zm with card keep getting issue with no video device found?
aot2002
Post by aot2002 »
im using this ebay card here
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... &rd=1#tech
its a 4 port 60 frames per second
i thought it was similar to bbtv type ebay cards the ones with 30fps but i cannot seem to get fedora core 3 to detect this card ?
i've tried a modprobe but still no luck ?
is there some way to get this type of card working ?
please help ?
here is my zmdc.log
Can't locate MIME/Entity.pm in @INC (@INC contains: /usr/lib/perl5/5.8.5/i386-linux-thread-multi /usr/lib/perl5/5.8.5 /usr/lib/perl5/site_perl/5.8.5/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.4/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.3/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.2/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.1/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.0/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.5 /usr/lib/perl5/site_perl/5.8.4 /usr/lib/perl5/site_perl/5.8.3 /usr/lib/perl5/site_perl/5.8.2 /usr/lib/perl5/site_perl/5.8.1 /usr/lib/perl5/site_perl/5.8.0 /usr/lib/perl5/site_perl /usr/lib/perl5/vendor_perl/5.8.5/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.4/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.3/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.2/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.1/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.0/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.5 /usr/lib/perl5/vendor_perl/5.8.4 /usr/lib/perl5/vendor_perl/5.8.3 /usr/lib/perl5/vendor_perl/5.8.2 /usr/lib/perl5/vendor_perl/5.8.1 /usr/lib/perl5/vendor_perl/5.8.0 /usr/lib/perl5/vendor_perl) at /usr/local/bin/zmfilter.pl line 102.
BEGIN failed--compilation aborted at /usr/local/bin/zmfilter.pl line 102.
'zmfilter.pl ' crashed at 05/06/08 19:44:34, exit status 2
here is my zmwatch.log
Can't get shared memory id '2053971969': No such file or directory
What seems to give here ?
here is my /var/log/messages
Jun 8 19:41:50 localhost zmfix[3007]: ERR [Can't stat /dev/video0: No such file or directory]
Jun 8 19:41:53 localhost zmc_d0[3034]: INF [Debug Level = 0, Debug Log = <none>]
Jun 8 19:41:53 localhost zmc_d0[3034]: ERR [Failed to open video device /dev/video0: No such file or directory]
Jun 8 19:41:53 localhost zmc_d0[3036]: INF [Debug Level = 0, Debug Log = <none>]
Jun 8 19:41:53 localhost zmc_d0[3036]: ERR [Failed to open video device /dev/video0: No such file or directory]
jay
cordel
Post by cordel »
Hi Jay,
From your error log looks like you need to install the MIME::Entity Perl module.
Also you might want to run a scanpci -v and post the infomation it gives relivant to the card.
The other errors would be related to the card not being detected or installed as a differant device and not video. Try looking through dmesg and see whats there as well.
Regards,
Cordel
maciekc
Post by maciekc »
Tell us what lspci writes.
I think that it wouldn't be supported - one chip and bt878 doesn't have 60fps
aot2002
Post by aot2002 »
i put the card in another machine which has windows xp on it and installed the software it came with JUST to verify the card works ok.
Well it does work and i put two cameras on the card and set them to 30fps and i was getting in the high 20fps each ? so it seems to get what it claims i dont know how but its doing that.
anyhow here is the stuff you asked for.
DMESG ********************
dmesg
Linux version 2.6.9-1.667 (bhcompile@tweety.build.redhat.com) (gcc version 3.4.2 20041017 (Red Hat 3.4.2-6.fc3)) #1 Tue Nov 2 14:41:25 EST 2004
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000ec000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000000fff0000 (usable)
BIOS-e820: 000000000fff0000 - 000000000fff8000 (ACPI data)
BIOS-e820: 000000000fff8000 - 0000000010000000 (ACPI NVS)
BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
255MB LOWMEM available.
zapping low mappings.
On node 0 totalpages: 65520
DMA zone: 4096 pages, LIFO batch:1
Normal zone: 61424 pages, LIFO batch:14
HighMem zone: 0 pages, LIFO batch:1
DMI 2.3 present.
ACPI: RSDP (v000 AMI ) @ 0x000fa970
ACPI: RSDT (v001 AMIINT VIA_K7 0x00000010 MSFT 0x00000097) @ 0x0fff0000
ACPI: FADT (v001 AMIINT VIA_K7 0x00000011 MSFT 0x00000097) @ 0x0fff0030
ACPI: MADT (v001 AMIINT 0x00000009 MSFT 0x00000097) @ 0x0fff00b0
ACPI: DSDT (v001 VIA VT8371 0x00001000 MSFT 0x0100000b) @ 0x00000000
ACPI: PM-Timer IO Port: 0x808
Built 1 zonelists
Kernel command line: ro root=/dev/VolGroup00/LogVol00 rhgb quiet
mapped 4G/4G trampoline to ffff4000.
Initializing CPU#0
CPU 0 irqstacks, hard=023d5000 soft=023d4000
PID hash table entries: 1024 (order: 10, 16384 bytes)
Detected 1100.189 MHz processor.
Using tsc for high-res timesource
Console: colour VGA+ 80x25
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 254792k/262080k available (2068k kernel code, 6652k reserved, 647k data, 144k init, 0k highmem)
Calibrating delay loop... 2162.68 BogoMIPS (lpj=1081344)
Security Scaffold v1.0.0 initialized
SELinux: Initializing.
SELinux: Starting in permissive mode
There is already a security framework initialized, register_security failed.
selinux_register_security: Registering secondary module capability
Capability LSM initialized as secondary
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
CPU: After generic identify, caps: 0383fbff c1c3fbff 00000000 00000000
CPU: After vendor identify, caps: 0383fbff c1c3fbff 00000000 00000000
CPU: CLK_CTL MSR was 6003d22f. Reprogramming to 2003d22f
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 256K (64 bytes/line)
CPU: After all inits, caps: 0383f3ff c1c3fbff 00000000 00000020
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU: AMD Athlon(tm) XP stepping 01
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Checking 'hlt' instruction... OK.
ACPI: IRQ9 SCI: Level Trigger.
checking if image is initramfs... it is
Freeing initrd memory: 944k freed
NET: Registered protocol family 16
PCI: PCI BIOS revision 2.10 entry at 0xfdb31, last bus=1
PCI: Using configuration type 1
mtrr: v2.0 (20020519)
ACPI: Subsystem revision 20040816
ACPI: Interpreter enabled
ACPI: Using PIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (00:00)
PCI: Probing PCI hardware (bus 00)
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: Power Resource [URP1] (off)
ACPI: Power Resource [URP2] (off)
ACPI: Power Resource [FDDP] (off)
ACPI: Power Resource [LPTP] (off)
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11 12 14 15) *9
Linux Plug and Play Support v0.97 (c) Adam Belay
usbcore: registered new driver usbfs
usbcore: registered new driver hub
PCI: Using ACPI for IRQ routing
ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
ACPI: PCI interrupt 0000:00:07.2[D] -> GSI 11 (level, low) -> IRQ 11
ACPI: PCI interrupt 0000:00:07.3[D] -> GSI 11 (level, low) -> IRQ 11
ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 10
ACPI: PCI interrupt 0000:00:07.5[C] -> GSI 10 (level, low) -> IRQ 10
ACPI: PCI interrupt 0000:00:0a.0[A] -> GSI 10 (level, low) -> IRQ 10
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11
ACPI: PCI interrupt 0000:00:0c.0[A] -> GSI 11 (level, low) -> IRQ 11
ACPI: PCI interrupt 0000:01:00.0[A] -> GSI 11 (level, low) -> IRQ 11
apm: BIOS version 1.2 Flags 0x03 (Driver version 1.16ac)
apm: overridden by ACPI.
audit: initializing netlink socket (disabled)
audit(1118310104.4294966710:0): initialized
Total HugeTLB memory allocated, 0
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
SELinux: Registering netfilter hooks
Initializing Cryptographic API
ksign: Installing public key data
Loading keyring
- Added public key 6ECDA687281A73E5
- User ID: Red Hat, Inc. (Kernel Module GPG key)
Applying VIA southbridge workaround.
PCI: Via IRQ fixup for 0000:00:07.3, from 9 to 11
PCI: Via IRQ fixup for 0000:00:07.2, from 9 to 11
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
vesafb: probe of vesafb0 failed with error -6
ACPI: Processor [CPU1] (supports C1, 16 throttling states)
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Real Time Clock Driver v1.12
Linux agpgart interface v0.100 (c) Dave Jones
agpgart: Detected VIA Twister-K/KT133x/KM133 chipset
agpgart: Maximum main memory to use for agp memory: 203M
agpgart: AGP aperture is 64M @ 0xe0000000
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
Serial: 8250/16550 driver $Revision: 1.90 $ 8 ports, IRQ sharing enabled
RAMDISK driver initialized: 16 RAM disks of 16384K size 1024 blocksize
divert: not allocating divert_blk for non-ethernet device lo
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller at PCI slot 0000:00:07.1
VP_IDE: chipset revision 6
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt82c686b (rev 40) IDE UDMA100 controller on pci0000:00:07.1
ide0: BM-DMA at 0xffa0-0xffa7, BIOS settings: hda:pio, hdb:DMA
ide1: BM-DMA at 0xffa8-0xffaf, BIOS settings: hdc:DMA, hdd:pio
Probing IDE interface ide0...
hdb: Maxtor 6Y060L0, ATA DISK drive
Using cfq io scheduler
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdc: JLMS DVD-ROM LTD-166S, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
Probing IDE interface ide2...
ide2: Wait for ready failed before probe !
Probing IDE interface ide3...
ide3: Wait for ready failed before probe !
Probing IDE interface ide4...
ide4: Wait for ready failed before probe !
Probing IDE interface ide5...
ide5: Wait for ready failed before probe !
hdb: max request size: 128KiB
hdb: 120103200 sectors (61492 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(100)
hdb: cache flushes supported
hdb: hdb1 hdb2
hdc: ATAPI 48X DVD-ROM drive, 512kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
ide-floppy driver 0.99.newide
usbcore: registered new driver hiddev
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.0:USB HID core driver
mice: PS/2 mouse device common for all mice
input: AT Translated Set 2 keyboard on isa0060/serio0
input: ImExPS/2 Generic Explorer Mouse on isa0060/serio1
md: md driver 0.90.0 MAX_MD_DEVS=256, MD_SB_DISKS=27
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 16Kbytes
TCP: Hash tables configured (established 16384 bind 4681)
Initializing IPsec netlink socket
NET: Registered protocol family 17
ACPI: (supports S0 S1 S4 S5)
ACPI wakeup devices:
PCI0 USB USB1 MC9
Freeing unused kernel memory: 144k freed
device-mapper: 4.1.0-ioctl (2003-12-10) initialised: dm@uk.sistina.com
cdrom: open failed.
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
SELinux: Disabled at runtime.
SELinux: Unregistering netfilter hooks
inserting floppy driver for 2.6.9-1.667
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
8139too Fast Ethernet driver 0.9.27
divert: allocating divert_blk for eth0
eth0: RealTek RTL8139 at 0xc800, 00:c0:26:7d:5d:08, IRQ 10
eth0: Identified 8139 chip type 'RTL-8100B/8139D'
PCI: Setting latency timer of device 0000:00:07.5 to 64
parport_pc: Via 686A parallel port disabled in BIOS
USB Universal Host Controller Interface driver v2.2
uhci_hcd 0000:00:07.2: UHCI Host Controller
uhci_hcd 0000:00:07.2: irq 11, io base 0000cc00
uhci_hcd 0000:00:07.2: new USB bus registered, assigned bus number 1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
uhci_hcd 0000:00:07.3: UHCI Host Controller
uhci_hcd 0000:00:07.3: irq 11, io base 0000d000
uhci_hcd 0000:00:07.3: new USB bus registered, assigned bus number 2
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
ACPI: Power Button (FF) [PWRF]
ACPI: Sleep Button (CM) [SLPB]
EXT3 FS on dm-0, internal journal
cdrom: open failed.
EXT3 FS on hdb1, internal journal
Adding 655352k swap on /dev/VolGroup00/LogVol01. Priority:-1 extents:1
ip_tables: (C) 2000-2002 Netfilter core team
eth0: link up, 100Mbps, half-duplex, lpa 0x40A1
i2c /dev entries driver
lp: driver loaded but no devices found
NET: Registered protocol family 10
Disabled Privacy Extensions on device 02369a00(lo)
IPv6 over IPv4 tunneling driver
divert: not allocating divert_blk for non-ethernet device sit0
eth0: no IPv6 routers present
SCANPCI -V ******** HERE *****************
scanpci -v
pci bus 0x0000 cardnum 0x00 function 0x00: vendor 0x1106 device 0x0305
VIA Technologies, Inc. VT8363/8365 [KT133/KM133]
CardVendor 0x1458 card 0x0000 (Giga-byte Technology, Card unknown)
STATUS 0xa210 COMMAND 0x0006
CLASS 0x06 0x00 0x00 REVISION 0x03
BIST 0x00 HEADER 0x00 LATENCY 0x08 CACHE 0x00
BASE0 0xe0000008 addr 0xe0000000 MEM PREFETCHABLE
pci bus 0x0000 cardnum 0x01 function 0x00: vendor 0x1106 device 0x8305
VIA Technologies, Inc. VT8363/8365 [KT133/KM133 AGP]
STATUS 0x2230 COMMAND 0x0007
CLASS 0x06 0x04 0x00 REVISION 0x00
HEADER 0x01 LATENCY 0x00
PRIBUS 0x00 SECBUS 0x01 SUBBUS 0x01
SECLT 0x00 SECSTATUS 0x0000
IOBASE 0x8000 IOLIM 0x9fff
NOPREFETCH_MEMBASE 0xdde00000 MEMLIM 0xddefffff
PREFETCH_MEMBASE 0xd5c00000 MEMLIM 0xddcfffff
NO_FAST_B2B NO_SEC_BUS_RST NO_M_ABRT VGA_EN NO_ISA_EN NO_SERR_EN NO_PERR_EN
pci bus 0x0000 cardnum 0x07 function 0x00: vendor 0x1106 device 0x0686
VIA Technologies, Inc. VT82C686 [Apollo Super South]
STATUS 0x0210 COMMAND 0x0087
CLASS 0x06 0x01 0x00 REVISION 0x40
BIST 0x00 HEADER 0x80 LATENCY 0x00 CACHE 0x00
BYTE_0 0x08 BYTE_1 0x41 BYTE_2 0x00 BYTE_3 0x00
pci bus 0x0000 cardnum 0x07 function 0x01: vendor 0x1106 device 0x0571
VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT8233/A/C/VT8235 PIPC Bus Master IDE
STATUS 0x0290 COMMAND 0x0007
CLASS 0x01 0x01 0x8a REVISION 0x06
BIST 0x00 HEADER 0x00 LATENCY 0x20 CACHE 0x00
BASE4 0x0000ffa1 addr 0x0000ffa0 I/O
MAX_LAT 0x00 MIN_GNT 0x00 INT_PIN 0x00 INT_LINE 0xff
BYTE_0 0x0b BYTE_1 0x42 BYTE_2 0x09 BYTE_3 0x05
pci bus 0x0000 cardnum 0x07 function 0x02: vendor 0x1106 device 0x3038
VIA Technologies, Inc. USB
CardVendor 0x0925 card 0x1234 (VIA Technologies, Inc. (Wrong ID) USB Controller)
STATUS 0x0210 COMMAND 0x0117
CLASS 0x0c 0x03 0x00 REVISION 0x1a
BIST 0x00 HEADER 0x00 LATENCY 0x40 CACHE 0x08
BASE4 0x0000cc01 addr 0x0000cc00 I/O
MAX_LAT 0x00 MIN_GNT 0x00 INT_PIN 0x04 INT_LINE 0x0b
BYTE_0 0x00 BYTE_1 0x12 BYTE_2 0x03 BYTE_3 0x00
pci bus 0x0000 cardnum 0x07 function 0x03: vendor 0x1106 device 0x3038
BASE4 0x0000d001 addr 0x0000d000 I/O
pci bus 0x0000 cardnum 0x07 function 0x04: vendor 0x1106 device 0x3057
VIA Technologies, Inc. VT82C686 [Apollo Super ACPI]
STATUS 0x0290 COMMAND 0x0000
CLASS 0x0c 0x05 0x00 REVISION 0x40
BIST 0x00 HEADER 0x00 LATENCY 0x00 CACHE 0x00
BYTE_0 0x20 BYTE_1 0x80 BYTE_2 0x49 BYTE_3 0x00
pci bus 0x0000 cardnum 0x07 function 0x05: vendor 0x1106 device 0x3058
VIA Technologies, Inc. VT82C686 AC97 Audio Controller
CardVendor 0x1458 card 0xa002 (Giga-byte Technology, Card unknown)
STATUS 0x0210 COMMAND 0x0001
CLASS 0x04 0x01 0x00 REVISION 0x50
BASE0 0x0000dc01 addr 0x0000dc00 I/O
BASE1 0x0000d801 addr 0x0000d800 I/O
BASE2 0x0000d401 addr 0x0000d400 I/O
MAX_LAT 0x00 MIN_GNT 0x00 INT_PIN 0x03 INT_LINE 0x0a
BYTE_0 0x01 BYTE_1 0xcc BYTE_2 0x40 BYTE_3 0x10
pci bus 0x0000 cardnum 0x0a function 0x00: vendor 0x10ec device 0x8139
Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+
CLASS 0x02 0x00 0x00 REVISION 0x10
BIST 0x00 HEADER 0x00 LATENCY 0x40 CACHE 0x00
BASE0 0x0000c801 addr 0x0000c800 I/O
BASE1 0xdfffff00 addr 0xdfffff00 MEM
MAX_LAT 0x40 MIN_GNT 0x20 INT_PIN 0x01 INT_LINE 0x0a
pci bus 0x0000 cardnum 0x0c function 0x00: vendor 0x1797 device 0x6800
Device unknown
STATUS 0x0280 COMMAND 0x0017
CLASS 0x04 0x00 0x00 REVISION 0x11
BASE0 0xde000000 addr 0xde000000 MEM
MAX_LAT 0x48 MIN_GNT 0x20 INT_PIN 0x01 INT_LINE 0x0b
BYTE_0 0xff BYTE_1 0x80 BYTE_2 0x00 BYTE_3 0x00
pci bus 0x0001 cardnum 0x00 function 0x00: vendor 0x1002 device 0x5446
ATI Technologies Inc Rage 128 Pro Ultra TF
CardVendor 0x174b card 0x7106 (PC Partner Limited, Card unknown)
STATUS 0x02b0 COMMAND 0x0087
CLASS 0x03 0x00 0x00 REVISION 0x00
BASE0 0xd8000008 addr 0xd8000000 MEM PREFETCHABLE
BASE1 0x00009801 addr 0x00009800 I/O
BASE2 0xddefc000 addr 0xddefc000 MEM
BASEROM 0xddec0000 addr 0xddec0000 not-decode-enabled
MAX_LAT 0x00 MIN_GNT 0x08 INT_PIN 0x01 INT_LINE 0x0b
jay
aot2002
Post by aot2002 »
i've now installed the perl modules too today...
here is my zmdc.log
Server starting at 05/06/09 09:57:25
'zmfilter.pl' started at 05/06/09 09:57:28
'zmfilter.pl' starting at 05/06/09 09:57:28, pid = 3131
'zmaudit.pl -d 900 -y' started at 05/06/09 09:57:29
'zmaudit.pl -d 900 -y' starting at 05/06/09 09:57:29, pid = 3135
'zmwatch.pl' starting at 05/06/09 09:57:29, pid = 3140
'zmwatch.pl' started at 05/06/09 09:57:29
No perl errors
Watchdog starting at 05/06/09 09:57:30
Watchdog pausing for 30 seconds
Can't get shared memory id '2053971973': No such file or directory
HERE IS MY /var/log/messages
Jun 9 09:57:18 localhost zmfix[3050]: ERR [Can't stat /dev/video0: No such file or directory]
Jun 9 09:57:22 localhost zmc_d0[3077]: INF [Debug Level = 0, Debug Log = <none>]
Jun 9 09:57:22 localhost zmc_d0[3077]: ERR [Failed to open video device /dev/video0: No such file or directory]
Jun 9 09:57:22 localhost zmc_d0[3080]: INF [Debug Level = 0, Debug Log = <none>]
Jun 9 09:57:22 localhost zmc_d0[3080]: ERR [Failed to open video device /dev/video0: No such file or directory]
Jun 9 09:57:25 localhost zmc_d0[3104]: INF [Debug Level = 0, Debug Log = <none>]
Jun 9 09:57:25 localhost zmc_d0[3104]: ERR [Failed to open video device /dev/video0: No such file or directory]
Jun 9 09:57:25 localhost zmc_d0[3107]: INF [Debug Level = 0, Debug Log = <none>]
Jun 9 09:57:25 localhost zmc_d0[3107]: ERR [Failed to open video device /dev/video0: No such file or directory]
jay
cordel
Post by cordel »
The Kernel don't have what it takes to support that card apperantly. I would try to find out what you can about that card including what chip they are using. That would be a start. Its posible that there are drivers to support the chip in the kernel but without the correct manufacturer info in the kernal to tell what it is, unknown device means it will not work.
Regards,
Cordel
aot2002
Post by aot2002 »
Cordel
I know the web address on the card but is there some other type of manufactures for modules i can try at least to see if it will work?
jay
cordel
Post by cordel »
Without knowing the chip thats on the card I wouldn't know where to start. The hard thing is that there is a heat sink on the chip that would have to be carefully removed to get the info off the chip. Depending on how it's fixed to the chip this could be a diffecult task and then you would have to place the heat sink back before using the card. Unless you know what you are doing I do not suggest trying that.
aot2002
Post by aot2002 »
no heat sink is installed ?
i must of sent the wrong ebay link
let me set the right one here
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 51171&rd=1
jay
aot2002
Post by aot2002 »
Here is the sticker on the chip
Ewatch EW-204M
ver2.0 www.ewatch.com.au
I removed it and this was on the chip
TECHWELL
TW6800
ACPD RB194011
0509
just in that order
heres a website link
http://techwellinc.com/brochures/TW6800_Brochure.pdf
jay
cordel
Post by cordel »
Thanks for that Jay. I will look into it some more this weekend and let you know what I find.
Regards,
Cordel
aot2002
Post by aot2002 »
i've looked all over the net and havent found anything relavent for this card?
Good luck Cordel
jay
giba
Post by giba »
Did you go any further on this?
I have the same board and want to use it with zone minder too.
Saludos, Juan.
cordel
Post by cordel »
No it hasn't gone much farther. I would need to get a card to work with and would have to have the time to work it out. The best way to go about it would be to donate a card to the guy that maintains the video drivers for the kernel. You can find his info in the kernel readme for the bttv drivers.
Regards,
Corey
