I have just installed ZoneMinder 1.28.0 following
http://www.zoneminder.com/wiki/index.ph ... se_systemd
and
http://www.zoneminder.com/wiki/index.ph ... e_easy_way
But there is no API in the web root. Have I missed something?
TIA
Missing API
Re: Missing API
If you followed the instructions Zoneminder is accessed with http://ipaddress/zm
If you have problems start over and do not do systemd. That will come in time...
bb
bb
Re: Missing API
Thanks. But ZoneMinder is accessible and working fine at /zm. It's /zm/api that's not there. But I think it should be included since 1.27?
See zoneminder on readthedocs (can't post a link).
- knight-of-ni
Re: Missing API
hmmmm.... the APi is a work in progress and Kyle may not have added it to the installation scripts.
I recommend you ask the question here:
https://github.com/ZoneMinder/ZoneMinder/issues/8
Re: Missing API
Thanks, I've asked over there.
In case anyone else is wondering, I installed it manually as follows: http://iain.rauch.co.uk/blog/2014-12/zo ... -1-28-api/
