I made some tweaks, but today purgewhenfull purged all data again.
I have 3Gb of memory, 1,4 grabbed by ZM, other is cached. Maybe ext2 is not so good to keep so many files?
[abishai@zoneminder ~]$ sudo iotop -b |grep rm
22869 be/4 apache 0.00 B/s 0.00 B/s 0.00 % 0.00 % rm -rf 6/15/11/22/00/40/00
22869 be/4 apache 60.82 K/s 98.84 K/s 0.00 % 94.30 % rm -rf 6/15/11/22/00/40/00
22869 be/4 apache 152.86 K/s 217.82 K/s 0.00 % 99.99 % rm -rf 6/15/11/22/00/40/00
22869 be/4 apache 19.15 K/s 61.29 K/s 0.00 % 99.99 % rm -rf 6/15/11/22/00/40/00
22869 be/4 apache 19.18 K/s 65.21 K/s 0.00 % 91.96 % rm -rf 6/15/11/22/00/40/00
22869 be/4 apache 19.06 K/s 49.54 K/s 0.00 % 96.53 % rm -rf 6/15/11/22/00/40/00
22869 be/4 apache 7.70 K/s 19.24 K/s 0.00 % 89.94 % rm -rf 6/15/11/22/00/40/00
22869 be/4 apache 153.92 K/s 519.50 K/s 0.00 % 99.99 % rm -rf 6/15/11/22/00/40/00
22869 be/4 apache 410.19 K/s 846.97 K/s 0.00 % 99.99 % rm -rf 6/15/11/22/00/40/00
22869 be/4 apache 376.58 K/s 664.79 K/s 0.00 % 92.43 % rm -rf 6/15/11/22/00/40/00
22869 be/4 apache 210.99 K/s 333.75 K/s 0.00 % 71.10 % rm -rf 6/15/11/22/00/40/00
22869 be/4 apache 49.93 K/s 76.81 K/s 0.00 % 99.99 % rm -rf 6/15/11/22/00/40/00
22869 be/4 apache 287.96 K/s 453.06 K/s 0.00 % 99.99 % rm -rf 6/15/11/22/00/40/00
You may see how bad is IO (99), basically, this means that server stops at all.
[abishai@zoneminder ~]$ sudo tune2fs -l /dev/vdb
tune2fs 1.42.9 (28-Dec-2013)
Filesystem volume name: <none>
Last mounted on: /var/lib/zoneminder/events
Filesystem UUID: c844bf64-46cb-48c9-855b-4c5af1407556
Filesystem magic number: 0xEF53
Filesystem revision #: 1 (dynamic)
Filesystem features: ext_attr resize_inode dir_index filetype sparse_super large_file
Filesystem flags: signed_directory_hash
Default mount options: user_xattr acl
Filesystem state: not clean
Errors behavior: Continue
Filesystem OS type: Linux
Inode count: 32768000
Block count: 131072000
Reserved block count: 6553600
Free blocks: 114282702
Free inodes: 32474883
First block: 0
Block size: 4096
Fragment size: 4096
Reserved GDT blocks: 992
Blocks per group: 32768
Fragments per group: 32768
Inodes per group: 8192
Inode blocks per group: 512
RAID stride: 2
RAID stripe width: 2
Filesystem created: Thu Nov 19 01:18:38 2015
Last mount time: Sat Nov 21 12:24:15 2015
Last write time: Sat Nov 21 12:24:15 2015
Mount count: 6
Maximum mount count: -1
Last checked: Thu Nov 19 01:18:38 2015
Check interval: 0 (<none>)
Lifetime writes: 658 GB
Reserved blocks uid: 0 (user root)
Reserved blocks gid: 0 (group root)
First inode: 11
Inode size: 256
Required extra isize: 28
Desired extra isize: 28
Default directory hash: half_md4
Directory Hash Seed: 05e08129-d59a-4b74-9aa7-02ad14558c22
