open source ZM client: ZmNinja (uses ZoneMinder APIs)
Re: open source ZM client: ZmNinja
http://www.zoneminder.com/forums/viewto ... 32&t=23375
The link above is a "Master Branch" forum topic. In that there are procedures to install ZM on Ubuntu 14.04 and 15.04 from the iconnor zoneminder-master. Both assume you have installed the LAMP on your server. These procedures should continue to work as updates are developed.
bb
jbg70
Post by jbg70 »
I installed Zoneminder 1.28.106, the latest available from iconnor ppa (ppa:iconnor/zoneminder-master).
On the zmninja github document "Configuring ZoneMinder with API" there is a test to check if api works:
h_t_t_p://localhost/zm/api/host/getVersion.json
If i browse my zm/api directory, there is no "host" subdir and there is no file "getVersion.json" anywhere in the disk.
Sure I miss something, but what?
Thanks for your help.
asker
Post by asker »
These are not files you will find. They are URLs that are processed by the API layer for routing purposes
Please read before posting:
ES docs
zmNinja docs
asker
Post by asker »
Folks, I've updated instructions on how to install ZM+APIs correctly.
I've tested the ubuntu (iconnor's package and source) instructions today with clean OS installs before each.
Please follow them accurately and you should have no problems, especially with Ubuntu (which I've tried myself, based on both source install and iconnor's PPAs) and for Fedora/Centos that knnniggett has made sure is a very simple install process.
https://github.com/pliablepixels/zmNinj ... r-with-API
ES docs
zmNinja docs
patpend
Re: open source ZM client: ZmNinja (uses ZoneMinder APIs)
Post by patpend »
Asker, please put me on the list to test the iOS version. I have ZM 1.28.107 running with the APIs. The app looks excellent, looking forward to checking it out and giving you feedback. Many thanks for your effort.
If anyone's into Docker, Angel Rodriguez-Ricardo just released a zoneminder container with the API at https://github.com/QuantumObject/docker-zoneminder. Makes it very easy to get zm up & running with the APIs.
asker
Post by asker »
patpend wrote:Asker, please put me on the list to test the iOS version. I have ZM 1.28.107 running with the APIs. The app looks excellent, looking forward to checking it out and giving you feedback. Many thanks for your effort.
Patpend, will do. I need more iOS testers. I have a bazillion Android testers (and growing) but only 2 iOS testers :(
Can you please follow the steps in the 1st post in this thread and send me an email?
ES docs
zmNinja docs
asker
Post by asker »
zmNinja now runs great on Desktop platforms: linux, windows, mac. See the first post in this thread.
ES docs
zmNinja docs
asker
Post by asker »
Folks, I've submitted both iOS and Android to the app/play store. They are priced at $3.99
I don't know when they will show up though. And I may go through a few rounds of rejection - this being my first time
thanks for the support.
ES docs
zmNinja docs
PacoLM
Post by PacoLM »
Good luck, I hope you get a valuable payback of this effort... ;)
asker
Post by asker »
Thanks PacoLM, very kind of you
PacoLM wrote:Good luck, I hope you get a valuable payback of this effort... ;)
ES docs
zmNinja docs
BiloxiGeek
Post by BiloxiGeek »
Since I have (IOS) ZmNinja installed will the App Store see it as an update or a different app?
asker
Post by asker »
BiloxiGeek wrote:Since I have (IOS) ZmNinja installed will the App Store see it as an update or a different app?
It will be a different app.
ES docs
zmNinja docs
asker
Post by asker »
Folks, the iOS app is also published. Check the first post for a link
ES docs
zmNinja docs
BiloxiGeek
Installed with no problems. Glad to see you got it into the app store.
asker
Post by asker »
BiloxiGeek wrote:Installed with no problems. Glad to see you got it into the app store.
Awesome - don't forget to leave reviews :-)
ES docs
zmNinja docs
