Trendnet TV-IP321PI
kronos.gaia
Trendnet TV-IP321PI
Post by kronos.gaia »
is there any way to connect the Trendnet TV-IP321PI into Zoneminder?
I tried these settings:
Remote Protocol: ffmpeg
Source path: rtsp://user:pass@<camera ip address>/streaming/Channels/1
i am receiving 1 image, after this, the screen turns red.
every help appreciated.
thanks
david
PacoLM
Re: Trendnet TV-IP321PI
Post by PacoLM »
If you explain us a little bit more (which hardware you are using, the Linux distro, etc), will help us to help you. I will try selecting VLC instead of ffmpeg...
Hope it helps,
PacoLM
kronos.gaia
i am using
* Ubuntu 14.04.2 LTS
* ZM v1.27
The server HW i can not tell by heart. i need to take a look, what specific information are you looking for?
My second camera instar in-2905 v2 is working without issues using the HTTP, simple configuration.
thanks for your help
david
jwildman
Post by jwildman »
I am trying to get the same camera working with zm v1.28.1 on RHEL 7.
I've tried the settings recommended https://wiki.zoneminder.com/Trendnet#TV-IP320PI but that does not give me an image.
If I give it a username and password (with http and rtsp auth enabled on the camera) I get failed logins. With no auth configured on the camera I get
Unable to open input http://192.168.0.91/streaming/Channels/1 due to: Operation now in progress
I've tried a lot of other combinations as well (http/url, etc) but can't find the right combination. Pointers?
PacoLM
Post by PacoLM »
In your monitor setup, try ffmpeg as source type and RTP/RTSP as Remote method.
PacoLM
Post by PacoLM »
This is another source of good information: https://www.ispyconnect.com/man.aspx?n=TV-IP321PI
jwildman
Post by jwildman »
PacoLM wrote:In your monitor setup, try ffmpeg as source type and RTP/RTSP as Remote method.
I tried that per the wiki, but I'll reset and have another run at it. Also try the iSpy reference. Thanks..
jwildman
Post by jwildman »
PacoLM wrote:Hi,
I reset the camera and set a different (simpler) password.
Source type set to ffmpeg and source path set to rtsp://admin:changeme@192.168.0.91:554//Streaming/Channels/2 per the iSpy reference. (I've also tried 0 and 1 as the channel number).
Still getting this in the logs
"Unable to open input rtsp://admin:changeme@192.168.0.91:554//Streaming/Channels/2 due to: Permission denied"
Other suggestions? I have the latest firmware. (V5.1.7 build 141111) per the trendnet.com website.
PacoLM
Post by PacoLM »
Have you tried to view the streaming from a windows/linux machine? I suggest you to copy the network path to the VideoLan player (for instance) and check if you could see it. I do not remember if you already done that. If you could see it, then seems a permission problem.
I will check the permissions on my system and let you know,
PacoLM
jwildman
Post by jwildman »
PacoLM wrote:Hi,
PacoLM
Well, I was _this_ close to saying it wouldn't work at all. But it works with
cvlc rtsp://admin:changeme@192.168.0.91:554/Streaming/Channels/2
With the source path copied right from the monitor definition on Zoneminder. So the source path is correct and the camera functions with Linux.
Apparently I'm missing something on my ZM setup?
I've switched my host OS to Fedora 22
I installed Zoneminder from the zmrepo for Fedora 22.
The only thing I touched in zm.conf was the database authentication stuff.
I ran the cvlc command (above) from the zoneminder host that is not working correctly with the monitor, which would seem to eliminate missing libraries, etc.
to recap
Source path set to rtsp://admin:changeme@192.168.0.91:554/Streaming/Channels/2
Remote method set to rtp/rtsp
Log shows
Unable to open input rtsp://admin:changeme@192.168.0.91:554/Streaming/Channels/2 due to: Permission denied
and occassionally
socket_bind( /var/lib/zoneminder/sock/zms-432499w.sock ) failed: Permission denied
Host OS is Fedora 22, 64 bit, selinux set to permissive mode.
Just noticed this in /var/log/messages
Nov 13 20:54:33 zmfed zmc_m1[4364]: INF [Monitor-1: 260000 - Capturing at inf fps]
Nov 13 20:54:34 zmfed zmc_m1[4364]: INF [Monitor-1: 261000 - Capturing at 1000.00 fps]
Where do I look next??
SteveGilvarry
Post by SteveGilvarry »
Have a go with source type remote also, and then start cranking up debug levels on zmc to see if you get any more information. It must be doing something that ffmpeg doesn't handle
jwildman
Post by jwildman »
SteveGilvarry wrote:Have a go with source type remote also, and then start cranking up debug levels on zmc to see if you get any more information. It must be doing something that ffmpeg doesn't handle
Tried remote and libvlc as well and generated various other errors. I've gone back to ffmpeg and turned up the logging.
/var/log/zoneminder/zmc_mc1.log has lots of these sets
11/16/15 06:30:09.586949 zmc_m1[26426].ERR-/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_ffmpeg_camera.cpp/161 [Unable to read packet from stream 0: error -541478725 "End of file".]
11/16/15 06:30:10.582757 zmc_m1[26426].INF-/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_ffmpeg_camera.cpp/128 [Successfully reopened stream.]
11/16/15 06:30:22.871470 zmc_m1[26426].ERR-/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_ffmpeg_camera.cpp/161 [Unable to read packet from stream 0: error -1 "Operation not permitted".]
11/16/15 06:30:23.121233 zmc_m1[26426].INF-/builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_ffmpeg_camera.cpp/157 [av_read_frame returned "End of file". Reopening stream.]
/var/log/zoneminder/zmdc.log has
11/15/2015 21:04:16.846608 zmdc[15716].INF ['zmc -m 1' starting at 15/11/15 21:04:16, pid = 26426]
11/15/2015 21:04:16.851236 zmdc[26426].INF ['zmc -m 1' started at 15/11/15 21:04:16]
11/15/2015 21:04:17.162733 zmdc[15716].WAR [Can't find process with command of 'zmtrack.pl -m 1']
11/15/2015 21:04:17.328353 zmdc[15716].WAR [Can't find process with command of 'zma -m 1']
The date is from the last time I saved the monitor definition.
This is the current state
[root@zmfed zoneminder]# ps -ef | grep zm
root 4708 26154 0 06:38 pts/0 00:00:00 grep --color=auto zm
apache 15716 1 0 Nov14 ? 00:01:32 /usr/bin/perl -wT /usr/bin/zmdc.pl startup
apache 15751 15716 0 Nov14 ? 00:00:08 /usr/bin/perl -wT /usr/bin/zmfilter.pl
apache 15761 15716 0 Nov14 ? 00:00:00 /usr/bin/perl -wT /usr/bin/zmaudit.pl -c
apache 15771 15716 0 Nov14 ? 00:00:09 /usr/bin/perl -wT /usr/bin/zmwatch.pl
apache 26426 15716 0 Nov15 ? 00:01:34 /usr/bin/zmc -m 1
Just to verify that everything still works, I tried it with vlc again (cutting and pasting the path from my monitor definition) and it worked flawlessly.
SteveGilvarry
All I have got left is to try with ffplay instead of vlc, that is the same libraries as the monitor type you are using. If that works them I am out of ideas.
I do wonder if there is a way to capture and restream cameras to help debug these issues. Maybe some clues here https://trac.ffmpeg.org/ticket/3823
jwildman
Post by jwildman »
SteveGilvarry wrote:All I have got left is to try with ffplay instead of vlc, that is the same libraries as the monitor type you are using. If that works them I am out of ideas.
well, unfortunately
ffplay rtsp://admin:changeme@192.168.0.91:554/Streaming/Channels/2
works fine (default is grey scale, but I assume that's just some option I need to find)
does the camera open a port on the zm machine? I noticed a change in behaviour when I dropped iptables on the zm host...
benf
Post by benf »
Just have been having some fun getting a TV-IP310PI working and have updated the Wiki with the combination of settings that gave me a useable feed to Zoneminder.
These are the settings that worked for me, and may be useful for you. my Zoneminder box is Centos 6, Zoneminder 1.28.1 :
Maximum FPS and Alam Maximum FPS : Set to match the FPS value set in the camera GUI
Remote Method : RTP/RTSP ( ZM 1.28.1 )
I've updated the Wiki as well with these details
https://wiki.zoneminder.com/Trendnet#TV-IP310PI
