MYSQL won't start
Barry
MYSQL won't start
Post by Barry »
Hello. I think my zoneminder version is 1.28, but I'm not positive.... How do I check?
Going to my zoneminder page show this :
Could not connect to database: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (111)
Attempting to start mysql(d):
root@mfs-cameraserver:/var/log# mysql
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (111)
root@mfs-cameraserver:/var/log# mysqld
150106 11:43:22 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead.
I tried the database repair on the FAQ, but it didn't help. http://www.zoneminder.com/wiki/index.ph ... atabase.3F
Any help is appreciated.
Cheers.
chippy99
Re: MYSQL won't start
Post by chippy99 »
What distribution are you running ?
Also what is returned if you type
ps ax | grep mysql
Barry
Post by Barry »
Thanks for the reply. I got it sorted out. I'd post the link, but the forum won't let me. Google "How to Recover InnoDB Corruption for MySQL". The gist of it is I used the innodb_force_recovery tag in my.cnf. That allowed me to at least start the database and log into it. So then I did this
mysqldump –all-databases > all_the_bases.sql
Then
mkdir /var/lib/old_innodb_data/
mv /var/lib/mysql/ib* /var/lib/old_innodb_data
Removed the innodb_force_recovery tag, started the database back up and ran the .sql script. Back in business.
Cheers.
chippy99
Post by chippy99 »
Ok, good to hear you are now up and running.
