Just noticed that event view is acting funny. Live feeds are ok. Everything works OK through the web interface.
And it doesn't seem to be updating the list of events. Via the web I see 8 recorded events, zmNinja thinks I have 22. I did delete some events earlier this mornig. I did make sure I tried to view an event that still shows up in the web interface and is viewable that way.
Added: after a while the event list updated to match what I see on the web. But for an hour or two they weren't in sync.
event view failing (iPad)
Re: event view failing (iPad)
zmNinja refreshes the list of events every time you switch to a different view and back to events, or simply tap on the refresh icon at the top. If you do either, you should see a new list.
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
