No Video (all else is fine) new install
Re: No Video (all else is fine) new install
I had similar problems directly after my install (on Debian). I solved it by deleting all events, then new events as well as live video started working... But my guess is that it was a problem with the web browser cache not trying to load the updated content. Try to clear the browsers cache.
ZoneMinder in Puppy Linux Tahr is somewhat tricky, sort of Debian sort of Ubuntu. This problem sometimes occurs, and the fix is to change Web path to zms streaming server PATH_ZMS in Options>Paths from:
to:
brought the video stream to life.
Hope it helps.
/cgi-bin/nph-zms
/cgi-bin/zms
Hope it helps.
Ok,
I disabled the Barn camera and left Driveway on. Actually disabled both and enabled one Driveway
Then i tried to view Driveway a number of times. No results of corse but plenty of errors.
Hope this is what you want.
Thanks! George....
Date/Time
Component PID Level Message File Line
2015-11-24 09:36:09.253787 zma_m4 6103 INF Driveway: 7000 - Processing at 13.70 fps zm_monitor.cpp 1160
2015-11-24 09:36:05.230779 zmc_m4 6068 INF Driveway: 7000 - Capturing at 13.70 fps zm_monitor.cpp 2907
2015-11-24 09:35:22.033367 zma_m2 6021 INF Barn: 7000 - Processing at 14.93 fps zm_monitor.cpp 1160
2015-11-24 09:35:19.515838 zmc_m2 5965 INF Barn: 7000 - Capturing at 15.15 fps zm_monitor.cpp 2907
2015-11-24 09:34:56.166720 zma_m4 6103 INF Driveway: 6000 - Processing at 13.70 fps zm_monitor.cpp 1160
2015-11-24 09:34:52.625263 zmc_m4 6068 INF Driveway: 6000 - Capturing at 13.70 fps zm_monitor.cpp 2907
2015-11-24 09:34:38.605720 web_php 1562 ERR socket_sendto( /var/lib/zoneminder/sock/zms-262332s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:34:28.478346 web_php 5005 ERR socket_sendto( /var/lib/zoneminder/sock/zms-262332s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:34:15.672901 zma_m2 6021 INF Barn: 6000 - Processing at 15.15 fps zm_monitor.cpp 1160
2015-11-24 09:34:15.003024 web_php 4924 ERR socket_sendto( /var/lib/zoneminder/sock/zms-262332s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:34:13.473243 zmc_m2 5965 INF Barn: 6000 - Capturing at 15.15 fps zm_monitor.cpp 2907
2015-11-24 09:33:43.293827 zma_m4 6103 INF Driveway: 5000 - Processing at 13.70 fps zm_monitor.cpp 1160
2015-11-24 09:33:41.706596 web_php 4832 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:33:39.784819 zmc_m4 6068 INF Driveway: 5000 - Capturing at 13.89 fps zm_monitor.cpp 2907
2015-11-24 09:33:24.782689 web_php 6881 ERR socket_sendto( /var/lib/zoneminder/sock/zms-466986s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:33:11.196369 web_php 5005 ERR socket_sendto( /var/lib/zoneminder/sock/zms-466986s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:33:09.557647 zma_m2 6021 INF Barn: 5000 - Processing at 15.15 fps zm_monitor.cpp 1160
2015-11-24 09:33:07.597598 zmc_m2 5965 INF Barn: 5000 - Capturing at 15.15 fps zm_monitor.cpp 2907
2015-11-24 09:32:57.712201 web_php 5014 ERR socket_sendto( /var/lib/zoneminder/sock/zms-466986s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:32:43.074258 web_php 4853 ERR socket_sendto( /var/lib/zoneminder/sock/zms-466986s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:32:30.898343 web_php 5008 ERR socket_sendto( /var/lib/zoneminder/sock/zms-466986s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:32:30.628499 zma_m4 6103 INF Driveway: 4000 - Processing at 13.89 fps zm_monitor.cpp 1160
2015-11-24 09:32:27.389184 zmc_m4 6068 INF Driveway: 4000 - Capturing at 13.89 fps zm_monitor.cpp 2907
2015-11-24 09:32:20.652991 web_php 1562 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:32:10.492027 web_php 4950 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:32:03.482217 zma_m2 6021 INF Barn: 4000 - Processing at 15.15 fps zm_monitor.cpp 1160
2015-11-24 09:32:01.720833 zmc_m2 5965 INF Barn: 4000 - Capturing at 15.15 fps zm_monitor.cpp 2907
2015-11-24 09:32:00.331480 web_php 6876 ERR socket_sendto( /var/lib/zoneminder/sock/zms-466986s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:31:50.232122 web_php 4825 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:31:40.098706 web_php 4807 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:31:29.907542 web_php 4966 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:31:19.405980 web_php 4796 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:31:18.265652 zma_m4 6103 INF Driveway: 3000 - Processing at 13.89 fps zm_monitor.cpp 1160
2015-11-24 09:31:15.170174 zmc_m4 6068 INF Driveway: 3000 - Capturing at 13.89 fps zm_monitor.cpp 2907
2015-11-24 09:31:09.209223 web_php 4905 ERR socket_sendto( /var/lib/zoneminder/sock/zms-466986s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:30:59.004575 web_php 4845 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:30:57.156175 zma_m2 6021 INF Barn: 3000 - Processing at 14.93 fps zm_monitor.cpp 1160
2015-11-24 09:30:55.654919 zmc_m2 5965 INF Barn: 3000 - Capturing at 15.15 fps zm_monitor.cpp 2907
2015-11-24 09:30:48.836182 web_php 5005 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:30:38.672087 web_php 4961 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:30:28.530405 web_php 4978 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:30:18.345409 web_php 5014 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:30:07.049387 web_php 5025 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:30:06.392238 zma_m4 6103 INF Driveway: 2000 - Processing at 13.89 fps zm_monitor.cpp 1160
2015-11-24 09:30:03.284374 zmc_m4 6068 INF Driveway: 2000 - Capturing at 13.89 fps zm_monitor.cpp 2907
2015-11-24 09:30:00.176753 zma_m4 6103 INF Driveway: 1915 - Opening new event 484, section start zm_monitor.cpp 1405
2015-11-24 09:30:00.034524 zma_m4 6103 INF Driveway: 1915 - Closing event 483, section end zm_monitor.cpp 1385
2015-11-24 09:29:56.938719 web_php 4861 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:29:50.821482 zma_m2 6021 INF Barn: 2000 - Processing at 15.15 fps zm_monitor.cpp 1160
2015-11-24 09:29:49.855378 zmc_m2 5965 INF Barn: 2000 - Capturing at 15.15 fps zm_monitor.cpp 2907
2015-11-24 09:29:46.844274 web_php 4855 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:29:36.755971 web_php 4970 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:29:26.449654 web_php 4879 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:29:16.304951 web_php 4843 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:29:03.865294 web_php 5010 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:28:54.260918 zma_m4 6103 INF Driveway: 1000 - Processing at 13.16 fps zm_monitor.cpp 1160
2015-11-24 09:28:53.764343 web_php 4899 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:28:51.114033 zmc_m4 6068 INF Driveway: 1000 - Capturing at 13.70 fps zm_monitor.cpp 2907
2015-11-24 09:28:44.249362 zma_m2 6021 INF Barn: 1000 - Processing at 14.93 fps zm_monitor.cpp 1160
2015-11-24 09:28:43.713913 zmc_m2 5965 INF Barn: 1000 - Capturing at 15.15 fps zm_monitor.cpp 2907
2015-11-24 09:28:43.652756 web_php 5001 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:28:32.445342 web_php 4798 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:28:22.266149 web_php 4903 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:28:12.165510 web_php 4424 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:28:00.980347 web_php 4837 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:27:47.457289 web_php 4916 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:27:43.598910 zmwatch 6261 INF Watchdog pausing for 30 seconds zmwatch.pl
2015-11-24 09:27:43.388050 zmwatch 6261 INF Watchdog starting zmwatch.pl
2015-11-24 09:27:43.328090 zmdc 5761 INF 'zmupdate.pl -c' starting at 15/11/24 09:27:43, pid = 6517 zmdc.pl
2015-11-24 09:27:43.324900 zmdc 6517 INF 'zmupdate.pl -c' started at 15/11/24 09:27:43 zmdc.pl
2015-11-24 09:27:42.790460 zma_m4 6103 INF Driveway: 026 - Opening new event 483, section start zm_monitor.cpp 1405
2015-11-24 09:27:40.906440 zmfilter 6153 INF Scanning for events zmfilter.pl
2015-11-24 09:27:40.358490 zmdc 6261 INF 'zmwatch.pl' started at 15/11/24 09:27:40 zmdc.pl
2015-11-24 09:27:40.337420 zmdc 5761 INF 'zmwatch.pl' starting at 15/11/24 09:27:40, pid = 6261 zmdc.pl
2015-11-24 09:27:39.506270 zmdc 6202 INF 'zmaudit.pl -c' started at 15/11/24 09:27:39 zmdc.pl
2015-11-24 09:27:39.503530 zmdc 5761 INF 'zmaudit.pl -c' starting at 15/11/24 09:27:39, pid = 6202 zmdc.pl
2015-11-24 09:27:38.834080 zmdc 6153 INF 'zmfilter.pl' started at 15/11/24 09:27:38 zmdc.pl
2015-11-24 09:27:38.829810 zmdc 5761 INF 'zmfilter.pl' starting at 15/11/24 09:27:38, pid = 6153 zmdc.pl
2015-11-24 09:27:38.429462 zma_m4 6103 INF In mode 5/1, warming up zma.cpp 105
2015-11-24 09:27:38.277690 zmdc 6103 INF 'zma -m 4' started at 15/11/24 09:27:38 zmdc.pl
2015-11-24 09:27:38.272010 zmdc 5761 INF 'zma -m 4' starting at 15/11/24 09:27:38, pid = 6103 zmdc.pl
2015-11-24 09:27:38.255220 zmc_m4 6068 INF Starting Capture zmc.cpp 195
2015-11-24 09:27:37.903950 zmdc 6068 INF 'zmc -m 4' started at 15/11/24 09:27:37 zmdc.pl
2015-11-24 09:27:37.898290 zmdc 5761 INF 'zmc -m 4' starting at 15/11/24 09:27:37, pid = 6068 zmdc.pl
2015-11-24 09:27:37.836480 zmdc 5761 INF Starting pending process, zmc -m 4 zmdc.pl
2015-11-24 09:27:37.702820 zmdc 5761 ERR 'zmc -m 4' exited abnormally, exit status 255 zmdc.pl
2015-11-24 09:27:37.623706 zma_m2 6021 INF In mode 5/0, warming up zma.cpp 105
2015-11-24 09:27:37.567500 zmdc 5761 INF 'zmc -m 4' starting at 15/11/24 09:27:37, pid = 6034 zmdc.pl
2015-11-24 09:27:37.565100 zmdc 6034 INF 'zmc -m 4' started at 15/11/24 09:27:37 zmdc.pl
2015-11-24 09:27:37.460700 zmdc 6021 INF 'zma -m 2' started at 15/11/24 09:27:37 zmdc.pl
2015-11-24 09:27:37.447210 zmdc 5761 INF 'zma -m 2' starting at 15/11/24 09:27:37, pid = 6021 zmdc.pl
2015-11-24 09:27:37.366795 zmc_m2 5965 INF Starting Capture zmc.cpp 195
2015-11-24 09:27:37.343260 zmdc 5761 INF Starting pending process, zma -m 2 zmdc.pl
2015-11-24 09:27:37.269540 zmdc 5761 ERR 'zma -m 2' exited abnormally, exit status 255 zmdc.pl
2015-11-24 09:27:37.139187 zma_m2 5974 ERR Shared data not initialised by capture daemon for monitor Barn zm_monitor.cpp 421
2015-11-24 09:27:37.121655 web_php 4928 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:27:36.896420 zmdc 5761 INF 'zma -m 2' starting at 15/11/24 09:27:36, pid = 5974 zmdc.pl
2015-11-24 09:27:36.896400 zmdc 5974 INF 'zma -m 2' started at 15/11/24 09:27:36 zmdc.pl
2015-11-24 09:27:36.841710 zmdc 5965 INF 'zmc -m 2' started at 15/11/24 09:27:36 zmdc.pl
2015-11-24 09:27:36.827410 zmdc 5761 INF 'zmc -m 2' starting at 15/11/24 09:27:36, pid = 5965 zmdc.pl
2015-11-24 09:27:36.748740 zmdc 5761 INF Starting pending process, zmc -m 2 zmdc.pl
2015-11-24 09:27:36.698790 zmdc 5761 ERR 'zmc -m 2' exited abnormally, exit status 255 zmdc.pl
2015-11-24 09:27:36.375670 zmdc 5921 INF 'zmc -m 2' started at 15/11/24 09:27:36 zmdc.pl
2015-11-24 09:27:36.373830 zmdc 5761 INF 'zmc -m 2' starting at 15/11/24 09:27:36, pid = 5921 zmdc.pl
2015-11-24 09:27:33.012880 zmdc 5761 INF Server starting at 15/11/24 09:27:33 zmdc.pl
2015-11-24 09:27:30.229250 zmpkg 5466 INF Command: start zmpkg.pl
2015-11-24 09:27:26.983348 web_php 4805 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:27:24.366730 zmdc 3427 INF Server shutdown at 15/11/24 09:27:24 zmdc.pl
2015-11-24 09:27:16.892617 web_php 4992 ERR socket_sendto( /var/lib/zoneminder/sock/zms-250373s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2330
2015-11-24 09:27:13.990070 zmdc 3427 INF 'zmfilter.pl ' exited, signal 14 zmdc.pl
2015-11-24 09:27:13.926710 zmdc 3427 INF 'zmfilter.pl ' stopping at 15/11/24 09:27:13 zmdc.pl
2015-11-24 09:27:13.853190 zmdc 3427 INF 'zmc -m 2' exited normally zmdc.pl
2015-11-24 09:27:13.818537 zmc_m2 4460 INF Terminating Logger zm_logger.cpp 236
2015-11-24 09:27:13.759318 zmc_m2 4460 ERR Unable to get response zm_remote_camera_http.cpp 1176
2015-11-24 09:27:13.717414 zmc_m2 4460 ERR Unable to read header zm_remote_camera_http.cpp 650
2015-11-24 09:27:13.683933 zmc_m2 4460 ERR Select error: Interrupted system call zm_remote_camera_http.cpp 163
2015-11-24 09:27:13.650507 zmc_m2 4460 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2015-11-24 09:27:13.600490 zmdc 3427 INF 'zmc -m 2' stopping at 15/11/24 09:27:13 zmdc.pl
2015-11-24 09:27:13.551970 zmdc 3427 INF 'zma -m 4' exited normally zmdc.pl
Thanks! George....
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
N4ZPO (ham Radio)
- knight-of-ni
You have a configuration problem, but so far I have been unable to find it.
Report the following:
Make sure you've put PATH_ZMS back to /cgi-bin/zm/nph-zms and the ZoneMinder Apache ScriptAlias matches that.
And have you completed this step from /usr/share/doc/zoneminder/README.Fedora:
rpm -qi zoneminder
7. IMPORTANT: Edit /etc/httpd/conf.d/zoneminder.conf and/or
/etc/httpd/conf/httpd.conf.
The httpd.conf file included with this version of Fedora processes the conf.d
folder after the default ScriptAlias directive in the httpd.conf file.
Previously, the conf.d folder was processed before the default ScriptAlias
directive. This causes a ScriptAlias overlap and breaks Zoneminder's
streaming abilities.
Reference: http://httpd.apache.org/docs/2.4/mod/mo ... html#order
Bug Report: https://bugzilla.redhat.com/show_bug.cgi?id=973067
WORKAROUND #1
If you are running zoneminder on a dedicated server then the simplest
solution may be to simply comment out the line in httpd.conf that reads:
WORKAROUND #2
If you need both the default cgi-bin folder & the zoneminder cgi-bin folder
then a solution might be to move the following line before the default
ScriptAlias directive in the httpd.conf file:
IncludeOptional conf.d/*.conf
Here is the first part:
It will take me a while on the rest.
Thanks! George....
Thanks! George....
[george@tera-two Desktop]$ su -l
Password:
[root@tera-two ~]# systemctl start zoneminder
[root@tera-two ~]# rpm -qi zoneminder
Version : 1.28.1
Release : 4.fc23
Architecture: x86_64
Install Date: Wed 18 Nov 2015 08:34:22 AM EST
Group : System Environment/Daemons
License : GPLv2+ and LGPLv2+ and MIT
Signature : RSA/SHA256, Tue 23 Jun 2015 05:03:32 PM EDT, Key ID 32474cf834ec9cba
Source RPM : zoneminder-1.28.1-4.fc23.src.rpm
Build Date : Fri 19 Jun 2015 01:46:29 AM EDT
Build Host : buildhw-11.phx2.fedoraproject.org
Relocations : (not relocatable)
Packager : Fedora Project
Vendor : Fedora Project
URL : http://www.zoneminder.com/
Summary : A camera monitoring and analysis tool
Description :
ZoneMinder is a set of applications which is intended to provide a complete
solution allowing you to capture, analyse, record and monitor any cameras you
have attached to a Linux based machine. It is designed to run on kernels which
support the Video For Linux (V4L) interface and has been tested with cameras
attached to BTTV cards, various USB cameras and IP network cameras. It is
designed to support as many cameras as you can attach to your computer without
too much degradation of performance.
[root@tera-two ~]#
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
N4ZPO (ham Radio)
- knight-of-ni
Okay, that answers it. You are using a zoneminder rpm from Fedora, rather than the rpm packaged by us.
The package from Fedora does not have ffmpeg or vlc support, which is needed in many cases.
You should completely uninstall the version of ZoneMinder you have.
Once you do that, go here, select Fedora 23 as your distro, and take care to follow the instructions exactly:
http://zmrepo.zoneminder.com/
Don't forget to add "exclude=zoneminder*" to your fedora.repo file so you don't end up with Fedora's rpm again.
Wow,
Thanks! I added the zoneminder repo and assumed all was well because i thought fedora was using an old version like f22 or 21. Guess assuming isn'r the way to go.
In any event thank you very much. It will take a little while but you can bet i'll be back.
Thanks! George....
Thanks! George....
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
N4ZPO (ham Radio)
Just for my own curiosity how can i be certian i have the ZM REPO version of zoneminder?
Sure would hate to do this again!
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
N4ZPO (ham Radio)
- knight-of-ni
Perform another "rpm -qi zoneminder" and compare the differences between this output and what you posted previously.
The Signature is not mine.
The Packager says Fedora, instead of me, Andrew Bauer
The Build Host shows a machine name that is part of Fedora
You're not using the same distro as me, and probably followed different setup instructions, so this might not help you.
I had a similar problem that stemmed from following instructions without thinking. I wrote about it in the Gentoo Zoneminder wiki, cuz those were the wrong instructions I had followed at the time. Copying my text from there ...
The symptoms for me were a) a 404 in apache logs, couldn't find zms or nph_zms;
and b) apparent missing socket in the zonemaster logs.
I read http://httpd.apache.org/docs/2.2/howto/cgi.html, to remind myself how ScriptAlias is supposed to work. In particular, it points to a directory, not to a file.
I made the following changes in my config. In /etc/apache2/vhosts.d/10_zoneminder.conf:
In zm web UI, set
After a restart of zm and apache, I am now able to see streamed images.
HTH, and good luck.
glen
[Tue Oct 27 10:38:55.754977 2015] [cgi:error] [pid 29986] [client 192.168.0.9:54882] AH02811: script not found or unable to stat: /var/www/localhost/cgi-bin/nph-zms, .. blah blah
192.168.0.9 - - [27/Oct/2015:10:38:55 -0700] "GET /cgi-bin/nph-zms?source=event&mode=jpeg&event=5&frame=1&scale=50&rate=100&maxfps=30&replay=single&connkey=313914&rand=1445967535 HTTP/1.1" 404 274
ERR [socket_sendto( /var/run/zm/zms-264615s.sock ) failed: No such file or directory]
# ScriptAlias /cgi-bin/zms "/usr/libexec/zoneminder/cgi-bin/zms"
# ScriptAlias /cgi-bin/nph-zms "/usr/libexec/zoneminder/cgi-bin/nph-zms"
ScriptAlias /zm/cgi-bin/ "/usr/libexec/zoneminder/cgi-bin/"
Options -> Paths -> PATH_ZMS = /zm/cgi-bin/zms
HTH, and good luck.
glen
- Contact:
I have exactly the same issue on an ubuntu install - nothing here seemed to help
Steve
Mines all fixed by upgrading to 1.2.109
Steve
Last edited by stevewrightnz1 on Fri Nov 27, 2015 9:39 pm, edited 1 time in total.
- knight-of-ni
Guys,
The issue here was Fedora silently released their own ZoneMinder 1.28.1 rpm without our knowledge. The problem with that is Fedora will not build ZoneMinder with ffmpeg or vlc support. It is against their policy, apparently. Unfortunately, most modern cameras need ffmpeg or vlc in one form or another to work. Adding ffmpeg and vlc after the fact will not solve the problem. ZoneMinder has to be built with vlc and ffmpeg development libraries pre-installed on the build host.
This means that anyone who installs Fedora's ZoneMinder package will not be able to achieve a working system, unless they are using capture cards or really old mjpeg ip cameras.
The steps to get (our) ZoneMinder working on Fedora our fully documented on the zmrepo site.
This is not a Gentoo problem, nor is is an Ubuntu problem, nor does it relate to any other distro. If you are not using Fedora, then you should look elsewhere.
As you can see, IT WORKS! It was quite an effort but IT WORKS! The editing and switching from one document to the next was tough for me. But quite a lot better than it was working it the first time. The readme was very helpful. I fear though that i must have typo'ed or left out something as i am getting continuous errors. I see 10-20 FPS on 3 cameras. i can only imagine what it will do once this small problem is worked out.
Thank You all Very much for the help. it has been a lifesaver.
I bought a network dvr but it is incompatible with all my cameras if my setup is even right. The poor info on both the cameras and the DVR is scarce. Zoneminder Has it beat hands down..
Thanks again!
george....
Thanks again!
george....
Date/Time
2015-11-27 10:18:07.553904 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:07.518573 zma_m3 3589 INF Driveway: 13327 - Closing event 951, section end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1385
2015-11-27 10:18:07.478202 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:07.409309 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:07.341682 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:07.274514 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:07.166533 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:07.073519 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:06.996906 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:06.930043 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:06.861743 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:06.781356 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:06.709638 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:06.642314 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:06.574745 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:06.506560 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:06.439796 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:06.405616 zma_m3 3589 INF Driveway: 13313 - Opening new event 951, section start /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1405
2015-11-27 10:18:06.371720 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:06.287811 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:06.212005 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:06.180766 zma_m3 3589 INF Driveway: 13313 - Closing event 950, section end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1385
2015-11-27 10:18:06.144555 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:06.074809 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:06.007177 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:05.939698 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:05.872483 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:05.739193 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:05.512297 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:05.443991 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:05.376442 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:05.308354 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:05.240709 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:05.173658 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:05.106196 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:05.022158 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:04.946409 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:04.860589 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:04.827234 zma_m3 3589 INF Driveway: 13298 - Opening new event 950, section start /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1405
2015-11-27 10:18:04.793404 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:04.726763 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:04.658355 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:04.626578 zma_m3 3589 INF Driveway: 13298 - Closing event 949, section end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1385
2015-11-27 10:18:04.589623 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:04.513786 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:04.430626 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:04.396512 zma_m3 3589 INF Driveway: 13296 - Opening new event 949, section start /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1405
2015-11-27 10:18:04.362048 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:04.294514 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:04.227396 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:04.197058 zma_m3 3589 INF Driveway: 13296 - Closing event 948, section end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1385
2015-11-27 10:18:04.164466 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:04.083590 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:03.931473 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:03.797451 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:03.729859 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:03.661944 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:03.659405 zmc_m2 3556 INF Living-Room: 19000 - Capturing at 13.70 fps /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 2907
2015-11-27 10:18:03.629076 zma_m3 3589 INF Driveway: 13291 - Opening new event 948, section start /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1405
2015-11-27 10:18:03.595557 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:03.527933 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:03.451431 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:03.422005 zma_m3 3589 INF Driveway: 13291 - Closing event 947, section end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1385
2015-11-27 10:18:03.384077 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:03.316600 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:03.247736 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:03.180486 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:03.112902 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:03.036961 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:02.971196 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:02.902857 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:02.834818 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:02.771310 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:02.699817 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:02.624007 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:02.514039 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:02.438049 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:02.403910 zma_m3 3589 INF Driveway: 13278 - Opening new event 947, section start /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1405
2015-11-27 10:18:02.362635 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:02.286419 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:02.177475 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:02.046162 zma_m3 3589 INF Driveway: 13278 - Closing event 946, section end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1385
2015-11-27 10:18:01.976468 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:01.800616 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:01.716495 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:01.647483 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:01.580034 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:01.512596 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:01.478693 zma_m3 3589 INF Driveway: 13273 - Opening new event 946, section start /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1405
2015-11-27 10:18:01.444920 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:01.377609 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:01.310454 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:01.279579 zma_m3 3589 INF Driveway: 13273 - Closing event 945, section end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1385
2015-11-27 10:18:01.216371 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:01.108486 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:01.031559 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:00.998395 zma_m3 3589 INF Driveway: 13271 - Opening new event 945, section start /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1405
2015-11-27 10:18:00.963051 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:00.895662 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:00.828220 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:00.797237 zma_m3 3589 INF Driveway: 13271 - Closing event 944, section end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1385
2015-11-27 10:18:00.535747 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:00.459825 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:00.392305 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:00.324229 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:00.256556 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:00.190998 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:00.104724 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:00.070992 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:18:00.027727 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:59.960275 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:59.884427 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:59.808537 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:59.732627 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:59.657606 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:59.623565 zma_m3 3589 INF Driveway: 13259 - Opening new event 944, section start /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1405
2015-11-27 10:17:59.590113 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:59.522398 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:59.454088 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:59.423239 zma_m3 3589 INF Driveway: 13259 - Closing event 943, section end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1385
2015-11-27 10:17:59.386422 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:59.310856 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:59.234614 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:59.200945 zma_m3 3589 INF Driveway: 13257 - Opening new event 943, section start /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1405
2015-11-27 10:17:59.167671 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:59.098937 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:59.031708 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:59.001839 zma_m3 3589 INF Driveway: 13257 - Closing event 942, section end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1385
2015-11-27 10:17:58.963994 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:58.896720 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:58.827556 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:58.786205 zma_m3 3589 INF Driveway: 13255 - Opening new event 942, section start /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1405
2015-11-27 10:17:58.743477 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:58.676030 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:58.612080 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:58.551755 zma_m3 3589 INF Driveway: 13255 - Closing event 941, section end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1385
2015-11-27 10:17:58.507674 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:58.409530 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:58.302115 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:58.199250 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:58.138780 zma_m3 3589 INF Driveway: 13252 - Opening new event 941, section start /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1405
2015-11-27 10:17:58.104325 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:58.037852 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:57.968117 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:57.937887 zma_m3 3589 INF Driveway: 13252 - Closing event 940, section end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1385
2015-11-27 10:17:57.900844 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:57.833490 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:57.765384 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:57.732481 zma_m3 3589 INF Driveway: 13250 - Opening new event 940, section start /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1405
2015-11-27 10:17:57.698026 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:57.630809 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:57.563817 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:57.533355 zma_m3 3589 INF Driveway: 13250 - Closing event 939, section end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1385
2015-11-27 10:17:57.487637 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:57.411796 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:57.302014 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:57.217225 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:57.141385 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:57.107925 zma_m3 3589 INF Driveway: 13246 - Opening new event 939, section start /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1405
2015-11-27 10:17:57.075038 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:57.006559 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:56.939245 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:56.913468 zma_m3 3589 INF Driveway: 13246 - Closing event 938, section end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1385
2015-11-27 10:17:56.839396 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:56.737273 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:56.661824 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:56.584142 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:56.550448 zma_m3 3589 INF Driveway: 13243 - Opening new event 938, section start /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1405
2015-11-27 10:17:56.516626 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:56.448811 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:56.382052 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:56.351518 zma_m3 3589 INF Driveway: 13243 - Closing event 937, section end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1385
2015-11-27 10:17:56.306206 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:56.222047 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:56.129582 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:56.028267 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:55.960877 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:55.893488 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:55.824784 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:55.755250 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:55.464629 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:55.422237 zma_m3 3589 INF Driveway: 13235 - Opening new event 937, section start /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1405
2015-11-27 10:17:55.380695 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:55.312890 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:55.196140 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:55.175094 zma_m3 3589 INF Driveway: 13235 - Closing event 936, section end /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_monitor.cpp 1385
2015-11-27 10:17:55.119193 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:55.051577 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:54.934673 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:54.864868 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:54.788949 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:54.713211 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:54.637599 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:54.569767 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:54.502274 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:54.435118 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:54.365970 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:54.298317 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:54.205806 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
2015-11-27 10:17:54.138160 zmc_dvideo0 3424 ERR Attempt to assign buffer from a NULL pointer /builddir/build/BUILD/ZoneMinder-1.28.1/src/zm_image.cpp 417
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
N4ZPO (ham Radio)
Hmmm... Still not too late to switch to Ubuntu (poke!)
bb
bb
