Debian Testing + zoneminder 1.28 NOT WORK
daryl0
Post by daryl0 »
I've installed Debian Testing.
Then I install Zoneminder from synaptic.
When i start
localhost/zm
view on screen
NOT FOUND (the requested URL /zm non found on this server
Why?
Thanks.
Dario B.
Re: Debian Testing + zoneminder 1.28 NOT WORK
I'm not a Debian user so I don't know if Debian testing is an official Debian repo or not. It sounds like it is.
If that is indeed an official Debian repository, note that we don't create those packages and do not have direct control over them.
I've heard through others that the zoneminder package from Debain requires a bit of manual configuration before it will work.
So if you just did an "apt get" and have not read the documentation with the package, then I'd say you should start there.
There are probably some steps you need to perform.
If you are still having configuration issues, then you may need to contact the Debian package maintainer to get it resolved.
PacoLM
Post by PacoLM »
What about http:\\localhost?
Is the apache2 service working (try service apache2 status)
Regards,
PacoLM
Look through this how-to:
http://www.zoneminder.com/wiki/index.ph ... e_Easy_Way
You might find some clues as to how to set up your Zoneminder. There is more than just installing the program...
pyroman
Post by pyroman »
my zoneminder main page moved to localhost/zm/www after the update to 1.28.104
