disk percent not working
littlej
Post by littlej »
Hi, i just installed 1.28.108 on ubuntu 14.04 but now i have a problem with disk percent. My cams are recording ok but disk percent does not increase, check the attached (untitled) file and this is my df output :
Filesystem Size Used Avail Use% Mounted on
/dev/sda2 143G 19G 118G 14% /
none 4.0K 0 4.0K 0% /sys/fs/cgroup
udev 1.9G 4.0K 1.9G 1% /dev
tmpfs 391M 536K 390M 1% /run
none 5.0M 0 5.0M 0% /run/lock
none 2.0G 643M 1.3G 33% /run/shm
none 100M 0 100M 0% /run/user
/dev/mapper/lvm0-zone 4.1T 1.7T 2.3T 43% /var/cache/zoneminder
as you can see my space it's used and nothing weird in logs, permission is setup correctly (it was a 1.28.1 running setup i just upgraded it).
Please help me out, i'm afraid purge wen full filter wont work.
Also i have a problem when trying to setup alarm zones, the camera image wont show up but viewer works ok (check untitled2 attachment).
littlej
Re: disk percent not working
Post by littlej »
ok, so disk percent works now, it seems it is not working with a symbolic link anymore, i had to edit the path options in zm.
