No Video
Ronny
No Video
Post by Ronny »
Hi Everyone,
I've downloaded the ZoneMinder Virtual Appliance (1.25.0) and installed it without any issues.
I upgrade ZoneMinder to 1.28, however the error was happening before and after the upgrade.
The issue I'm having is that setting up the Amovision AM-Q630M using rtsp://10.1.1.50:554/11 does not seem to give me a video. Using the same link in VLC does work, so the details are correct.
I've setup Zoneminder the following way:
Source Type: Remote
Function: Monitor
Enabled: Ticked
Remote Protocol: RTSP
Remote Method: RTP/RTSP (have tried them all)
Remote Host Name: 10.1.1.50
Remote Host Port: 554
Remote Host Path: /11
Using a Anran Camera also has the same issue, using VLC to see stream works. In ZoneMinder it doesn't.
For the Anran Camera I used the following:
http://www.zoneminder.com/wiki/index.php/Anran
I have also attached a log for Camera 2 which is the Amovision camera
01/20/15 18:34:32.876980 zms[1739].DB1-zm_logger.cpp/230 [LogOpts: level=DB5/DB5, screen=OFF, database=INF, logfile=DB5->/tmp/zm/zm_debug.log.01739, syslog=ERR]
01/20/15 18:34:32.877163 zms[1739].DB1-zm_utils.cpp/254 [Detected a x86\x86-64 processor with SSE3]
01/20/15 18:34:32.877942 zms[1739].DB1-zms.cpp/102 [Query: mode=jpeg&monitor=2&scale=100&maxfps=15&buffer=1000&auth=3147a099863177aa363d4e241a28047c&connkey=958207&rand=1421807672]
01/20/15 18:34:32.878232 zms[1739].DB1-zm_user.cpp/172 [Attempting to authenticate user from auth string '3147a099863177aa363d4e241a28047c']
01/20/15 18:34:32.878903 zms[1739].DB1-zm_user.cpp/235 [Checking auth_key '...Change me to something unique...admin*2BBA9109D5A0A30F9C5ED43AF27BAB0193A30AF110.1.1.15018200115' -> auth_md5 '783f69b946252446adfc656774cfa4f9']
01/20/15 18:34:32.878934 zms[1739].DB1-zm_user.cpp/235 [Checking auth_key '...Change me to something unique...admin*2BBA9109D5A0A30F9C5ED43AF27BAB0193A30AF110.1.1.15017200115' -> auth_md5 '1a0d797fe260ddf9db15e02f7f6e98cf']
01/20/15 18:34:32.878957 zms[1739].DB1-zm_user.cpp/235 [Checking auth_key '...Change me to something unique...Admin*2BBA9109D5A0A30F9C5ED43AF27BAB0193A30AF110.1.1.15018200115' -> auth_md5 '3147a099863177aa363d4e241a28047c']
01/20/15 18:34:32.878975 zms[1739].INF-zm_user.cpp/241 [Authenticated user 'Admin']
01/20/15 18:34:32.888160 zms[1739].DB1-zm_monitor.cpp/2478 [Got 1 monitors]
01/20/15 18:34:32.888207 zms[1739].DB1-zm_monitor.cpp/2513 [Got 0 for v4l_captures_per_frame]
01/20/15 18:34:32.888258 zms[1739].DB2-zm_camera.cpp/39 [New camera id: 2 width: 720 height: 480 colours: 3 subpixelorder: 6 capture: 0]
01/20/15 18:34:32.888338 zms[1739].DB2-zm_image.cpp/151 [Blend: Using SSE2 fast blend function]
01/20/15 18:34:32.888395 zms[1739].DB2-zm_image.cpp/204 [Delta: Using SSE2 delta functions]
01/20/15 18:34:32.888419 zms[1739].DB2-zm_image.cpp/238 [Deinterlace: Using standard delta functions]
01/20/15 18:34:32.888430 zms[1739].DB2-zm_image.cpp/244 [Image buffer copy: Using SSE2 aligned memcpy]
01/20/15 18:34:32.888436 zms[1739].DB3-zm_image.cpp/251 [Setting up static colour tables]
01/20/15 18:34:32.888531 zms[1739].DB1-zm_monitor.cpp/367 [monitor purpose=0]
01/20/15 18:34:32.888544 zms[1739].DB1-zm_monitor.cpp/375 [mem.size=41473280]
01/20/15 18:34:32.888551 zms[1739].WAR-zm_monitor.cpp/424 [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
01/20/15 18:34:32.890570 zms[1739].DB1-zm_monitor.cpp/430 [Monitor Backyard has no zones, adding one.]
01/20/15 18:34:32.890668 zms[1739].DB1-zm_zone.cpp/51 [Initialised zone 0/All - 1 - 720x480 - Rgb:0000ff, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0, AF: 0]
01/20/15 18:34:32.908606 zms[1739].DB1-zm_monitor.cpp/440 [Monitor Backyard has function 2]
01/20/15 18:34:32.908623 zms[1739].DB1-zm_monitor.cpp/441 [Monitor Backyard LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
01/20/15 18:34:32.908630 zms[1739].DB1-zm_monitor.cpp/442 [Monitor Backyard IBC = 40, WUC = 25, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 0, ARBP = 0, FM = 0]
01/20/15 18:34:32.908653 zms[1739].DB1-zm_monitor.cpp/2766 [Loaded monitor 2(Backyard), 0 zones]
01/20/15 18:34:32.908722 zms[1739].DB1-zm_monitor.cpp/520 [Unable to map file /dev/shm/zm.mmap.2 (41473280 bytes) to locked memory, trying unlocked]
01/20/15 18:34:32.908735 zms[1739].DB1-zm_monitor.cpp/522 [Mapped file /dev/shm/zm.mmap.2 (41473280 bytes) to locked memory, unlocked]
01/20/15 18:34:32.908902 zms[1739].DB3-zm_stream.cpp/66 [FPS:0.00, MXFPS:15.00, BFPS:0.00, EFPS:0.00, FM:1]
01/20/15 18:34:32.908946 zms[1739].DB3-zm_stream.cpp/73 [aEFPS:0.00, aFM:1]
01/20/15 18:34:32.909233 zms[1739].DB2-zm_monitor.cpp/3940 [Checking swap image location]
01/20/15 18:34:32.909246 zms[1739].DB3-zm_monitor.cpp/3941 [Checking swap image path]
01/20/15 18:34:32.909300 zms[1739].DB3-zm_monitor.cpp/3437 [Swap path '/tmp/zm/zmswap-m2' missing, creating]
01/20/15 18:34:32.909541 zms[1739].DB3-zm_monitor.cpp/3437 [Swap path '/tmp/zm/zmswap-m2/zmswap-q958207' missing, creating]
01/20/15 18:34:32.909596 zms[1739].DB2-zm_monitor.cpp/3962 [Assigning temporary buffer]
01/20/15 18:34:32.916284 zms[1739].DB2-zm_monitor.cpp/3965 [Assigned temporary buffer]
01/20/15 18:34:33.416566 zms[1739].ERR-zm_monitor.cpp/4147 [Terminating, last frame sent time 1421807672.916349 secs more than maximum of 10.000000]
01/20/15 18:34:33.423972 zms[1739].DB1-zm_monitor.cpp/4156 [Cleaning swap files from /tmp/zm/zmswap-m2/zmswap-q958207]
01/20/15 18:34:33.424118 zms[1739].DB1-zm_monitor.cpp/4184 [Can't glob '/tmp/zm/zmswap-m2/zmswap-q958207/*.*': 3]
My linux skills are limited, is there something else that needs to be installed to via the Monitor feed in ZoneMinder that wasn't part of the ESX package.
Thank you
Re: No Video
Might help if we know what Linux version you are using...
Re: No Video
Change your source type to ffmpeg or libvlc (use whatever works best).
Ronny
Re: No Video
Post by Ronny »
tried all that :-)
At the end I build my own Ubuntu 14.04 and it's now working.
PacoLM
Re: No Video
Post by PacoLM »
I have the same camera, these are my settings:
rtsp://user:pwd@your.cam.ip.address:554/12?tcp
Capture Width (pixels): 640
Capture Height (pixels):360
Using ffmpeg in ZM1.25 as well. No problems at all.
Regards,
PacoLM
