How do i install VLC lib files?
I have a wanscam NCM625GA and i can open the stream with VLC using (rtsp://user:pwd@192.168.1.80/live/ch1). I have tried many variations of this to setup zoneminder, and have decided i need the VLC lib files to make it work. So i am wondering how to do this.
Thanks!
george....
Thanks!
george....
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
N4ZPO (ham Radio)
- knight-of-ni
Re: How do i install VLC lib files?
Since, from your previous thread, we established that you are using ZoneMinder from zmrepo, there is nothing more you need.
All of zoneminder's dependencies, including/especially the vlc libraries, are already installed on your machine for you, courtesy of zmrepo.
If you need help getting this camera working in zoneminder you need to post:
a) The complete camera configuration
b) relavant log file information
This guy reported success with the same camera:
viewtopic.php?t=23522
Thanks for the reply!
I got the impression i needed to install vlc files from this error. Sorry for the confusion. also I have read and gone by the article you suggested. I think there is a conflict between the text and the boiler plate, where the text says prefix the line with (vlc) and the suggested method is without the (vlc) prefix . Perhaps i am reading it incorrectly.
Upon watching the log file, i see there are plenty of other errors this morning. I have disabled all but 3 cameras that have always worked well. and knocked the frame rate back to 5fps for the 3 cameras.
The computer is an old dell with a 2.8ghz pentium dual core processor. Does the disable select truly unload the processor or should i delete the other cameras all together.
Thanks!
george....
Another set of errors!
Thanks!
george....
2015-12-06 03:07:03.509460 zmdc 5874 ERR 'zma -m 6' exited abnormally, exit status 255 zmdc.pl
2015-12-06 03:07:03.464931 zma_m6 7310 FAT You must have vlc libraries installed to use vlc cameras for monitor 6 zm_monitor.cpp 2705
2015-12-06 03:07:03.406310 zmdc 5874 ERR 'zmc -m 6' exited abnormally, exit status 255 zmdc.pl
2015-12-06 03:07:03.330390 zmdc 7310 INF 'zma -m 6' started at 15/12/06 03:07:03 zmdc.pl
2015-12-06 03:07:03.327810 zmdc 5874 INF 'zma -m 6' starting at 15/12/06 03:07:03, pid = 7310 zmdc.pl
2015-12-06 03:07:03.267339 zmc_m6 7309 FAT You must have vlc libraries installed to use vlc cameras for monitor 6 zm_monitor.cpp 2705
2015-12-06 03:07:03.246850 zmdc 5874 INF Starting pending process, zma -m 6 zmdc.pl
2015-12-06 03:07:03.144230 zmdc 5874 INF 'zmc -m 6' starting at 15/12/06 03:07:03, pid = 7309 zmdc.pl
2015-12-06 03:07:03.142050 zmdc 7309 INF 'zmc -m 6' started at 15/12/06 03:07:03 zmdc.pl
2015-12-06 03:07:03.098360 zmdc 5874 INF Starting pending process, zmc -m 6 zmdc.pl
2015-12-06 03:07:02.264260 zmdc 5874 ERR 'zma -m 5' exited abnormally, exit status 255 zmdc.pl
2015-12-06 03:07:02.227530 zma_m5 7308 FAT You must have vlc libraries installed to use vlc cameras for monitor 5 zm_monitor.cpp 2705
2015-12-06 03:07:02.112550 zmdc 7308 INF 'zma -m 5' started at 15/12/06 03:07:02 zmdc.pl
2015-12-06 03:07:02.109020 zmdc 5874 INF 'zma -m 5' starting at 15/12/06 03:07:02, pid = 7308 zmdc.pl
2015-12-06 03:07:02.058240 zmdc 5874 INF Starting pending process, zma -m 5 zmdc.pl
2015-12-06 03:07:01.211870 zmdc 5874 ERR 'zmc -m 5' exited abnormally, exit status 255 zmdc.pl
2015-12-06 03:07:01.173546 zmc_m5 7302 FAT You must have vlc libraries installed to use vlc cameras for monitor 5 zm_monitor.cpp 2705
2015-12-06 03:07:01.080860 zmdc 7302 INF 'zmc -m 5' started at 15/12/06 03:07:01 zmdc.pl
2015-12-06 03:07:01.074670 zmdc 5874 INF 'zmc -m 5' starting at 15/12/06 03:07:01, pid = 7302 zmdc.pl
2015-12-06 03:07:01.040380 zmdc 5874 INF Starting pending process, zmc -m 5 zmdc.pl
2015-12-06 03:06:59.285060 zmdc 5874 ERR 'zma -m 4' exited abnormally, exit status 255 zmdc.pl
2015-12-06 03:06:59.250157 zma_m4 7298 FAT You must have vlc libraries installed to use vlc cameras for monitor 4 zm_monitor.cpp 2705
2015-12-06 03:06:59.120890 zmdc 7298 INF 'zma -m 4' started at 15/12/06 03:06:59 zmdc.pl
2015-12-06 03:06:59.116840 zmdc 5874 INF 'zma -m 4' starting at 15/12/06 03:06:59, pid = 7298 zmdc.pl
2015-12-06 03:06:59.059420 zmdc 5874 INF Starting pending process, zma -m 4 zmdc.pl
2015-12-06 03:06:58.225900 zmdc 5874 ERR 'zmc -m 4' exited abnormally, exit status 255 zmdc.pl
2015-12-06 03:06:58.193610 zmc_m4 7297 FAT You must have vlc libraries installed to use vlc cameras for monitor 4 zm_monitor.cpp 2705
2015-12-06 03:06:58.111010 zmdc 7297 INF 'zmc -m 4' started at 15/12/06 03:06:58 zmdc.pl
2015-12-06 03:06:58.110990 zmdc 5874 INF 'zmc -m 4' starting at 15/12/06 03:06:58, pid = 7297 zmdc.pl
2015-12-06 03:06:58.060440 zmdc 5874 INF Starting pending process, zmc -m 4 zmdc.pl
2015-12-06 03:06:43.637920 zmdc 5874 ERR 'zma -m 6' exited abnormally, exit status 255 zmdc.pl
2015-12-06 03:06:43.571463 zma_m6 7296 FAT You must have vlc libraries installed to use vlc cameras for monitor 6 zm_monitor.cpp 2705
2015-12-06 03:06:43.447890 zmdc 7296 INF 'zma -m 6' started at 15/12/06 03:06:43 zmdc.pl
2015-12-06 03:06:43.438980 zmdc 5874 INF 'zma -m 6' starting at 15/12/06 03:06:43, pid = 7296 zmdc.pl
2015-12-06 03:06:43.367600 zmdc 5874 ERR 'zmc -m 6' exited abnormally, exit status 255 zmdc.pl
2015-12-06 03:06:43.276680 zmdc 5874 INF Starting pending process, zma -m 6 zmdc.pl
2015-12-06 03:06:43.259676 zmc_m6 7295 FAT You must have vlc libraries installed to use vlc cameras for monitor 6 zm_monitor.cpp 2705
2015-12-06 03:06:43.157770 zmdc 5874 INF 'zmc -m 6' starting at 15/12/06 03:06:43, pid = 7295 zmdc.pl
2015-12-06 03:06:43.155700 zmdc 7295 INF 'zmc -m 6' started at 15/12/06 03:06:43 zmdc.pl
2015-12-06 03:06:43.052960 zmdc 5874 INF Starting pending process, zmc -m 6 zmdc.pl
2015-12-06 03:06:42.285860 zmdc 5874 ERR 'zma -m 5' exited abnormally, exit status 255 zmdc.pl
2015-12-06 03:06:42.245251 zma_m5 7292 FAT You must have vlc libraries installed to use vlc cameras for monitor 5 zm_monitor.cpp 2705
2015-12-06 03:06:42.097780 zmdc 7292 INF 'zma -m 5' started at 15/12/06 03:06:42 zmdc.pl
2015-12-06 03:06:42.095560 zmdc 5874 INF 'zma -m 5' starting at 15/12/06 03:06:42, pid = 7292 zmdc.pl
2015-12-06 03:06:42.026450 zmdc 5874 INF Starting pending process, zma -m 5 zmdc.pl
2015-12-06 03:06:41.291720 zmdc 5874 ERR 'zmc -m 5' exited abnormally, exit status 255 zmdc.pl
2015-12-06 03:06:41.255319 zmc_m5 7234 FAT You must have vlc libraries installed to use vlc cameras for monitor 5 zm_monitor.cpp 2705
2015-12-06 03:06:41.134220 zmdc 7234 INF 'zmc -m 5' started at 15/12/06 03:06:41 zmdc.pl
2015-12-06 03:06:41.127010 zmdc 5874 INF 'zmc -m 5' starting at 15/12/06 03:06:41, pid = 7234 zmdc.pl
2015-12-06 03:06:41.090840 zmdc 5874 INF Starting pending process, zmc -m 5 zmdc.pl
2015-12-06 03:06:40.855770 zmaudit 6986 INF Deleted 99 log table entries by time zmaudit.pl
2015-12-06 03:06:39.454690 zmwatch 7077 INF Watchdog pausing for 30 seconds zmwatch.pl
2015-12-06 03:06:39.266830 zmwatch 7077 INF Watchdog starting zmwatch.pl
2015-12-06 03:06:39.051910 zmdc 5874 ERR 'zma -m 4' exited abnormally, exit status 255 zmdc.pl
2015-12-06 03:06:38.987620 zma_m4 7102 FAT You must have vlc libraries installed to use vlc cameras for monitor 4 zm_monitor.cpp 2705
2015-12-06 03:06:38.595590 zmdc 5874 ERR 'zmc -m 4' exited abnormally, exit status 255 zmdc.pl
2015-12-06 03:06:38.541770 zmc_m4 7094 FAT You must have vlc libraries installed to use vlc cameras for monitor 4 zm_monitor.cpp 2705
2015-12-06 03:06:38.373890 zmdc 7102 INF 'zma -m 4' started at 15/12/06 03:06:38 zmdc.pl
2015-12-06 03:06:38.353870 zmdc 5874 INF 'zma -m 4' starting at 15/12/06 03:06:38, pid = 7102 zmdc.pl
2015-12-06 03:06:38.271480 zmdc 5874 INF Starting pending process, zma -m 4 zmdc.pl
2015-12-06 03:06:38.129970 zmdc 7094 INF 'zmc -m 4' started at 15/12/06 03:06:38 zmdc.pl
2015-12-06 03:06:38.129610 zmdc 5874 INF 'zmc -m 4' starting at 15/12/06 03:06:38, pid = 7094 zmdc.pl
2015-12-06 03:06:38.055470 zmdc 5874 INF Starting pending process, zmc -m 4 zmdc.pl
2015-12-06 03:06:37.736860 zmdc 7077 INF 'zmwatch.pl' started at 15/12/06 03:06:37 zmdc.pl
2015-12-06 03:06:37.726850 zmdc 5874 INF 'zmwatch.pl' starting at 15/12/06 03:06:37, pid = 7077 zmdc.pl
2015-12-06 03:06:37.694570 zmfilter 6905 INF Scanning for events zmfilter.pl
2015-12-06 03:06:34.617830 zmdc 5874 INF 'zmaudit.pl -c' starting at 15/12/06 03:06:34, pid = 6986 zmdc.pl
2015-12-06 03:06:34.609140 zmdc 6986 INF 'zmaudit.pl -c' started at 15/12/06 03:06:34 zmdc.pl
2015-12-06 03:06:33.256980 zmdc 5874 ERR 'zmc -m 6' exited abnormally, exit status 255 zmdc.pl
2015-12-06 03:06:33.202358 zmc_m6 6929 FAT You must have vlc libraries installed to use vlc cameras for monitor 6 zm_monitor.cpp 2705
2015-12-06 03:06:33.095520 zmdc 5874 ERR 'zma -m 6' exited abnormally, exit status 255 zmdc.pl
2015-12-06 03:06:33.054477 zma_m6 6924 FAT You must have vlc libraries installed to use vlc cameras for monitor 6 zm_monitor.cpp 2705
2015-12-06 03:06:32.926910 zmdc 6929 INF 'zmc -m 6' started at 15/12/06 03:06:32 zmdc.pl
2015-12-06 03:06:32.850900 zmdc 5874 INF 'zmc -m 6' starting at 15/12/06 03:06:32, pid = 6929 zmdc.pl
2015-12-06 03:06:32.760150 zmdc 5874 INF Starting pending process, zmc -m 6 zmdc.pl
2015-12-06 03:06:32.746050 zmdc 6924 INF 'zma -m 6' started at 15/12/06 03:06:32 zmdc.pl
2015-12-06 03:06:32.691000 zmdc 5874 INF 'zma -m 6' starting at 15/12/06 03:06:32, pid = 6924 zmdc.pl
2015-12-06 03:06:32.614060 zmdc 5874 ERR 'zma -m 5' exited abnormally, exit status 255 zmdc.pl
2015-12-06 03:06:32.467760 zmdc 5874 INF Starting pending process, zma -m 6 zmdc.pl
2015-12-06 03:06:32.360401 zma_m5 6898 FAT You must have vlc libraries installed to use vlc cameras for monitor 5 zm_monitor.cpp 2705
2015-12-06 03:06:32.303590 zmdc 6905 INF 'zmfilter.pl' started at 15/12/06 03:06:32 zmdc.pl
2015-12-06 03:06:32.298000 zmdc 5874 INF 'zmfilter.pl' starting at 15/12/06 03:06:32, pid = 6905 zmdc.pl
2015-12-06 03:06:32.210383 zma_m7 6889 INF In mode 5/0, warming up zma.cpp 105
2015-12-06 03:06:32.168050 zmdc 6898 INF 'zma -m 5' started at 15/12/06 03:06:32 zmdc.pl
2015-12-06 03:06:32.152750 zmdc 5874 INF 'zma -m 5' starting at 15/12/06 03:06:32, pid = 6898 zmdc.pl
2015-12-06 03:06:32.063760 zmdc 5874 INF Starting pending process, zma -m 5 zmdc.pl
2015-12-06 03:06:31.982060 zmdc 6889 INF 'zma -m 7' started at 15/12/06 03:06:31 zmdc.pl
2015-12-06 03:06:31.975060 zmdc 5874 INF 'zma -m 7' starting at 15/12/06 03:06:31, pid = 6889 zmdc.pl
2015-12-06 03:06:31.011530 zmdc 5874 ERR 'zmc -m 5' exited abnormally, exit status 255 zmdc.pl
2015-12-06 03:06:30.654681 zmc_dvideo0 6712 WAR Hue control is not supported zm_local_camera.cpp 1757
2015-12-06 03:06:30.287070 zmdc 5874 INF Starting pending process, zma -m 7 zmdc.pl
2015-12-06 03:06:29.954092 zmc_dvideo0 6712 INF Starting Capture zmc.cpp 195
2015-12-06 03:06:29.739847 zmc_m5 6741 FAT You must have vlc libraries installed to use vlc cameras for monitor 5 zm_monitor.cpp 2705
2015-12-06 03:06:29.694430 zmdc 5874 ERR 'zma -m 7' exited abnormally, exit status 255 zmdc.pl
2015-12-06 03:06:29.167210 zmdc 6741 INF 'zmc -m 5' started at 15/12/06 03:06:29 zmdc.pl
2015-12-06 03:06:29.136980 zmdc 5874 INF 'zmc -m 5' starting at 15/12/06 03:06:29, pid = 6741 zmdc.pl
2015-12-06 03:06:29.042522 zma_m7 6722 ERR Shared data not initialised by capture daemon for monitor MYDESK zm_monitor.cpp 421
2015-12-06 03:06:29.000470 zmdc 5874 INF Starting pending process, zmc -m 5 zmdc.pl
2015-12-06 03:06:28.843528 zmc_dvideo0 6712 INF No direct match for the selected palette and target colorspace. Format conversion is required, performance penalty expected zm_local_camera.cpp 409
2015-12-06 03:06:28.824160 zmdc 6722 INF 'zma -m 7' started at 15/12/06 03:06:28 zmdc.pl
2015-12-06 03:06:28.809090 zmdc 5874 INF 'zma -m 7' starting at 15/12/06 03:06:28, pid = 6722 zmdc.pl
2015-12-06 03:11:27.073390 zmwatch 7077 ERR Memory map file '/dev/shm/zm.mmap.6' does not exist. zmc might not be running. zmwatch.pl
2015-12-06 03:11:27.039880 zmwatch 7077 ERR Memory map file '/dev/shm/zm.mmap.6' does not exist. zmc might not be running. zmwatch.pl
2015-12-06 03:11:26.981100 zmwatch 7077 ERR Memory map file '/dev/shm/zm.mmap.5' does not exist. zmc might not be running. zmwatch.pl
2015-12-06 03:11:26.939180 zmwatch 7077 ERR Memory map file '/dev/shm/zm.mmap.5' does not exist. zmc might not be running. zmwatch.pl
2015-12-06 03:11:26.888550 zmwatch 7077 ERR Memory map file '/dev/shm/zm.mmap.4' does not exist. zmc might not be running. zmwatch.pl
2015-12-06 03:11:26.848590 zmwatch 7077 ERR Memory map file '/dev/shm/zm.mmap.4' does not exist. zmc might not be running. zmwatch.pl
2015-12-06 03:11:16.804430 zmwatch 7077 ERR Memory map file '/dev/shm/zm.mmap.6' does not exist. zmc might not be running. zmwatch.pl
2015-12-06 03:11:16.770750 zmwatch 7077 ERR Memory map file '/dev/shm/zm.mmap.6' does not exist. zmc might not be running. zmwatch.pl
2015-12-06 03:11:16.722970 zmwatch 7077 ERR Memory map file '/dev/shm/zm.mmap.5' does not exist. zmc might not be running. zmwatch.pl
2015-12-06 03:11:16.686720 zmwatch 7077 ERR Memory map file '/dev/shm/zm.mmap.5' does not exist. zmc might not be running. zmwatch.pl
2015-12-06 03:11:16.636570 zmwatch 7077 ERR Memory map file '/dev/shm/zm.mmap.4' does not exist. zmc might not be running. zmwatch.pl
2015-12-06 03:11:16.572290 zmwatch 7077 ERR Memory map file '/dev/shm/zm.mmap.4' does not exist. zmc might not be running. zmwatch.pl
2015-12-06 03:11:08.080420 zmfilter 6905 INF Deleting event 10007 zmfilter.pl
2015-12-06 03:11:08.013140 zmfilter 6905 INF Deleting event 10006 zmfilter.pl
2015-12-06 03:11:07.946130 zmfilter 6905 INF Deleting event 10005 zmfilter.pl
2015-12-06 03:11:07.862140 zmfilter 6905 INF Deleting event 10004 zmfilter.pl
2015-12-06 03:11:07.786790 zmfilter 6905 INF Deleting event 10003 zmfilter.pl
2015-12-06 03:11:07.695990 zmfilter 6905 INF Deleting event 10002 zmfilter.pl
2015-12-06 03:11:07.626990 zmfilter 6905 INF Deleting event 10001 zmfilter.pl
2015-12-06 03:11:07.526420 zmfilter 6905 INF Deleting event 10000 zmfilter.pl
2015-12-06 03:11:07.414650 zmfilter 6905 INF Deleting event 9999 zmfilter.pl
2015-12-06 03:11:07.333730 zmfilter 6905 INF Deleting event 9998 zmfilter.pl
2015-12-06 03:11:07.220630 zmfilter 6905 INF Deleting event 9997 zmfilter.pl
2015-12-06 03:11:07.149140 zmfilter 6905 INF Deleting event 9996 zmfilter.pl
2015-12-06 03:11:07.056900 zmfilter 6905 INF Deleting event 9995
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
N4ZPO (ham Radio)
- knight-of-ni
Sounds like you are not using the rpm from zmrepo.2015-12-06 03:07:03.464931 zma_m6 7310 FAT You must have vlc libraries installed to use vlc cameras for monitor 6 zm_monitor.cpp 2705
Post the complete output of:
rpm -qi zoneminder
rpm -qa |grep vlc
thanks for the reply, Here is the info requested.
Thanks for the help, it is much appriceated..
george....
[root@tera-two ~]# rpm -qi zoneminder
Version : 1.28.1
Release : 4.fc23
Architecture: x86_64
Install Date: Sat 28 Nov 2015 06:52:39 AM EST
Group : System Environment/Daemons
License : GPLv2+ and LGPLv2+ and MIT
Signature : RSA/SHA256, Tue 23 Jun 2015 05:03:32 PM EDT, Key ID 32474cf834ec9cba
Source RPM : zoneminder-1.28.1-4.fc23.src.rpm
Build Date : Fri 19 Jun 2015 01:46:29 AM EDT
Build Host : buildhw-11.phx2.fedoraproject.org
Relocations : (not relocatable)
Packager : Fedora Project
Vendor : Fedora Project
URL : http://www.zoneminder.com/
Summary : A camera monitoring and analysis tool
Description :
ZoneMinder is a set of applications which is intended to provide a complete
solution allowing you to capture, analyse, record and monitor any cameras you
have attached to a Linux based machine. It is designed to run on kernels which
support the Video For Linux (V4L) interface and has been tested with cameras
attached to BTTV cards, various USB cameras and IP network cameras. It is
designed to support as many cameras as you can attach to your computer without
too much degradation of performance.
[root@tera-two ~]#
[root@tera-two ~]# rpm -qa |grep vlc
npapi-vlc-gtk-2.2.0-0.1.fc22.x86_64
vlc-2.2.2-0.1.fc23.x86_64
npapi-vlc-filesystem-2.2.0-0.1.fc22.x86_64
vlc-core-2.2.2-0.1.fc23.x86_64
[root@tera-two ~]#
george....
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
N4ZPO (ham Radio)
- knight-of-ni
As one can see from the first output you provided, the name of the Packager is Fedora Project, and not me, Andrew Bauer.
You are, again, using the wrong zoneminder package.
You will never get vlc or ffmpeg support to work with that rpm because vlc and ffmpeg support were not built into it.
Referring back to the previous thread you created, you need to, again, completely uninstall ZoneMinder. Next, go to zmrepo.zoneminder.com and follow the instructions on the site. You need to especially follow the note about putting an "exclude" statement into your fedora.repo file. Otherwise, you will end up with the wrong zoneminder package on your system yet again.
I was under the impression i had done so, However i see that it hasn't been done correctly. Thank you very much for your time and effort it is greatly appriceated.
I think i will just disable the fedora repo all together while re installing the proper package. I am certian parts of it were from the zoneminder repo as i watched the install carefully and saw the repository pop up a time or too. But, that is neither here nor there as you have proven it didn't go as i thought.
Thanks Again!
george....
Thanks Again!
george....
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
N4ZPO (ham Radio)
- knight-of-ni
I would not disable the Fedora repo entirely. That could cause other problems.
You need to exclude the zoneminder package specifically as described on the zmrepo site.
In other words, you need to edit the file /etc/yum.repos.d/fedora.repo and add an exclude line to the first block just like this:
See that last line? You need to add that to yours.
[fedora]
name=Fedora $releasever - $basearch
failovermethod=priority
#baseurl=http://download.fedoraproject.org/pub/fedora/linux/releases/$releasever/Everything/$basearch/os/
metalink=https://mirrors.fedoraproject.org/metalink?repo=fedora-$releasever&arch=$basearch
enabled=1
metadata_expire=28d
gpgcheck=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-fedora-$releasever-$basearch
skip_if_unavailable=False
exclude=zoneminder*
This is what i am running into. Not sure how to fix it. Also i found that i had put the exclude line in the fedora repo file, but, it was not adjacent to the first block. Perhaps that was the difference.
[root@tera-two /]# yum install zoneminder
Yum command has been deprecated, redirecting to '/usr/bin/dnf install zoneminder'.
See 'man dnf' and 'man yum2dnf' for more information.
To transfer transaction metadata from yum to DNF, run:
'dnf install python-dnf-plugins-extras-migrate && dnf-2 migrate'
Failed to synchronize cache for repo 'zmrepo' from 'http://zmrepo.mehvc.com/f/23/x86_64;http://zmrepo.connortechnology.com/f/23/x86_64': repomd.xml parser error: Element <repomd> was not found - Bad repomd file, disabling.
Failed to synchronize cache for repo 'zmrepo-source' from 'http://zmrepo.mehvc.com/f/23/SRPMS;http://zmrepo.connortechnology.com/f/23/SRPMS': repomd.xml parser error: Element <repomd> was not found - Bad repomd file, disabling.
Last metadata expiration check performed 2:57:33 ago on Sun Dec 6 12:59:35 2015.
No package zoneminder available.
Error: Unable to find a match.
[root@tera-two /]#
[root@tera-two /]#
[root@tera-two /]# dnf install zoneminder
Last metadata expiration check performed 2:58:54 ago on Sun Dec 6 12:59:35 2015.
[root@tera-two /]#
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
N4ZPO (ham Radio)
- knight-of-ni
Try "yum install zoneminder" again.
Here are the results of the last try. I also tried with all but the zm repo excluded. the results were identical save the update.
Thanks!
george....
Thanks!
george....
[root@tera-two ~]# yum install zoneminder
Fedora 23 - x86_64 - Updates 2.5 MB/s | 10 MB 00:04
Last metadata expiration check performed 0:00:12 ago on Mon Dec 7 01:37:12 2015.
[root@tera-two ~]#
[root@tera-two ~]#
[root@tera-two ~]# dnf install zoneminder
[root@tera-two ~]#
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
N4ZPO (ham Radio)
- knight-of-ni
I was able to duplicate the problem, yesterday. There was an issue with one of our mirror servers. Not all the files rsynced to the server properly. I have fixed the issue and it is working fine now for me anyway.
Clear your cache and try again:
The old yum tool is still on your system. It has just been renamed.
You could try this if dnf is still not working right:
yum clean all
yum-deprecated clean all
yum-deprecated install zoneminder
I tried both and added a dnf as well, looks like yum is still here.
Thanks!
george....
Thanks!
george....
[root@tera-two ~]# yum clean all
Yum command has been deprecated, redirecting to '/usr/bin/dnf clean all'.
Cleaning repos: updates rpmfusion-free zmrepo-source zmrepo fedora
: rpmfusion-free-updates
Cleaning up Everything
Fedora 23 - x86_64 5.8 MB/s | 43 MB 00:07
Fedora 23 - x86_64 - Updates 5.4 MB/s | 10 MB 00:01
RPM Fusion for Fedora 23 - Free - Updates 1.0 MB/s | 318 kB 00:00
RPM Fusion for Fedora 23 - Free 914 kB/s | 738 kB 00:00
Last metadata expiration check performed 0:00:01 ago on Mon Dec 7 08:39:28 2015.
[root@tera-two ~]# yum-deprecated clean all
bash: yum-deprecated: command not found...
Install package 'yum' to provide command 'yum-deprecated'? [N/y] n
[root@tera-two ~]#
[root@tera-two ~]# dnf clean all
Cleaning repos: rpmfusion-free zmrepo-source rpmfusion-free-updates zmrepo
: fedora updates
Fedora 23 - x86_64 - Updates 1.9 MB/s | 10 MB 00:05
Fedora 23 - x86_64 4.5 MB/s | 43 MB 00:09
RPM Fusion for Fedora 23 - Free 906 kB/s | 738 kB 00:00
Last metadata expiration check performed 0:00:01 ago on Mon Dec 7 08:46:35 2015.
[root@tera-two ~]#
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
N4ZPO (ham Radio)
- knight-of-ni
zmrepo-source should not be enabled, which implies you've been making changes to the repo files.Failed to synchronize cache for repo 'zmrepo-source' from 'http://zmrepo.mehvc.com/f/23/SRPMS;http ... f/23/SRPMS': repomd.xml parser error: Element <repomd> was not found - Bad repomd file, disabling.
Try:
- uninstall zmrepo
- delete all files under /etc/yum.repos.d with the word "zmrepo" in it
- re-download the zmrepo rpm for Fedora 23
- install it
- yum install zoneminder
You do not need to modify the zmrepo repo files in any way.
B I N G O
Looks like that did it I got a bunch of perl stuff and zoneminder. hope it came from the right place.
Not so quick, have a look at this!
Installed:
cambozola.noarch 0.93-3.fc23
perl-Algorithm-Diff.noarch 1.1903-3.fc23
perl-Archive-Tar.noarch 2.04-347.fc23
perl-Archive-Zip.noarch 1.49-1.fc23
perl-Convert-BinHex.noarch 1.124-1.fc23
perl-Date-Manip.noarch 6.51-1.fc23
perl-Email-Date-Format.noarch 1.005-3.fc23
perl-IO-Zlib.noarch 1:1.10-349.fc23
perl-Locale-Maketext-Simple.noarch 1:0.21-349.fc23
perl-MIME-Lite.noarch 3.030-5.fc23
perl-MIME-Types.noarch 2.11-1.fc23
perl-MIME-tools.noarch 5.506-3.fc23
perl-MailTools.noarch 2.14-3.fc23
perl-Module-CoreList.noarch 1:5.20151120-1.fc23
perl-Module-Load-Conditional.noarch 0.64-346.fc23
perl-Module-Metadata.noarch 1.000027-3.fc23
perl-Net-SMTP-SSL.noarch 1.03-1.fc23
perl-Params-Check.noarch 1:0.38-346.fc23
perl-Sys-Mmap.x86_64 0.17-3.fc23
perl-Sys-Syslog.x86_64 0.33-347.fc23
perl-Text-Diff.noarch 1.43-1.fc23
perl-URI-Encode.noarch 0.09-3.fc23
perl-version.x86_64 5:0.99.12-4.fc23
zoneminder.x86_64 1.28.1-1.fc23
Complete!
[root@tera-two yum.repos.d]#
[root@tera-two yum.repos.d]# cd /
[root@tera-two /]# systemctl start zoneminder.service
Job for zoneminder.service failed because the control process exited with error code. See "systemctl status zoneminder.service" and "journalctl -xe" for details.
[root@tera-two /]#
[root@tera-two /]#
[root@tera-two /]#
[root@tera-two /]#
[root@tera-two /]#
[root@tera-two /]#
[root@tera-two /]# rpm -gi zoneminder
error: open of zoneminder failed: No such file or directory
[root@tera-two /]#
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
N4ZPO (ham Radio)
