Err: Attempt to fetch integer value for ZM_OPT_ADAPTIVE_SKIP
benf
Post by benf »
Just noticed my 1.28 installation on Centos 6.6 is throwing errors, and although running is not capturing from any of my attached cameras - JPEG, RTMP :
Looking in the logs, the error flagged as it starts the capture process is :
Attempt to fetch integer value for ZM_OPT_ADAPTIVE_SKIP, actual type is boolean. Try running 'zmupdate.pl -f' to reload config.
OK, so I ran the script, which freshened the database - but didn't clear the error.
Checking via phpmyadmin I did a check and optimise on the database table but that didn't flag any consistency issues - also didn't help either.
Any suggestions for a fix?
I suspect that after a recent Perl RPM update that was pushed in the last four weeks which was installed there may be some stricter type checking which is responsible ...?
Ben.
benf
Re: Err: Attempt to fetch integer value for ZM_OPT_ADAPTIVE_
Post by benf »
Just reporting back - I tried various things but basically nuking Zoneminder 1.28.03 and then re-installing and setting up the monitors once again did the trick.
