zoneminder error after Ubuntu 14.04 / ZM 1.28.107 update
sodisuhy
Post by sodisuhy »
i was patching my Ubuntu 14.04 server running ZoneMinder 1.28, and inadvertently installed the 'package maintainer's version' of /etc/init.d/zoneminder. see below.
Setting up zoneminder (1.28.107-trusty-2015101401) ...
Configuration file '/etc/init.d/zoneminder'
==> Modified (by you or by a script) since installation.
==> Package distributor has shipped an updated version.
What would you like to do about it ? Your options are:
Y or I : install the package maintainer's version
N or O : keep your currently-installed version
D : show the differences between the versions
Z : start a shell to examine the situation
The default action is to keep your current version.
*** zoneminder (Y/I/N/O/D/Z) [default=N] ? y
Installing new version of config file /etc/init.d/zoneminder ...
Installing new version of config file /etc/zm/zm.conf ...
Setting up zoneminder-doc (1.28.107-trusty-2015101401) ...
after a reboot, i try to login to the web UI and receive the following error:
ZoneMinder is not installed properly: php's date.timezone is not set to a valid timezone
can anyone tell me how to fix this? i am uncertain at this point.
PacoLM
Re: zoneminder error after Ubuntu 14.04 / ZM 1.28.107 update
Post by PacoLM »
Check this out: http://www.zoneminder.com/wiki/index.ph ... _on_Ubuntu
Bbunge has made a good job compiling all this information to help other users.
Hope it helps,
Paco
PacoLM
Post by PacoLM »
Add timezone to PHP
nano /etc/php5/apache2/php.ini
Search for [Date] and make changes as follows for your time zone
[Date]
sodisuhy
Post by sodisuhy »
thanks for the replies, Paco. i appreciate your feedback.
