Hi all,
I've just bought a new network camera Maginon IPC 20C, but I've troubles connecting it to Zoneminder.
When I connect with VLC it works fine with: user:pwd@1.1.1.1/videostream.cgi (I cannot put in the full URL with leading http, because of "Your post looks too spamy for a new user, please remove off-site URLs.")
The media info from VLC is: MJPG, 640x480, decoded format: Planar 4:2:2 YUV full scale
I configured the source like this:
Source Type: Remote
Function: Modect
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Name: user:pwd@1.1.1.1
Remote Host path: /videostream.cgi
Remote Image Colours: 24 bit
Capture Width: 640
Capture Height: 480
Image Buffer Size (frames): 50
Warmup Frames: 25
Pre Event Image Count: 20
Post Event Image Count: 50
Stream Replay Image Buffer: 1000
Alarm Frame Count: 2
I already tried to add ?a=.mjpg at the end of the remote host path
this log messages appears:
2015-04-03 20:04:16.110690 zmdc 2205 INF 'zmc -m 2' crashed, signal 6 zmdc.pl
2015-04-03 20:04:16.108630 zmdc 2205 ERR 'zma -m 2' exited abnormally, exit status 255 zmdc.pl
2015-04-03 20:04:16.106961 zma_m2 4375 ERR Shared data not initialised by capture daemon zm_monitor.cpp 434
2015-04-03 20:04:16.106714 zma_m2 4375 ERR Got unexpected memory map file size 15361672, expected 92161672 zm_monitor.cpp 364
2015-04-03 20:04:16.099901 zmc_m2 4376 ERR Got unexpected memory map file size 15361672, expected 92161672 zm_monitor.cpp 364
2015-04-03 20:04:16.066720 zmdc 4375 INF 'zma -m 2' started at 15/04/03 20:04:16 zmdc.pl
2015-04-03 20:04:16.064260 zmdc 4376 INF 'zmc -m 2' started at 15/04/03 20:04:16 zmdc.pl
2015-04-03 20:04:16.063220 zmdc 2205 INF 'zmc -m 2' starting at 15/04/03 20:04:16, pid = 4376 zmdc.pl
2015-04-03 20:04:16.062260 zmdc 2205 INF Starting pending process, zmc -m 2 zmdc.pl
2015-04-03 20:04:16.061890 zmdc 2205 INF 'zma -m 2' starting at 15/04/03 20:04:16, pid = 4375 zmdc.pl
2015-04-03 20:04:16.060480 zmdc 2205 INF Starting pending process, zma -m 2
If I change source buffer settings to:
Image Buffer Size (frames): 10
Warmup Frames: 5
Pre Event Image Count: 5
Alarm Frame Count: 1
I get the following log messages:
2015-04-03 20:06:30.775331 zmc_m2 4486 WAR Unable to capture image, retrying zm_remote_camera_http.cpp 1092
2015-04-03 20:06:30.775224 zmc_m2 4486 ERR Connection dropped by remote end zm_remote_camera_http.cpp 920
2015-04-03 20:06:30.774043 zma_m2 4494 WAR Approaching buffer overrun, consider slowing capture, simplifying analysis or increasing ring buffer size zm_monitor.cpp 1083
I already set the shared memory to:
kernel.shmall = 33554432
kernel.shmmax = 536870912
# ipcs -lm
------ Shared Memory Limits --------
max number of segments = 4096
max seg size (kbytes) = 524288
max total shared memory (kbytes) = 134217728
min seg size (bytes) = 1
What I also found out, that the Content-Type in HTTP Header ist "multipart/x-mixed-replace;boundary=ipcamera", don't know if this could be a problem.
I hope anybody can give me a hint, how I can bring this camera up&running.
Thanks in advance,
Philipp
Maginon IPC 20C
Jump to
- General
- ↳ Announcements
- ↳ Website Issues
- Support
- ↳ ZoneMinder 1.36.x
- ↳ ZoneMinder 1.34.x
- ↳ Mobile Apps and Event Server
- ↳ Docker
- ↳ ZoneMinder Distributions
- ↳ ZoneMinder Translations
- ↳ Archive [End of Life Versions]
- ↳ ZoneMinder 1.35.x Development Branch
- ↳ ZoneMinder 1.33.x Development Branch
- ↳ ZoneMinder 1.32.x
- ↳ ZoneMinder 1.31.x
- ↳ ZoneMinder 1.30.x
- ↳ ZoneMinder 1.29.x
- ↳ ZoneMinder 1.28.x
- ↳ ZoneMinder 1.27.x
- ↳ ZoneMinder 1.26.x
- ↳ ZoneMinder 1.25.x
- ↳ ZoneMinder 1.24.x
- ↳ ZoneMinder Previous Versions
- Development
- ↳ ZoneMinder 1.37.x Development Branch
- ↳ Feature Requests
- ↳ User Contributions
- Miscellaneous
- ↳ ZoneMinder Hints & Tips
- ↳ Non-ZoneMinder Chat
- ↳ Jobs / For Sale / Wanted / Exchange
- ↳ Hardware Compatibility List
- ↳ Hardware Queries
