Isaac Connor Repo
I have some permission problems,
this will also be one again
how can I fix this?
Initiating database upgrade to version 1.28.100 from version 1.28.1
Upgrading database to version 1.28.100
Loading config from DB
Saving config to DB
Upgrading DB to 1.28.1 from 1.28.1
Database successfully upgraded to version 1.28.1.
Upgrading DB to 1.28.100 from 1.28.1
Database successfully upgraded to version 1.28.100.
Upgrading DB to 1.28.99 from 1.28.1
ERROR 1142 (42000) at line 376: CREATE command denied to user 'zmuser'@'localhost' for table 'Servers'
Output:
Command 'mysql -hlocalhost -uzmuser -pzmpass zm < /usr/share/zoneminder/db/zm_update-1.28.99.sql' exited with status: 1
dpkg: Fehler beim Bearbeiten des Paketes zoneminder (--configure):
Unterprozess installiertes post-installation-Skript gab den Fehlerwert 1 zurück
Fehler traten auf beim Bearbeiten von:
zoneminder
E: Sub-process /usr/bin/dpkg returned an error code (1)
