Filter on monitor name does not appear to work
carcachute
Post by carcachute »
I have monitors named Garage0 and Garage1. Both have hundreds of events.
I want to create a filter that e-mails me any time there is activity on those monitors. I created a filter:
Monitor Name equal to Garage0
Sort by Date/Time Asc
When I click Submit, I get 0 events. I also get 0 events for any monitor name I put into the filter.
What am I missing here? Is filtering only on monitor name broken? I can find events for any criteria EXCEPT the monitor name.
sogood007
Re: Filter on monitor name does not appear to work
Post by sogood007 »
carcachute wrote:I have monitors named Garage0 and Garage1. Both have hundreds of events.
Monitor Id equal to Garage0
Do you really mean Monitor Id or Monitor Name? The former is a number and the later probably is the name. Disclaimer: I haven't used either in my filter
carcachute
sogood007 wrote:
carcachute wrote: Do you really mean Monitor Id or Monitor Name? The former is a number and the later probably is the name. Disclaimer: I haven't used either in my filter
Sorry, I meant Monitor Name. I tried both!
Working fine for me. I was surprised to notice that the filter does not appear to be case sensistive either. I can search on "shed" or "Shed" and still get the same results.
What version of zoneminder are you using and on what distro?
Are there any errors in your log when you run the filter?
carcachute
knnniggett wrote:Working fine for me. I was surprised to notice that the filter does not appear to be case sensistive either. I can search on "shed" or "Shed" and still get the same results.
I'm using Zoneminder 1.27.99 on Ubuntu 14.04.1 LTS x86_64, installed with the stock package. I don't see any errors in the log when I submit the query. The filter is
Monitor Name matches Garage1
and all the checkboxes are left unchecked.
Using the numeric ID of the monitor does work.
