Vanishing timestamps in 1.21.1
lazyleopard
Post by lazyleopard »
Installed 1.21.1 last night. All seemed well, but I've noticed this morning that none of the images are getting time annotations on them any more. Anyone else noticed this, or have I done something daft?
Rick Hewett
zoneminder
Site Admin
Post by zoneminder »
Do you mean in the live view or in events? Have you checked the timestamp format in the monitor definitions is still there?
Phil
lazyleopard
The timestamps in the images as stored in the events sub-directories.
Yes, the timestamp locations (0,0) and formats (%y/%m/%d %H:%M:%S) are still defined for all the monitors.
I've tried re-starting zoneminder after toggling ZM_TIMESTAMP_ON_CAPTURE both ways, too.
Rick Hewett
zoneminder
Site Admin
Ah ok. I think is an actual bug as this area has changed slightly and I can reproduce the issue here. Added %%s to the timestamp will get it back but with the inclusion of the monitor name. I'll do a fix and get it out in the next day or so (to allow for any other issues to show).
Phil
zoneminder
Site Admin
I've found the problem. If you're impatient then this patch
*** src/zm_monitor.h    22 May 2005 17:33:34 -0000      1.40
--- src/zm_monitor.h    15 Jun 2005 13:21:53 -0000
*** 219,224 ****
--- 219,229 ----
                        strftime( label_time_text, sizeof(label_time_text), label_format, localtime( &ts_time ) );
                        switch ( token_count )
+                               case 0:
+                                       strncpy( label_text, label_time_text, sizeof(label_text) );
+                                       break;
                                case 1:
                                        snprintf( label_text, sizeof(label_text), label_time_text, name );
should get it working in the meantime.
Phil
lazyleopard
Cheers. That patch fixed it. ;)
Rick Hewett
