ZoneMinder for RPi 2
_peterlast
Re: ZoneMinder for RPi 2
Post by _peterlast »
Ok so you installed Fedora on the Pi 2?
Absolutely.
Raspbian might be the most popular distro for the raspberry pi, but it is not the only one.
The Fedora team natively builds for the arm7 architecture.
I believe this is the active thread that describes it here:
https://www.raspberrypi.org/forums/view ... 1&t=101027
_peterlast
Ok cool, gonna look into that as Raspbian is a bit bloated with it's GUI but most important of all...I need a running ZM on the Pi :D Gonna save me a lot of energy when I can turn my Synology into hibernate when I don't use it (90% of the time that it's on actually...).
Add one of the following to /etc/apt/sources.list for raspbian packages.
deb http://zmrepo.zoneminder.com/debian wheezy
or
deb http://zmrepo.zoneminder.com/debian jessie
fr33s7yl0r
Post by fr33s7yl0r »
adding this line to lists did not work:
deb zmrepo zoneminder / debian wheezy main contrib non-free rpi
apt-get update shows errors:
Err zmrepo zoneminder wheezy/main armhf Packages
404 Not Found
