I'm got a problem with RTSP (RTP/RTSP/HTTP) connection to an Axis M3014 (firmware 5.40.9.3 just updated)
I read that with new 5.x firmwares the path to use is: /axis-media/media.amp
I tried it, but the connection is not stable, it crashes and live view doesn't work
With older cams,I have for example an AXIS 209FD with firmware version 4.47.1
the connection with the path /mpeg4/media.amp works pefectly.
although RTSP doesn't work for me, I can connect to M3014 using mjpeg
/mjpg/1/video.mjpg?resolution=800x600&fps=10
but I saw in nethogs that this connection uses 450kb/s for a 800x600 image.
AXIS 209FD streaming with h264, 800x600 use about 120kb brandwidth.
is anyone else facing this problem with new axis cameras?
thanks Paolo
http://www.axis.com/files/manuals/um_m3 ... n_1112.pdf
2014-10-09 12:27:16.245220 zmdc 16522 INF 'zmc -m 7' crashed, signal 8 zmdc.pl
2014-10-09 12:27:14.493001 zma_m5 19095 INF Monitor-5: 64000 - Processing at 13.33 fps /builddir/build/BUILD/ZoneMinder-1.27.0/src/zm_monitor.cpp 1153
2014-10-09 12:27:13.584957 zmc_m5 19084 INF Monitor-5: 64000 - Capturing at 13.33 fps /builddir/build/BUILD/ZoneMinder-1.27.0/src/zm_monitor.cpp 2831
2014-10-09 12:27:10.242363 zmc_m7 20152 INF Got signal 15 (Terminated), exiting /builddir/build/BUILD/ZoneMinder-1.27.0/src/zm_signal.cpp 40
2014-10-09 12:27:10.203210 zmdc 16522 INF 'zmc -m 7' stopping at 14/10/09 12:27:10 zmdc.pl
2014-10-09 12:27:10.104450 zmwatch 16586 INF Restarting capture daemon for Monitor-7, time since last capture 7 seconds (1412850430-1412850423) zmwatch.pl
2014-10-09 12:27:00.134942 zmc_m7 20152 INF Starting Capture /builddir/build/BUILD/ZoneMinder-1.27.0/src/zmc.cpp 195
2014-10-09 12:27:00.027860 zmdc 20152 INF 'zmc -m 7' started at 14/10/09 12:27:00 zmdc.pl
2014-10-09 12:27:00.027860 zmdc 16522 INF 'zmc -m 7' starting at 14/10/09 12:27:00, pid = 20152 zmdc.pl
2014-10-09 12:26:59.930750 zmwatch 16586 INF Restarting capture daemon for Monitor-7, time since last capture 22 seconds (1412850419-1412850397) zmwatch.pl
