What is the difference between Routers & Switches??????
Which is comfortable for the worthy budget????
Wireless Gadgets
Re: Wireless Gadgets
A router is connected to at least two networks, commonly two LANs or WANs or a LAN and its ISP.s network. Routers are located at gateways, the places where two or more networks connect.
Router used for - Connecting two or more networks
Switch used for - Connecting two or more nodes in the same network or different network
Router - Networking Device
Switch - Active Device (With Software) & Networking device
Router's function - Directs data in a network. Passes data between home computers, and between computers and the modem.
Switch's function - Allow to connect multiple device and port can be manage, Vlan can create security also can apply
In Router - every port has its own Broadcast domain.
In Switch - Switch has one broadcast domain
- Switch
- switch.jpg (5.16 KiB) Viewed 3617 times
- Router
- router.jpg (3.28 KiB) Viewed 3617 times
