How to verify the API's
BiloxiGeek
Post by BiloxiGeek »
Just updated my SciLinux 7.1 system to zm 1.28.107-1 using the repo. I see all the API files under /usr/share/zoneminder/www/api/ but so far I can't seem to verify if it's all running correctly. I can see the web interface and all my cameras, zm itself seems to work just fine so far.
Rebooted after all that just to make sure and still get the output below when I try to bring up https://hostname/zm/api/host/getVersion.json and I get this:
    "success": false,
    "data": {
        "code": 500,
        "name": "Database connection "Mysql" is missing, or could not be created.",
        "message": "SQLSTATE[28000] [1045] Access denied for user 'zmuser'@'localhost' (using password: YES)",
        "url": "\/zm\/api\/host\/getVersion.json",
        "exception": {
            "class": "MissingConnectionException",
            "code": 500,
            "message": "Database connection \"Mysql\" is missing, or could not be created.",
            "trace": [
                "#0 \/usr\/share\/zoneminder\/www\/api\/lib\/Cake\/Model\/Datasource\/DboSource.php(260): Mysql->connect()",
                "#1 \/usr\/share\/zoneminder\/www\/api\/lib\/Cake\/Model\/ConnectionManager.php(105): DboSource->__construct(Array)",
                "#2 \/usr\/share\/zoneminder\/www\/api\/lib\/Cake\/Model\/Model.php(3479): ConnectionManager::getDataSource('default')",
                "#3 \/usr\/share\/zoneminder\/www\/api\/lib\/Cake\/Model\/Model.php(1128): Model->setDataSource('default')",
                "#4 \/usr\/share\/zoneminder\/www\/api\/lib\/Cake\/Model\/Model.php(3501): Model->setSource('Config')",
                "#5 \/usr\/share\/zoneminder\/www\/api\/lib\/Cake\/Model\/Model.php(2905): Model->getDataSource()",
                "#6 \/usr\/share\/zoneminder\/www\/api\/lib\/Cake\/Model\/Model.php(2877): Model->_readDataSource('first', Array)",
                "#7 \/usr\/share\/zoneminder\/www\/api\/app\/Controller\/AppController.php(62): Model->find('first', Array)",
                "#8 [internal function]: AppController->beforeFilter(Object(CakeEvent))",
                "#9 \/usr\/share\/zoneminder\/www\/api\/lib\/Cake\/Event\/CakeEventManager.php(244): call_user_func(Array, Object(CakeEvent))",
                "#10 \/usr\/share\/zoneminder\/www\/api\/lib\/Cake\/Controller\/Controller.php(674): CakeEventManager->dispatch(Object(CakeEvent))",
                "#11 \/usr\/share\/zoneminder\/www\/api\/lib\/Cake\/Routing\/Dispatcher.php(187): Controller->startupProcess()",
                "#12 \/usr\/share\/zoneminder\/www\/api\/lib\/Cake\/Routing\/Dispatcher.php(165): Dispatcher->_invoke(Object(HostController), Object(CakeRequest))",
                "#13 \/usr\/share\/zoneminder\/www\/api\/app\/webroot\/index.php(108): Dispatcher->dispatch(Object(CakeRequest), Object(CakeResponse))",
                "#14 {main}"
        "queryLog": [
asker
Re: How to verify the API's
Post by asker »
Please read before posting:
ES docs
zmNinja docs
BiloxiGeek
I did not, just tweaked my repo settings and updated the zoneminder package from the testing repo. As I understand things knnniggett did all the work to get the API's working within the rpm's.
asker
Post by asker »
It looks like the Database connection was not correctly updated in your case (The APIs need to be able to connect to the ZM DB). I can get you to fix it manually but I'd rather not - since it should be all handled within the repo like you suggested.
Let's wait for knnniggett to respond.
ES docs
zmNinja docs
BiloxiGeek
Maybe I'll drop a shrubbery in here to lure him in. :)
He is using the rpm's in zmrepo. It worked in my test environment right out of the box.
Says it can't connect to your database using the account zmuser@localhost.
Did you change the password for your zmuser to something other than the default?
Did you change the user account zoneminder uses to something other than "zmuser"?
Is mysql running on the local server?
BiloxiGeek
Yes I changed password and checked /etc/zm/zm.conf and it's correct for the password.
mariadb.x86_64 is installed and running on the local server.
What I'm wondering if we have tested the API with a non-default password. It should work.
@asker Have you tried the API when the zmuser password has been changed to something unique?
BiloxiGeek
FYI: The goal here is get the API working. And then give zmNinja a test drive on my desktops, iPhone and iPad.
Agreed. Asker has been the driving force behind API development. If there is a problem with the API, he is most qualified to speak to that.
asker
Post by asker »
Yes, I use non-standard passwords.
If you changed the password _after_ installing Zoneminder, then the API won't know about it.
Go to zoneminder/www/api/app/Config
Edit database.php
There is a class there called DATABASE_CONFIG - change the $default array to reflect your new details. Example
public $default = array(
                'datasource' => 'Database/Mysql',
                'persistent' => false,
                'host' => 'localhost',
                'login' => 'mynewDBusername',
                'password' => 'mynewDBpassword',
                'database' => 'zm',
                'prefix' => '',
                //'encoding' => 'utf8',
ES docs
zmNinja docs
Ah, that is good to know. @BiloxiGeek I'd check your database.php. The error message you received would be a symptom of a misconfigured database.php.
Maybe in the future we can get the API to parse the variables it needs right out of the zm.conf file.
BiloxiGeek
Getting a different error now. Looks like the permissions and/or ownership of /usr/share/zoneminder/... is borked up. Should that whole file structure be owned apache:apache?
Warning: mkdir(): Permission denied in /usr/share/zoneminder/www/api/lib/Cake/Cache/Engine/FileEngine.php on line 379
Warning: _cake_core_ cache was unable to write 'cake_dev_en-us' to File cache in /usr/share/zoneminder/www/api/lib/Cake/Cache/Cache.php on line 323
Warning: /usr/share/zoneminder/www/api/app/tmp/cache/persistent/ is not writable in /usr/share/zoneminder/www/api/lib/Cake/Cache/Engine/FileEngine.php on line 384
Fatal error: Uncaught exception 'CacheException' with message 'Cache engine _cake_core_ is not properly configured.' in /usr/share/zoneminder/www/api/lib/Cake/Cache/Cache.php:181 Stack trace: #0 /usr/share/zoneminder/www/api/lib/Cake/Cache/Cache.php(151): Cache::_buildEngine('_cake_core_') #1 /usr/share/zoneminder/www/api/app/Config/core.php(376): Cache::config('_cake_core_', Array) #2 /usr/share/zoneminder/www/api/lib/Cake/Core/Configure.php(72): include('/usr/share/zone...') #3 /usr/share/zoneminder/www/api/lib/Cake/bootstrap.php(175): Configure::bootstrap(true) #4 /usr/share/zoneminder/www/api/app/webroot/index.php(90): include('/usr/share/zone...') #5 {main} thrown in /usr/share/zoneminder/www/api/lib/Cake/Cache/Cache.php on line 181
Verify this folder is a symlink pointing to /var/lib/zoneminder/temp:
/var/lib/zoneminder/temp of course should be owned by apache.
The rpm package should have done all this for you.
BiloxiGeek
That was the trick! The softlink is there and correct, but I've done a little jiggery-pokery on my setup. All the zoneminder stuff is actually on a big logical volume /export/zoneminder, and I've softlinked to that. The temp subdirectory was owned by root, but it's fixed now:
    "version": "1.28.107",
    "apiversion": "1.28.107.1"
Now I can start fiddling with the desktop app.
