I'd like to have ZM running and recording /dev/video0 on my RH9 but still be able to run GnomeMeeting using the same video device which ZM is recording. I'd need somehow to duplicate /dev/video0, because the other app (GnomeMeeting) says that /dev/video0 is in use.
I think I've seen somewhere such solution but I can't find it anymore.
Best regards,
Darko
ZM and other app using the same video device
Re: ZM and other app using the same video device
Hi Darko,
You might checkout this "http://motion.sourceforge.net/vloopback/index.html"
It works with "motion", it may work with ZoneMinder. Also check the motion mailing list archive for some recent info on this.
"http://www.frogtown.com/pipermail/motion/"
Hope this helps
Ross
Hope this helps
Ross
Thank you Ross,
I'vre tried to make it work but I can't compile vloopback 0.91 or older on my RH9 2.4.20-8 linux. I don't know linux so good that I could solve the problem alone: Here's the result of the make:
Darko
[root@omnibox vloopback-0.91]# make
cc -D__KERNEL__ -DMODULE -DCONFIG_PROC_FS -DCONFIG_VIDEO_PROC_FS -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -fno-strict-aliasing -pipe -fno-strength-reduce -march=i686 -falign-loops=2 -falign-jumps=2 -falign-functions=2 -I/usr/src/linux/drivers/usb -I/usr/src/linux/include -c -o vloopback.o vloopback.c
vloopback.c: In function `uvirt_to_kva':
vloopback.c:172: warning: implicit declaration of function `pte_offset'
vloopback.c:172: warning: assignment makes pointer from integer without a cast
vloopback.c: In function `vloopback_mmap':
vloopback.c:503: warning: passing arg 1 of `remap_page_range' makes pointer from integer without a cast
vloopback.c:503: incompatible type for argument 4 of `remap_page_range'
vloopback.c:503: too few arguments to function `remap_page_range'
vloopback.c: At top level:
vloopback.c:878: warning: initialization from incompatible pointer type
make: *** [vloopback.o] Error 1
Darko
vloopback
Is there some workaround about that?? I need to do something like that. 2 programs accesing the same device....
- zoneminder
- Site Admin
- Contact:
