Just got Android and OSX installed today.
If I use a browser, I can view the feeds.
If I use ZMNinja, I get camera question marks.
json looks right.
"version": "1.28.109",
"apiversion": "1.28.109.1"
Any ideas?
Can't view feeds
Re: Can't view feeds
please check your cgi-bin path. Its most likely set incorrectly in zmninja
Also useful to enable debug logs in zmninja
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
that's a bingo!
Thanks man. perfect.
I also have the same issue, except I had to fix PATH_ZM by adding /zm/ to get the Web View to work, but in zmNinja, just a question mark.
my PATHS_ZM looks like
/zm/cgi-bin/nph-zms
/zm/cgi-bin/nph-zms
Got it working, figured I would share.. cough cough.
The PATH_ZMS setting inside the Options >> PATH variable inside of ZoneMinder Consol fix viewing stream in WebBrowser but to fix zmNinja I had to manually edit
path to cgi-bin
http://server/zm/cgi-bin/nph-zms
I figured since it literally copied the text I pasted into ZM portal URL it was filling in the information as needed. A nice feature but perhaps it should just add /cgi-bin/nph-zms to whatever is typed for ZM Portal. Anyway one problem down!
path to cgi-bin
Briefly had the same issue here, and for my Centos7 ZM install, the correct ZMninja CGI-BIN path was http://server/zm/cgi-bin-zm/nph-zms
