How do i install VLC lib files?
teraquad
Post by teraquad »
I have a wanscam NCM625GA and i can open the stream with VLC using (rtsp://user:pwd@192.168.1.80/live/ch1). I have tried many variations of this to setup zoneminder, and have decided i need the VLC lib files to make it work. So i am wondering how to do this.
Thanks!
george....
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
Re: How do i install VLC lib files?
Since, from your previous thread, we established that you are using ZoneMinder from zmrepo, there is nothing more you need.
All of zoneminder's dependencies, including/especially the vlc libraries, are already installed on your machine for you, courtesy of zmrepo.
If you need help getting this camera working in zoneminder you need to post:
a) The complete camera configuration
b) relavant log file information
This guy reported success with the same camera:
viewtopic.php?t=23522
teraquad
Post by teraquad »
Thanks for the reply!
I got the impression i needed to install vlc files from this error. Sorry for the confusion. also I have read and gone by the article you suggested. I think there is a conflict between the text and the boiler plate, where the text says prefix the line with (vlc) and the suggested method is without the (vlc) prefix . Perhaps i am reading it incorrectly.
Upon watching the log file, i see there are plenty of other errors this morning. I have disabled all but 3 cameras that have always worked well. and knocked the frame rate back to 5fps for the 3 cameras.
The computer is an old dell with a 2.8ghz pentium dual core processor. Does the disable select truly unload the processor or should i delete the other cameras all together.
Thanks!
george....
 2015-12-06 03:07:03.509460	zmdc	5874	ERR	'zma -m 6' exited abnormally, exit status 255	zmdc.pl
2015-12-06 03:07:03.464931	zma_m6	7310	FAT	You must have vlc libraries installed to use vlc cameras for monitor 6	zm_monitor.cpp	2705
2015-12-06 03:07:03.406310	zmdc	5874	ERR	'zmc -m 6' exited abnormally, exit status 255	zmdc.pl
2015-12-06 03:07:03.330390	zmdc	7310	INF	'zma -m 6' started at 15/12/06 03:07:03	zmdc.pl
2015-12-06 03:07:03.327810	zmdc	5874	INF	'zma -m 6' starting at 15/12/06 03:07:03, pid = 7310	zmdc.pl
2015-12-06 03:07:03.267339	zmc_m6	7309	FAT	You must have vlc libraries installed to use vlc cameras for monitor 6	zm_monitor.cpp	2705
2015-12-06 03:07:03.246850	zmdc	5874	INF	Starting pending process, zma -m 6	zmdc.pl
2015-12-06 03:07:03.144230	zmdc	5874	INF	'zmc -m 6' starting at 15/12/06 03:07:03, pid = 7309	zmdc.pl
2015-12-06 03:07:03.142050	zmdc	7309	INF	'zmc -m 6' started at 15/12/06 03:07:03	zmdc.pl
2015-12-06 03:07:03.098360	zmdc	5874	INF	Starting pending process, zmc -m 6	zmdc.pl
2015-12-06 03:07:02.264260	zmdc	5874	ERR	'zma -m 5' exited abnormally, exit status 255	zmdc.pl
2015-12-06 03:07:02.227530	zma_m5	7308	FAT	You must have vlc libraries installed to use vlc cameras for monitor 5	zm_monitor.cpp	2705
2015-12-06 03:07:02.112550	zmdc	7308	INF	'zma -m 5' started at 15/12/06 03:07:02	zmdc.pl
2015-12-06 03:07:02.109020	zmdc	5874	INF	'zma -m 5' starting at 15/12/06 03:07:02, pid = 7308	zmdc.pl
2015-12-06 03:07:02.058240	zmdc	5874	INF	Starting pending process, zma -m 5	zmdc.pl
2015-12-06 03:07:01.211870	zmdc	5874	ERR	'zmc -m 5' exited abnormally, exit status 255	zmdc.pl
2015-12-06 03:07:01.173546	zmc_m5	7302	FAT	You must have vlc libraries installed to use vlc cameras for monitor 5	zm_monitor.cpp	2705
2015-12-06 03:07:01.080860	zmdc	7302	INF	'zmc -m 5' started at 15/12/06 03:07:01	zmdc.pl
2015-12-06 03:07:01.074670	zmdc	5874	INF	'zmc -m 5' starting at 15/12/06 03:07:01, pid = 7302	zmdc.pl
2015-12-06 03:07:01.040380	zmdc	5874	INF	Starting pending process, zmc -m 5	zmdc.pl
2015-12-06 03:06:59.285060	zmdc	5874	ERR	'zma -m 4' exited abnormally, exit status 255	zmdc.pl
2015-12-06 03:06:59.250157	zma_m4	7298	FAT	You must have vlc libraries installed to use vlc cameras for monitor 4	zm_monitor.cpp	2705
2015-12-06 03:06:59.120890	zmdc	7298	INF	'zma -m 4' started at 15/12/06 03:06:59	zmdc.pl
2015-12-06 03:06:59.116840	zmdc	5874	INF	'zma -m 4' starting at 15/12/06 03:06:59, pid = 7298	zmdc.pl
2015-12-06 03:06:59.059420	zmdc	5874	INF	Starting pending process, zma -m 4	zmdc.pl
2015-12-06 03:06:58.225900	zmdc	5874	ERR	'zmc -m 4' exited abnormally, exit status 255	zmdc.pl
2015-12-06 03:06:58.193610	zmc_m4	7297	FAT	You must have vlc libraries installed to use vlc cameras for monitor 4	zm_monitor.cpp	2705
2015-12-06 03:06:58.111010	zmdc	7297	INF	'zmc -m 4' started at 15/12/06 03:06:58	zmdc.pl
2015-12-06 03:06:58.110990	zmdc	5874	INF	'zmc -m 4' starting at 15/12/06 03:06:58, pid = 7297	zmdc.pl
2015-12-06 03:06:58.060440	zmdc	5874	INF	Starting pending process, zmc -m 4	zmdc.pl
2015-12-06 03:06:43.637920	zmdc	5874	ERR	'zma -m 6' exited abnormally, exit status 255	zmdc.pl
2015-12-06 03:06:43.571463	zma_m6	7296	FAT	You must have vlc libraries installed to use vlc cameras for monitor 6	zm_monitor.cpp	2705
2015-12-06 03:06:43.447890	zmdc	7296	INF	'zma -m 6' started at 15/12/06 03:06:43	zmdc.pl
2015-12-06 03:06:43.438980	zmdc	5874	INF	'zma -m 6' starting at 15/12/06 03:06:43, pid = 7296	zmdc.pl
2015-12-06 03:06:43.367600	zmdc	5874	ERR	'zmc -m 6' exited abnormally, exit status 255	zmdc.pl
2015-12-06 03:06:43.276680	zmdc	5874	INF	Starting pending process, zma -m 6	zmdc.pl
2015-12-06 03:06:43.259676	zmc_m6	7295	FAT	You must have vlc libraries installed to use vlc cameras for monitor 6	zm_monitor.cpp	2705
2015-12-06 03:06:43.157770	zmdc	5874	INF	'zmc -m 6' starting at 15/12/06 03:06:43, pid = 7295	zmdc.pl
2015-12-06 03:06:43.155700	zmdc	7295	INF	'zmc -m 6' started at 15/12/06 03:06:43	zmdc.pl
2015-12-06 03:06:43.052960	zmdc	5874	INF	Starting pending process, zmc -m 6	zmdc.pl
2015-12-06 03:06:42.285860	zmdc	5874	ERR	'zma -m 5' exited abnormally, exit status 255	zmdc.pl
2015-12-06 03:06:42.245251	zma_m5	7292	FAT	You must have vlc libraries installed to use vlc cameras for monitor 5	zm_monitor.cpp	2705
2015-12-06 03:06:42.097780	zmdc	7292	INF	'zma -m 5' started at 15/12/06 03:06:42	zmdc.pl
2015-12-06 03:06:42.095560	zmdc	5874	INF	'zma -m 5' starting at 15/12/06 03:06:42, pid = 7292	zmdc.pl
2015-12-06 03:06:42.026450	zmdc	5874	INF	Starting pending process, zma -m 5	zmdc.pl
2015-12-06 03:06:41.291720	zmdc	5874	ERR	'zmc -m 5' exited abnormally, exit status 255	zmdc.pl
2015-12-06 03:06:41.255319	zmc_m5	7234	FAT	You must have vlc libraries installed to use vlc cameras for monitor 5	zm_monitor.cpp	2705
2015-12-06 03:06:41.134220	zmdc	7234	INF	'zmc -m 5' started at 15/12/06 03:06:41	zmdc.pl
2015-12-06 03:06:41.127010	zmdc	5874	INF	'zmc -m 5' starting at 15/12/06 03:06:41, pid = 7234	zmdc.pl
2015-12-06 03:06:41.090840	zmdc	5874	INF	Starting pending process, zmc -m 5	zmdc.pl
2015-12-06 03:06:40.855770	zmaudit	6986	INF	Deleted 99 log table entries by time	zmaudit.pl
2015-12-06 03:06:39.454690	zmwatch	7077	INF	Watchdog pausing for 30 seconds	zmwatch.pl
2015-12-06 03:06:39.266830	zmwatch	7077	INF	Watchdog starting	zmwatch.pl
2015-12-06 03:06:39.051910	zmdc	5874	ERR	'zma -m 4' exited abnormally, exit status 255	zmdc.pl
2015-12-06 03:06:38.987620	zma_m4	7102	FAT	You must have vlc libraries installed to use vlc cameras for monitor 4	zm_monitor.cpp	2705
2015-12-06 03:06:38.595590	zmdc	5874	ERR	'zmc -m 4' exited abnormally, exit status 255	zmdc.pl
2015-12-06 03:06:38.541770	zmc_m4	7094	FAT	You must have vlc libraries installed to use vlc cameras for monitor 4	zm_monitor.cpp	2705
2015-12-06 03:06:38.373890	zmdc	7102	INF	'zma -m 4' started at 15/12/06 03:06:38	zmdc.pl
2015-12-06 03:06:38.353870	zmdc	5874	INF	'zma -m 4' starting at 15/12/06 03:06:38, pid = 7102	zmdc.pl
2015-12-06 03:06:38.271480	zmdc	5874	INF	Starting pending process, zma -m 4	zmdc.pl
2015-12-06 03:06:38.129970	zmdc	7094	INF	'zmc -m 4' started at 15/12/06 03:06:38	zmdc.pl
2015-12-06 03:06:38.129610	zmdc	5874	INF	'zmc -m 4' starting at 15/12/06 03:06:38, pid = 7094	zmdc.pl
2015-12-06 03:06:38.055470	zmdc	5874	INF	Starting pending process, zmc -m 4	zmdc.pl
2015-12-06 03:06:37.736860	zmdc	7077	INF	'zmwatch.pl' started at 15/12/06 03:06:37	zmdc.pl
2015-12-06 03:06:37.726850	zmdc	5874	INF	'zmwatch.pl' starting at 15/12/06 03:06:37, pid = 7077	zmdc.pl
2015-12-06 03:06:37.694570	zmfilter	6905	INF	Scanning for events	zmfilter.pl
2015-12-06 03:06:34.617830	zmdc	5874	INF	'zmaudit.pl -c' starting at 15/12/06 03:06:34, pid = 6986	zmdc.pl
2015-12-06 03:06:34.609140	zmdc	6986	INF	'zmaudit.pl -c' started at 15/12/06 03:06:34	zmdc.pl
2015-12-06 03:06:33.256980	zmdc	5874	ERR	'zmc -m 6' exited abnormally, exit status 255	zmdc.pl
2015-12-06 03:06:33.202358	zmc_m6	6929	FAT	You must have vlc libraries installed to use vlc cameras for monitor 6	zm_monitor.cpp	2705
2015-12-06 03:06:33.095520	zmdc	5874	ERR	'zma -m 6' exited abnormally, exit status 255	zmdc.pl
2015-12-06 03:06:33.054477	zma_m6	6924	FAT	You must have vlc libraries installed to use vlc cameras for monitor 6	zm_monitor.cpp	2705
2015-12-06 03:06:32.926910	zmdc	6929	INF	'zmc -m 6' started at 15/12/06 03:06:32	zmdc.pl
2015-12-06 03:06:32.850900	zmdc	5874	INF	'zmc -m 6' starting at 15/12/06 03:06:32, pid = 6929	zmdc.pl
2015-12-06 03:06:32.760150	zmdc	5874	INF	Starting pending process, zmc -m 6	zmdc.pl
2015-12-06 03:06:32.746050	zmdc	6924	INF	'zma -m 6' started at 15/12/06 03:06:32	zmdc.pl
2015-12-06 03:06:32.691000	zmdc	5874	INF	'zma -m 6' starting at 15/12/06 03:06:32, pid = 6924	zmdc.pl
2015-12-06 03:06:32.614060	zmdc	5874	ERR	'zma -m 5' exited abnormally, exit status 255	zmdc.pl
2015-12-06 03:06:32.467760	zmdc	5874	INF	Starting pending process, zma -m 6	zmdc.pl
2015-12-06 03:06:32.360401	zma_m5	6898	FAT	You must have vlc libraries installed to use vlc cameras for monitor 5	zm_monitor.cpp	2705
2015-12-06 03:06:32.303590	zmdc	6905	INF	'zmfilter.pl' started at 15/12/06 03:06:32	zmdc.pl
2015-12-06 03:06:32.298000	zmdc	5874	INF	'zmfilter.pl' starting at 15/12/06 03:06:32, pid = 6905	zmdc.pl
2015-12-06 03:06:32.210383	zma_m7	6889	INF	In mode 5/0, warming up	zma.cpp	105
2015-12-06 03:06:32.168050	zmdc	6898	INF	'zma -m 5' started at 15/12/06 03:06:32	zmdc.pl
2015-12-06 03:06:32.152750	zmdc	5874	INF	'zma -m 5' starting at 15/12/06 03:06:32, pid = 6898	zmdc.pl
2015-12-06 03:06:32.063760	zmdc	5874	INF	Starting pending process, zma -m 5	zmdc.pl
2015-12-06 03:06:31.982060	zmdc	6889	INF	'zma -m 7' started at 15/12/06 03:06:31	zmdc.pl
2015-12-06 03:06:31.975060	zmdc	5874	INF	'zma -m 7' starting at 15/12/06 03:06:31, pid = 6889	zmdc.pl
2015-12-06 03:06:31.011530	zmdc	5874	ERR	'zmc -m 5' exited abnormally, exit status 255	zmdc.pl
2015-12-06 03:06:30.654681	zmc_dvideo0	6712	WAR	Hue control is not supported	zm_local_camera.cpp	1757
2015-12-06 03:06:30.287070	zmdc	5874	INF	Starting pending process, zma -m 7	zmdc.pl
2015-12-06 03:06:29.954092	zmc_dvideo0	6712	INF	Starting Capture	zmc.cpp	195
2015-12-06 03:06:29.739847	zmc_m5	6741	FAT	You must have vlc libraries installed to use vlc cameras for monitor 5	zm_monitor.cpp	2705
2015-12-06 03:06:29.694430	zmdc	5874	ERR	'zma -m 7' exited abnormally, exit status 255	zmdc.pl
2015-12-06 03:06:29.167210	zmdc	6741	INF	'zmc -m 5' started at 15/12/06 03:06:29	zmdc.pl
2015-12-06 03:06:29.136980	zmdc	5874	INF	'zmc -m 5' starting at 15/12/06 03:06:29, pid = 6741	zmdc.pl
2015-12-06 03:06:29.042522	zma_m7	6722	ERR	Shared data not initialised by capture daemon for monitor MYDESK	zm_monitor.cpp	421
2015-12-06 03:06:29.000470	zmdc	5874	INF	Starting pending process, zmc -m 5	zmdc.pl
2015-12-06 03:06:28.843528	zmc_dvideo0	6712	INF	No direct match for the selected palette and target colorspace. Format conversion is required, performance penalty expected	zm_local_camera.cpp	409
2015-12-06 03:06:28.824160	zmdc	6722	INF	'zma -m 7' started at 15/12/06 03:06:28	zmdc.pl
2015-12-06 03:06:28.809090	zmdc	5874	INF	'zma -m 7' starting at 15/12/06 03:06:28, pid = 6722	zmdc.pl
Another set of errors!
2015-12-06 03:11:27.073390	zmwatch	7077	ERR	Memory map file '/dev/shm/zm.mmap.6' does not exist. zmc might not be running.	zmwatch.pl
2015-12-06 03:11:27.039880	zmwatch	7077	ERR	Memory map file '/dev/shm/zm.mmap.6' does not exist. zmc might not be running.	zmwatch.pl
2015-12-06 03:11:26.981100	zmwatch	7077	ERR	Memory map file '/dev/shm/zm.mmap.5' does not exist. zmc might not be running.	zmwatch.pl
2015-12-06 03:11:26.939180	zmwatch	7077	ERR	Memory map file '/dev/shm/zm.mmap.5' does not exist. zmc might not be running.	zmwatch.pl
2015-12-06 03:11:26.888550	zmwatch	7077	ERR	Memory map file '/dev/shm/zm.mmap.4' does not exist. zmc might not be running.	zmwatch.pl
2015-12-06 03:11:26.848590	zmwatch	7077	ERR	Memory map file '/dev/shm/zm.mmap.4' does not exist. zmc might not be running.	zmwatch.pl
2015-12-06 03:11:16.804430	zmwatch	7077	ERR	Memory map file '/dev/shm/zm.mmap.6' does not exist. zmc might not be running.	zmwatch.pl
2015-12-06 03:11:16.770750	zmwatch	7077	ERR	Memory map file '/dev/shm/zm.mmap.6' does not exist. zmc might not be running.	zmwatch.pl
2015-12-06 03:11:16.722970	zmwatch	7077	ERR	Memory map file '/dev/shm/zm.mmap.5' does not exist. zmc might not be running.	zmwatch.pl
2015-12-06 03:11:16.686720	zmwatch	7077	ERR	Memory map file '/dev/shm/zm.mmap.5' does not exist. zmc might not be running.	zmwatch.pl
2015-12-06 03:11:16.636570	zmwatch	7077	ERR	Memory map file '/dev/shm/zm.mmap.4' does not exist. zmc might not be running.	zmwatch.pl
2015-12-06 03:11:16.572290	zmwatch	7077	ERR	Memory map file '/dev/shm/zm.mmap.4' does not exist. zmc might not be running.	zmwatch.pl
2015-12-06 03:11:08.080420	zmfilter	6905	INF	Deleting event 10007	zmfilter.pl
2015-12-06 03:11:08.013140	zmfilter	6905	INF	Deleting event 10006	zmfilter.pl
2015-12-06 03:11:07.946130	zmfilter	6905	INF	Deleting event 10005	zmfilter.pl
2015-12-06 03:11:07.862140	zmfilter	6905	INF	Deleting event 10004	zmfilter.pl
2015-12-06 03:11:07.786790	zmfilter	6905	INF	Deleting event 10003	zmfilter.pl
2015-12-06 03:11:07.695990	zmfilter	6905	INF	Deleting event 10002	zmfilter.pl
2015-12-06 03:11:07.626990	zmfilter	6905	INF	Deleting event 10001	zmfilter.pl
2015-12-06 03:11:07.526420	zmfilter	6905	INF	Deleting event 10000	zmfilter.pl
2015-12-06 03:11:07.414650	zmfilter	6905	INF	Deleting event 9999	zmfilter.pl
2015-12-06 03:11:07.333730	zmfilter	6905	INF	Deleting event 9998	zmfilter.pl
2015-12-06 03:11:07.220630	zmfilter	6905	INF	Deleting event 9997	zmfilter.pl
2015-12-06 03:11:07.149140	zmfilter	6905	INF	Deleting event 9996	zmfilter.pl
2015-12-06 03:11:07.056900	zmfilter	6905	INF	Deleting event 9995
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
Sounds like you are not using the rpm from zmrepo.
Post the complete output of:
rpm -qi zoneminder
and:
rpm -qa |grep vlc
teraquad
Post by teraquad »
thanks for the reply, Here is the info requested.
[root@tera-two ~]# rpm -qi zoneminder
Version     : 1.28.1
Release     : 4.fc23
Architecture: x86_64
Install Date: Sat 28 Nov 2015 06:52:39 AM EST
Group       : System Environment/Daemons
License     : GPLv2+ and LGPLv2+ and MIT
Signature   : RSA/SHA256, Tue 23 Jun 2015 05:03:32 PM EDT, Key ID 32474cf834ec9cba
Source RPM  : zoneminder-1.28.1-4.fc23.src.rpm
Build Date  : Fri 19 Jun 2015 01:46:29 AM EDT
Build Host  : buildhw-11.phx2.fedoraproject.org
Relocations : (not relocatable)
Packager    : Fedora Project
Vendor      : Fedora Project
URL         : http://www.zoneminder.com/
Summary     : A camera monitoring and analysis tool
Description :
ZoneMinder is a set of applications which is intended to provide a complete
solution allowing you to capture, analyse, record and monitor any cameras you
have attached to a Linux based machine. It is designed to run on kernels which
support the Video For Linux (V4L) interface and has been tested with cameras
attached to BTTV cards, various USB cameras and IP network cameras. It is
designed to support as many cameras as you can attach to your computer without
too much degradation of performance.
[root@tera-two ~]#
[root@tera-two ~]# rpm -qa |grep vlc
npapi-vlc-gtk-2.2.0-0.1.fc22.x86_64
vlc-2.2.2-0.1.fc23.x86_64
npapi-vlc-filesystem-2.2.0-0.1.fc22.x86_64
vlc-core-2.2.2-0.1.fc23.x86_64
[root@tera-two ~]#
Thanks for the help, it is much appriceated..
george....
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
As one can see from the first output you provided, the name of the Packager is Fedora Project, and not me, Andrew Bauer.
You are, again, using the wrong zoneminder package.
You will never get vlc or ffmpeg support to work with that rpm because vlc and ffmpeg support were not built into it.
Referring back to the previous thread you created, you need to, again, completely uninstall ZoneMinder. Next, go to zmrepo.zoneminder.com and follow the instructions on the site. You need to especially follow the note about putting an "exclude" statement into your fedora.repo file. Otherwise, you will end up with the wrong zoneminder package on your system yet again.
teraquad
Post by teraquad »
I was under the impression i had done so, However i see that it hasn't been done correctly. Thank you very much for your time and effort it is greatly appriceated.
I think i will just disable the fedora repo all together while re installing the proper package. I am certian parts of it were from the zoneminder repo as i watched the install carefully and saw the repository pop up a time or too. But, that is neither here nor there as you have proven it didn't go as i thought.
Thanks Again!
george....
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
I would not disable the Fedora repo entirely. That could cause other problems.
You need to exclude the zoneminder package specifically as described on the zmrepo site.
In other words, you need to edit the file /etc/yum.repos.d/fedora.repo and add an exclude line to the first block just like this:
[fedora]
name=Fedora $releasever - $basearch
failovermethod=priority
#baseurl=http://download.fedoraproject.org/pub/fedora/linux/releases/$releasever/Everything/$basearch/os/
metalink=https://mirrors.fedoraproject.org/metalink?repo=fedora-$releasever&arch=$basearch
enabled=1
metadata_expire=28d
gpgcheck=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-fedora-$releasever-$basearch
skip_if_unavailable=False
exclude=zoneminder*
See that last line? You need to add that to yours.
teraquad
Post by teraquad »
This is what i am running into. Not sure how to fix it. Also i found that i had put the exclude line in the fedora repo file, but, it was not adjacent to the first block. Perhaps that was the difference.
[root@tera-two /]# yum install zoneminder
Yum command has been deprecated, redirecting to '/usr/bin/dnf install zoneminder'.
See 'man dnf' and 'man yum2dnf' for more information.
To transfer transaction metadata from yum to DNF, run:
'dnf install python-dnf-plugins-extras-migrate && dnf-2 migrate'
Failed to synchronize cache for repo 'zmrepo' from 'http://zmrepo.mehvc.com/f/23/x86_64;http://zmrepo.connortechnology.com/f/23/x86_64': repomd.xml parser error: Element <repomd> was not found - Bad repomd file, disabling.
Failed to synchronize cache for repo 'zmrepo-source' from 'http://zmrepo.mehvc.com/f/23/SRPMS;http://zmrepo.connortechnology.com/f/23/SRPMS': repomd.xml parser error: Element <repomd> was not found - Bad repomd file, disabling.
Last metadata expiration check performed 2:57:33 ago on Sun Dec  6 12:59:35 2015.
No package zoneminder available.
Error: Unable to find a match.
[root@tera-two /]#
[root@tera-two /]#
[root@tera-two /]# dnf install zoneminder
Last metadata expiration check performed 2:58:54 ago on Sun Dec  6 12:59:35 2015.
[root@tera-two /]#
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
Try "yum install zoneminder" again.
teraquad
Post by teraquad »
Here are the results of the last try. I also tried with all but the zm repo excluded. the results were identical save the update.
Thanks!
george....
[root@tera-two ~]# yum install zoneminder
Fedora 23 - x86_64 - Updates                    2.5 MB/s |  10 MB     00:04
Last metadata expiration check performed 0:00:12 ago on Mon Dec  7 01:37:12 2015.
[root@tera-two ~]#
[root@tera-two ~]#
[root@tera-two ~]# dnf install zoneminder
[root@tera-two ~]#
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
I was able to duplicate the problem, yesterday. There was an issue with one of our mirror servers. Not all the files rsynced to the server properly. I have fixed the issue and it is working fine now for me anyway.
Clear your cache and try again:
yum clean all
The old yum tool is still on your system. It has just been renamed.
You could try this if dnf is still not working right:
yum-deprecated clean all
yum-deprecated install zoneminder
teraquad
Post by teraquad »
I tried both and added a dnf as well, looks like yum is still here.
Thanks!
george....
[root@tera-two ~]# yum clean all
Yum command has been deprecated, redirecting to '/usr/bin/dnf clean all'.
Cleaning repos: updates rpmfusion-free zmrepo-source zmrepo fedora
              : rpmfusion-free-updates
Cleaning up Everything
Fedora 23 - x86_64                              5.8 MB/s |  43 MB     00:07
Fedora 23 - x86_64 - Updates                    5.4 MB/s |  10 MB     00:01
RPM Fusion for Fedora 23 - Free - Updates       1.0 MB/s | 318 kB     00:00
RPM Fusion for Fedora 23 - Free                 914 kB/s | 738 kB     00:00
Last metadata expiration check performed 0:00:01 ago on Mon Dec  7 08:39:28 2015.
[root@tera-two ~]# yum-deprecated clean all
bash: yum-deprecated: command not found...
Install package 'yum' to provide command 'yum-deprecated'? [N/y] n
[root@tera-two ~]#
[root@tera-two ~]# dnf clean all
Cleaning repos: rpmfusion-free zmrepo-source rpmfusion-free-updates zmrepo
              : fedora updates
Fedora 23 - x86_64 - Updates                    1.9 MB/s |  10 MB     00:05
Fedora 23 - x86_64                              4.5 MB/s |  43 MB     00:09
RPM Fusion for Fedora 23 - Free                 906 kB/s | 738 kB     00:00
Last metadata expiration check performed 0:00:01 ago on Mon Dec  7 08:46:35 2015.
[root@tera-two ~]#
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
Failed to synchronize cache for repo 'zmrepo-source' from 'http://zmrepo.mehvc.com/f/23/SRPMS;http ... f/23/SRPMS': repomd.xml parser error: Element <repomd> was not found - Bad repomd file, disabling.
zmrepo-source should not be enabled, which implies you've been making changes to the repo files.
Try:
- uninstall zmrepo
- delete all files under /etc/yum.repos.d with the word "zmrepo" in it
- re-download the zmrepo rpm for Fedora 23
- install it
- yum install zoneminder
You do not need to modify the zmrepo repo files in any way.
teraquad
Post by teraquad »
B I N G O
Looks like that did it I got a bunch of perl stuff and zoneminder. hope it came from the right place.
Not so quick, have a look at this!
Installed:
  cambozola.noarch 0.93-3.fc23
  perl-Algorithm-Diff.noarch 1.1903-3.fc23
  perl-Archive-Tar.noarch 2.04-347.fc23
  perl-Archive-Zip.noarch 1.49-1.fc23
  perl-Convert-BinHex.noarch 1.124-1.fc23
  perl-Date-Manip.noarch 6.51-1.fc23
  perl-Email-Date-Format.noarch 1.005-3.fc23
  perl-IO-Zlib.noarch 1:1.10-349.fc23
  perl-Locale-Maketext-Simple.noarch 1:0.21-349.fc23
  perl-MIME-Lite.noarch 3.030-5.fc23
  perl-MIME-Types.noarch 2.11-1.fc23
  perl-MIME-tools.noarch 5.506-3.fc23
  perl-MailTools.noarch 2.14-3.fc23
  perl-Module-CoreList.noarch 1:5.20151120-1.fc23
  perl-Module-Load-Conditional.noarch 0.64-346.fc23
  perl-Module-Metadata.noarch 1.000027-3.fc23
  perl-Net-SMTP-SSL.noarch 1.03-1.fc23
  perl-Params-Check.noarch 1:0.38-346.fc23
  perl-Sys-Mmap.x86_64 0.17-3.fc23
  perl-Sys-Syslog.x86_64 0.33-347.fc23
  perl-Text-Diff.noarch 1.43-1.fc23
  perl-URI-Encode.noarch 0.09-3.fc23
  perl-version.x86_64 5:0.99.12-4.fc23
  zoneminder.x86_64 1.28.1-1.fc23
Complete!
[root@tera-two yum.repos.d]#
[root@tera-two yum.repos.d]# cd /
[root@tera-two /]# systemctl start zoneminder.service
Job for zoneminder.service failed because the control process exited with error code. See "systemctl status zoneminder.service" and "journalctl -xe" for details.
[root@tera-two /]#
[root@tera-two /]#
[root@tera-two /]#
[root@tera-two /]#
[root@tera-two /]#
[root@tera-two /]#
[root@tera-two /]# rpm -gi zoneminder
error: open of zoneminder failed: No such file or directory
[root@tera-two /]#
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
