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2014-08-21 11:16:04.252870	zms	17413	WAR	Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results	zm_monitor.cpp	424
2014-08-21 11:16:04.216023	zms	17413	INF	Authenticated user 'admin'	zm_user.cpp	241
2014-08-21 11:15:56.171978	zms	17348	WAR	Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results	zm_monitor.cpp	424
2014-08-21 11:15:56.108302	zms	17348	INF	Authenticated user 'admin'	zm_user.cpp	241
c128
Post by c128 »
Seeing exactly the same the same thing.
I recently upgrade to Ubuntu 14.04 and so moved to iconnor's (very useful, thanks ;-) ) zoneminder-master PPA. This flags the Zoneminder version as v1.27.99.0, but I guess that's just a placeholder
Same cameras setup in the same way using ffmpeg (libvlc returns a stack of errors) as I had with my 1.27 install on Ubuntu 12.04.
Everything OK except when viewing in the web view, where I get the same warnings and errors as posted earlier:
2014-10-13 20:57:01.933470	zms	9303	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2014-10-13 20:57:01.775427	zms	9305	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2014-10-13 20:57:01.754786	zms	9307	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2014-10-13 20:56:46.772679	zms	9307	WAR	Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results	zm_monitor.cpp	424
2014-10-13 20:56:46.766035	zms	9305	WAR	Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results
ThomasNovin
I opened an issue on GitHub but it hasn't lead to anything
https://github.com/ZoneMinder/ZoneMinder/issues/507
c128
Post by c128 »
Just looked at the comments on the Github issue, especially:
This is actually a warning. It is just telling you that the camera is not recording. It means that the zmc process is not running. You need to look into why zmc is not running. So check in the zmc logs. /var/log/zm/zmc*
I also had no output in my zmc_* logs, even with debug output on to the component files. However...the zmc processes for my 3 cameras *were* actually running, and didn't stop/restart over getting the warning:
www-data 11079  9.4 11.3 677284 218768 ?       Sl   22:17   1:01 /usr/bin/zmc -m 1
www-data 11085  8.4  9.1 631280 175644 ?       Sl   22:17   0:54 /usr/bin/zmc -m 2
www-data 11091  3.4 11.4 677408 218964 ?       Sl   22:17   0:22 /usr/bin/zmc -m 3
Switching on the LOG_DEBUG stuff further down the logging page - lots of verbose output in the /tmp/zm stored files, and I also start getting stuff in the /var/log/zm/zmc*.log files. However - it looks normal? Here's the output form a single quick session viewing in the UI:
10/13/14 22:17:49.053822 zmc_m2[11085].INF-zmc.cpp/195 [Starting Capture]
10/13/14 22:17:49.087825 zmc_m2[11085].INF-zm_ffmpeg_camera.cpp/114 [Priming capture from rtsp://username:password@192.168.1.132:554/Streaming/Channels/1]
10/13/14 22:20:36.299390 zmc_m2[11085].INF-zm_monitor.cpp/2899 [Steps: 1000 - Capturing at 5.99 fps]
10/13/14 22:23:22.976310 zmc_m2[11085].INF-zm_monitor.cpp/2899 [Steps: 2000 - Capturing at 6.02 fps]
10/13/14 22:26:09.722060 zmc_m2[11085].INF-zm_monitor.cpp/2899 [Steps: 3000 - Capturing at 5.99 fps]
10/13/14 22:28:56.443431 zmc_m2[11085].INF-zm_monitor.cpp/2899 [Steps: 4000 - Capturing at 5.99 fps]
10/13/14 22:31:43.137095 zmc_m2[11085].INF-zm_monitor.cpp/2899 [Steps: 5000 - Capturing at 5.99 fps]
10/13/14 22:33:58.629539 zmc_m2[11085].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
However, within the zms log over this time, I have again:
10/13/14 22:28:32.069221 zms[11318].INF-zm_user.cpp/241 [Authenticated user 'admin']
10/13/14 22:28:32.100790 zms[11318].WAR-zm_monitor.cpp/424 [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
10/13/14 22:32:07.467107 zms[11318].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
c128
Post by c128 »
I ought to add that, in my case (and not the OP's) the "WAR-zm_monitor.cpp/424 [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]" warning *seems* to be benign.
I can view live streams and recordings seem to be fine, but although my shared memory settings seem valid, I get the warning.
daedalus
Post by daedalus »
any luck in finding a solution for this warning?
I have a slightly different issue - when i log in the gui and click on a monitor for live streaming the recording stops. When i close the live window the recording resumes.
