Multiple High Resolution Camera
geraldbrandt
Post by geraldbrandt »
I have 3 cameras on my 1.28.0 system, two at 1280x960 and one at 1280x800. I had to take one of them down to grayscale in order to get the camera working. As soon as all three are RGB24, the capture fails to run.
I'm hoping to get 4 more cameras on board. Setting shared memory didn't seem to help at all.
Any ideas what I can do?
Gerald
Re: Multiple High Resolution Camera
What OS are you running? What are the server specs (RAM, speed, # of cores)?
geraldbrandt
Core 2 Quad @ 2.66 GHz with 1GB RAM. I thought it had more...
Ubuntu 14.04 64bit
I'm only using about 1/2 the RAM though, the rest is cache.
You need a lot more memory than just 1GB to do what you are trying to do. Zoneminder uses your ramdisk for shared memory.
For example, on my home system with 8 cameras, the ramdisk is currently at 647MB, and all but one of my cameras are vga/D1 resultion.
AnotherBrian
Post by AnotherBrian »
My system (ubuntu 14.04 with 7 1280x720 cameras) as reported by system monitor utilizes only 1.7 gigabytes of my ram and no swap space.
ipcs -m returns the shared memory segments which total up to 74 megabytes.
Are you sure there is a ram disk? I don't see one on my system.
c128
Post by c128 »
Zoneminder does generate output to
/dev/shm
- so that's in RAM.
On my system (4 active cameras, one inactive):
root@cctv:/dev/shm# ls -alh
total 660M
drwxrwxrwt  2 root     root      140 Nov 30 18:46 .
drwxr-xr-x 21 root     root      780 Dec 13 11:25 ..
-rw-------  1 www-data www-data 176M Nov 30 18:46 zm.mmap.1
-rw-------  1 www-data www-data 132M Nov 30 18:46 zm.mmap.2
-rw-------  1 www-data www-data 176M Nov 30 18:46 zm.mmap.3
-rw-------  1 www-data www-data 132M Nov 30 18:46 zm.mmap.4
-rw-------  1 www-data www-data  44M Nov 30 18:46 zm.mmap.5
root@cctv:/dev/shm# df -h .
Filesystem      Size  Used Avail Use% Mounted on
none            938M  660M  279M  71% /run/shm
root@cctv:/dev/shm#
AnotherBrian wrote:My system (ubuntu 14.04 with 7 1280x720 cameras) as reported by system monitor utilizes only 1.7 gigabytes of my ram and no swap space.
Most every modern Linux distro has a ramdisk mapped to /dev/shm. It dynamically grows as items are placed in it. ZoneMinder uses that area to place its mmap'ed files.
geraldbrandt
knnniggett wrote:You need a lot more memory than just 1GB to do what you are trying to do. Zoneminder uses your ramdisk for shared memory.
Thanks! Upped RAM to 2GB, and all is well. Dunno why I didn't think of that myself.
Gerald
