Hey guys,
couldnt find any Solution for my Problem so far, really hope you can change this.
My Friends is operating a TrendNet IP31-PI for me. With iOS and Win (IP Cam Viewer)its easy to find under
https://xxxx.xxx.xx:333
User: admin
Pswd: tester123
But under zoneminder it doesn't work with
Source Type: Remote
Funktion: Monitor
Remote Protocol: HTTP
method: simple or regexp
admin.tester123@xxxx.xxx.xx
Port: 333
Or
Remote Protocol: RTSP
Any method
Where is my fault on this ???
Greetz Dombo
Access to https://... IP Cam
Re: Access to https://... IP Cam
http is not the same as https, I have no idea if zm even supports https sources.
