Explanation of event log suggestions
bucsfan069
Post by bucsfan069 »
I have an event in my event log that includes some suggestions. Can you point me to a procedure that explains how to perform these suggestions?
Buffer overrun at index 13, image 140013, slow down capture, speed up analysis or increase ring buffer size
If there was a specific manual to follow to perform these suggestions
1. speed up analysis
2. increase ring buffer size
3. slow down capture -- I think I understand this one but a definitive procedure on exactly where this is done would be helpful.
Zoneminder running on Dell Poweredge 2950
32 GB Ram
2TB Hard Drive
32 Cameras running on 2 16 port BlueCherry PCI Express Cards
Ubuntu 12.04
PacoLM
Re: Explanation of event log suggestions
Post by PacoLM »
3- slow down capture
You could set the Maximum FPS rate in each monitor configuration. If you could set this in the camera configuration side, it will be better, then leave the Maximum FPS blank.
Hope it helps,
PacoLM
bucsfan069
That is the normal procedure I use...I set the FPS lower for the caperas...I am hoping to get some clarification on the first two steps...especially number 1...
32 GB Ram
2TB Hard Drive
Ubuntu 12.04
PacoLM
Post by PacoLM »
To speed up analysis, you could disable:
CREATE_ANALYSIS_IMAGES
COLOUR_JPEG_FILES
ADD_JPEG_COMMENTS
RECORD_EVENT_STATS
RECORD_DIAG_IMAGES
Hope it helps,
PacoLM
