I followed a suggestion in (I can't paste the link because its to spammy but its viewtopic 86415#p86415 and setup /lib/systemd/system/zoneminder.service.
skank:/# service zoneminder start
Job for zoneminder.service failed. See 'systemctl status zoneminder.service' and 'journalctl -xn' for details.
skank:/# systemctl status zoneminder.service
â zoneminder.service - ZoneMinder CCTV recording and security system
Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled)
Active: failed (Result: exit-code) since Sun 2015-01-18 00:52:29 AWST; 29s ago
Process: 6946 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=255)
skank:/# journalctl -xn
No journal files were found.
skank:/etc/init.d# tail -f /var/log/messages
Jan 18 00:52:18 skank zmpkg[6946]: INF [Command: start]
Jan 18 00:52:19 skank zmdc[6954]: INF [Server starting at 15/01/18 00:52:19]
# uname -a
Linux skank 3.2.35-20150112 #3 SMP Sun Jan 11 18:31:13 AWST 2015 i686 GNU/Linux
I also tried manually running the startup script:
skank:/# /usr/bin/perl -wT /usr/bin/zmpkg.pl start
skank:/#
