sudo /usr/bin/zmcontrol.pl --panspeed=35 --autostop --command=moveConRight --id=4
and the output i get is nothing.
stty 4800 -cstopb cs8 -parenb -crtscts -echo -F /dev/ttyS0
stty -a -F /dev/ttyS0speed 4800 baud; rows 0; columns 0; line = 0;
intr = ^C; quit = ^\; erase = ^?; kill = ^U; eof = ^D; eol = <undef>;
eol2 = <undef>; swtch = <undef>; start = ^Q; stop = ^S; susp = ^Z; rprnt = ^R;
werase = ^W; lnext = ^V; flush = ^O; min = 0; time = 244;
-parenb -parodd -cmspar cs8 hupcl -cstopb cread clocal -crtscts
ignbrk -brkint -ignpar -parmrk -inpck -istrip -inlcr -igncr -icrnl -ixon -ixoff
-iuclc -ixany -imaxbel -iutf8
-opost -olcuc -ocrnl -onlcr -onocr -onlret -ofill -ofdel nl0 cr0 tab0 bs0 vt0 ff0
-isig -icanon -iexten -echo -echoe -echok -echonl -noflsh -xcase -tostop -echoprt
-echoctl -echoke
# ZoneMinder Pelco-P Control Protocol Module, $Date$, $Revision$
# This module contains the implementation of the Pelco-P camera control
# protocol
package ZoneMinder::Control::PelcoP;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# Pelco-P Control Protocol
use Time::HiRes qw( usleep );
use constant STX => 0xa0;
use constant ETX => 0xaf;
use constant COMMAND_GAP => 100000; # In ms
sub new
my $class = shift;
my $id = shift;
bless( $self, $class );
srand( time() );
return $self;
our $AUTOLOAD;
sub AUTOLOAD
my $self = shift;
my $name = $AUTOLOAD;
$name =~ s/.*://;
if ( exists($self->{$name}) )
return( $self->{$name} );
sub open
my $self = shift;
$self->loadMonitor();
use Device::SerialPort;
$self->{port} = new Device::SerialPort( $self->{Monitor}->{ControlDevice} );
$self->{port}->baudrate(4800);
$self->{port}->databits(8);
$self->{port}->parity('none');
$self->{port}->stopbits(1);
$self->{port}->handshake('none');
$self->{port}->read_const_time(50);
$self->{port}->read_char_time(10);
$self->{state} = 'open';
sub close
my $self = shift;
$self->{state} = 'closed';
$self->{port}->close();
sub printMsg
if ( logDebugging() )
my $self = shift;
my $msg = shift;
my $prefix = shift || "";
$prefix = $prefix.": " if ( $prefix );
my $line_length = 16;
my $msg_len = int(@$msg);
my $msg_str = $prefix;
for ( my $i = 0; $i < $msg_len; $i++ )
if ( ($i > 0) && ($i%$line_length == 0) && ($i != ($msg_len-1)) )
$msg_str .= sprintf( "\n%*s", length($prefix), "" );
$msg_str .= sprintf( "%02x ", $msg->[$i] );
$msg_str .= "[".$msg_len."]";
Debug( $msg_str );
sub sendCmd
my $self = shift;
my $cmd = shift;
my $ack = shift || 0;
my $result = undef;
my $checksum = 0x00;
for ( my $i = 1; $i < int(@$cmd); $i++ )
$checksum ^= $cmd->[$i];
$checksum &= 0xff;
push( @$cmd, $checksum );
$self->printMsg( $cmd, "Tx" );
my $id = $cmd->[0] & 0xf;
my $tx_msg = pack( "C*", @$cmd );
#print( "Tx: ".length( $tx_msg )." bytes\n" );
my $n_bytes = $self->{port}->write( $tx_msg );
if ( !$n_bytes )
Error( "Write failed: $!" );
if ( $n_bytes != length($tx_msg) )
Error( "Incomplete write, only ".$n_bytes." of ".length($tx_msg)." written: $!" );
if ( $ack )
Debug( "Waiting for ack" );
my $max_wait = 3;
my $now = time();
while( 1 )
my ( $count, $rx_msg ) = $self->{port}->read(4);
if ( $count )
#print( "Rx1: ".$count." bytes\n" );
my @resp = unpack( "C*", $rx_msg );
printMsg( \@resp, "Rx" );
if ( $resp[0] = 0x80 + ($id<<4) )
if ( ($resp[1] & 0xf0) == 0x40 )
my $socket = $resp[1] & 0x0f;
Debug( "Got ack for socket $socket" );
$result = !undef;
else
Error( "Got bogus response" );
last;
else
Error( "Got message for camera ".(($resp[0]-0x80)>>4) );
if ( (time() - $now) > $max_wait )
Warning( "Response timeout" );
last;
sub remoteReset
my $self = shift;
Debug( "Remote Reset" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x0f, 0x00, 0x00, ETX );
$self->sendCmd( \@msg );
sub resetDefaults
my $self = shift;
Debug( "Reset Defaults" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x29, 0x00, 0x00, ETX );
sub cameraOff
my $self = shift;
Debug( "Camera Off" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x08, 0x00, 0x00, 0x00, ETX );
sub cameraOn
my $self = shift;
Debug( "Camera On" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x88, 0x00, 0x00, 0x00, ETX );
sub autoScan
my $self = shift;
Debug( "Auto Scan" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x90, 0x00, 0x00, 0x00, ETX );
sub manScan
my $self = shift;
Debug( "Manual Scan" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x10, 0x00, 0x00, 0x00, ETX );
sub stop
my $self = shift;
Debug( "Stop" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x00, 0x00, 0x00, ETX );
sub moveConUp
my $self = shift;
my $params = shift;
my $speed = $self->getParam( $params, 'tiltspeed' );
my $autostop = $self->getParam( $params, 'autostop', 0 );
Debug( "Move Up" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x08, 0x00, $speed, ETX );
if( $autostop && $self->{Monitor}->{AutoStopTimeout} )
usleep( $self->{Monitor}->{AutoStopTimeout} );
$self->stop( $params );
sub moveConDown
my $self = shift;
my $params = shift;
Debug( "Move Down" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x10, 0x00, $speed, ETX );
$self->stop();
sub moveConLeft
my $self = shift;
my $params = shift;
my $speed = $self->getParam( $params, 'panspeed' );
Debug( "Move Left" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x04, $speed, 0x00, ETX );
$self->stop();
sub moveConRight
my $self = shift;
my $params = shift;
Debug( "Move Right" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x02, $speed, 0x00, ETX );
$self->stop();
sub moveConUpLeft
my $self = shift;
my $params = shift;
my $panspeed = $self->getParam( $params, 'panspeed', 0x3f );
my $tiltspeed = $self->getParam( $params, 'tiltspeed', 0x3f );
Debug( "Move Up/Left" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x0c, $panspeed, $tiltspeed, ETX );
$self->stop();
sub moveConUpRight
my $self = shift;
my $params = shift;
Debug( "Move Up/Right" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x0a, $panspeed, $tiltspeed, ETX );
$self->stop();
sub moveConDownLeft
my $self = shift;
my $params = shift;
Debug( "Move Down/Left" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x14, $panspeed, $tiltspeed, ETX );
$self->stop();
sub moveConDownRight
my $self = shift;
my $params = shift;
Debug( "Move Down/Right" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x12, $panspeed, $tiltspeed, ETX );
$self->stop();
sub moveStop
my $self = shift;
Debug( "Move Stop" );
$self->stop();
sub flip180
my $self = shift;
Debug( "Flip 180" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x07, 0x00, 0x21, ETX );
sub zeroPan
my $self = shift;
Debug( "Zero Pan" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x07, 0x00, 0x22, ETX );
sub _setZoomSpeed
my $self = shift;
my $speed = shift;
Debug( "Set Zoom Speed $speed" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x25, 0x00, $speed, ETX );
sub zoomStop
my $self = shift;
Debug( "Zoom Stop" );
$self->stop();
$self->_setZoomSpeed( 0 );
sub zoomConTele
my $self = shift;
my $params = shift;
my $speed = $self->getParam( $params, 'speed', 0x01 );
Debug( "Zoom Tele" );
$self->_setZoomSpeed( $speed );
usleep( COMMAND_GAP );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x20, 0x00, 0x00, ETX );
$self->zoomStop();
sub zoomConWide
my $self = shift;
my $params = shift;
Debug( "Zoom Wide" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x40, 0x00, 0x00, ETX );
$self->zoomStop();
sub _setFocusSpeed
my $self = shift;
my $speed = shift;
Debug( "Set Focus Speed $speed" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x27, 0x00, $speed, ETX );
sub focusConNear
my $self = shift;
my $params = shift;
my $speed = $self->getParam( $params, 'speed', 0x03 );
Debug( "Focus Near" );
$self->_setFocusSpeed( $speed );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x01, 0x00, 0x00, 0x00, ETX );
$self->_setFocusSpeed( 0 );
sub focusConFar
my $self = shift;
my $params = shift;
Debug( "Focus Far" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x80, 0x00, 0x00, ETX );
sub focusStop
my $self = shift;
Debug( "Focus Stop" );
$self->stop();
sub focusAuto
my $self = shift;
Debug( "Focus Auto" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x2b, 0x00, 0x00, ETX );
sub focusMan
my $self = shift;
Debug( "Focus Man" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x2b, 0x00, 0x02, ETX );
sub _setIrisSpeed
my $self = shift;
my $speed = shift;
Debug( "Set Iris Speed $speed" );
sub irisConClose
my $self = shift;
my $params = shift;
Debug( "Iris Close" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x04, 0x00, 0x00, 0x00, ETX );
$self->_setIrisSpeed( 0 );
sub irisConOpen
my $self = shift;
my $params = shift;
Debug( "Iris Open" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x02, 0x80, 0x00, 0x00, ETX );
sub irisStop
my $self = shift;
Debug( "Iris Stop" );
$self->stop();
sub irisAuto
my $self = shift;
Debug( "Iris Auto" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x2d, 0x00, 0x00, ETX );
sub irisMan
my $self = shift;
Debug( "Iris Man" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x2d, 0x00, 0x02, ETX );
sub writeScreen
my $self = shift;
my $params = shift;
my $string = $self->getParam( $params, 'string' );
Debug( "Writing '$string' to screen" );
my @chars = unpack( "C*", $string );
for ( my $i = 0; $i < length($string); $i++ )
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x15, $i, $chars[$i], ETX );
sub clearScreen
my $self = shift;
Debug( "Clear Screen" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x17, 0x00, 0x00, ETX );
sub clearPreset
my $self = shift;
my $params = shift;
my $preset = $self->getParam( $params, 'preset', 1 );
Debug( "Clear Preset $preset" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x05, 0x00, $preset, ETX );
sub presetSet
my $self = shift;
my $params = shift;
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x03, 0x00, $preset, ETX );
sub presetGoto
my $self = shift;
my $params = shift;
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x07, 0x00, $preset, ETX );
sub presetHome
my $self = shift;
Debug( "Home Preset" );
sub reset
my $self = shift;
Debug( "Reset" );
$self->remoteReset();
$self->resetDefaults();
sub wake
my $self = shift;
Debug( "Wake" );
$self->cameraOn();
sub sleep
my $self = shift;
Debug( "Sleep" );
$self->cameraOff();
1;
__END__
# Below is stub documentation for your module. You'd better edit it!
=head1 NAME
ZoneMinder::Database - Perl extension for blah blah blah
=head1 SYNOPSIS
use ZoneMinder::Database;
blah blah blah
=head1 DESCRIPTION
Stub documentation for ZoneMinder, created by h2xs. It looks like the
author of the extension was negligent enough to leave the stub
unedited.
Blah blah blah.
=head2 EXPORT
None by default.
=head1 SEE ALSO
Mention other useful documentation such as the documentation of
related modules or operating system documentation (such as man pages
in UNIX), or any relevant external documentation such as RFCs or
standards.
If you have a mailing list set up for your module, mention it here.
If you have a web site set up for your module, mention it here.
=head1 AUTHOR
Philip Coombes, E<lt>philip.coombes@zoneminder.comE<gt>
=head1 COPYRIGHT AND LICENSE
This library is free software; you can redistribute it and/or modify
it under the same terms as Perl itself, either Perl version 5.8.3 or,
at your option, any later version of Perl 5 you may have available.
=cut
I am using Pelco-D and my camera is set to 1, same as ZM.Zmptz wrote:Thanks for your reply
I've set the Control address to 0,1,2 and 3. The camera Address is set to 1
I read somewhere on this forum that Pelco D and P add +1 to the address??
In a serial terminal software I can send theses command to control the camera.
Pan Left at normal speed: A0 00 00 04 20 00 AF 2B
Pan Right at normal speed: A0 00 00 02 20 00 AF 2D
Tilt Up at normal speed: A0 00 00 08 00 20 AF 27
Tilt Down at normal speed: A0 00 00 10 00 20 AF 3F
Stop all actions (Pan/Tilt/Zoom/Iris etc.): A0 00 00 00 00 00 AF 0F
Info($var);
ls -l /dev/ttyS0
crw-rw---- 1 root dialout 4, 64 Dec 31 19:47 /dev/ttyS0
sudo -u www-data zmcontrol.pl --id=4 --panspeed=32 --command=moveConRight
sudo -u www-data zmcontrol.pl --id=4 --panspeed=32 --command=moveConLeft
sudo -u www-data zmcontrol.pl -info($var); --id=4 --panspeed=32 --command=moveConLeft
-bash: syntax error near unexpected token `('
Yeah, I actually meant you can edit zmcontrol.pl and substitute one of the program variables for $var. I tend to forget not everyone is a programmerZmptz wrote:Thanks
how do you add debugging when i add Info($var); to the command above i get a -bash errorI know might be doing something wrong here.Code: Select all
sudo -u www-data zmcontrol.pl -info($var); --id=4 --panspeed=32 --command=moveConLeft -bash: syntax error near unexpected token `('
#!/usr/bin/perl -wT
# ZoneMinder Control Script, $Date$, $Revision$
# This script continuously monitors the recorded events for the given
# monitor and applies any filters which would delete and/or upload
# matching events
use strict;
use lib '/usr/share/perl/5.20.2'; # Include custom perl install path
use ZoneMinder;
use Getopt::Long;
use POSIX qw/strftime EPIPE/;
use Socket;
#use Data::Dumper;
use Module::Load::Conditional qw{can_load};;
use constant MAX_CONNECT_DELAY => 10;
use constant MAX_COMMAND_WAIT => 1800;
$| = 1;
$ENV{PATH} = '/bin:/usr/bin';
$ENV{SHELL} = '/bin/sh' if exists $ENV{SHELL};
delete @ENV{qw(IFS CDPATH ENV BASH_ENV)};
sub Usage
print( "
Usage: zmcontrol.pl --id <monitor_id> --command=<command> <various options>
exit();
logInit();
my $arg_string = join( " ", @ARGV );
my $id;
my %options;
if ( !GetOptions(
'id=i'=>\$id,
'command=s'=>\$options{command},
'xcoord=i'=>\$options{xcoord},
'ycoord=i'=>\$options{ycoord},
'speed=i'=>\$options{speed},
'step=i'=>\$options{step},
'panspeed=i'=>\$options{panspeed},
'tiltspeed=i'=>\$options{tiltspeed},
'panstep=i'=>\$options{panstep},
'tiltstep=i'=>\$options{tiltstep},
'preset=i'=>\$options{preset},
'autostop'=>\$options{autostop},
Usage();
if ( !$id || !$options{command} )
print( STDERR "Please give a valid monitor id and command\n" );
Usage();
( $id ) = $id =~ /^(\w+)$/;
Debug( $arg_string );
my $sock_file = $Config{ZM_PATH_SOCKS}.'/zmcontrol-'.$id.'.sock';
socket( CLIENT, PF_UNIX, SOCK_STREAM, 0 ) or Fatal( "Can't open socket: $!" );
my $saddr = sockaddr_un( $sock_file );
my $server_up = connect( CLIENT, $saddr );
if ( !$server_up )
# The server isn't there
my $monitor = zmDbGetMonitorAndControl( $id );
if ( !$monitor )
Fatal( "Unable to load control data for monitor $id" );
my $protocol = $monitor->{Protocol};
if ( -x $protocol )
# Protocol is actually a script!
# Holdover from previous versions
my $command .= $protocol.' '.$arg_string;
Debug( $command."\n" );
my $output = qx($command);
my $status = $? >> 8;
if ( $status || logDebugging() )
chomp( $output );
Debug( "Output: $output\n" );
if ( $status )
Error( "Command '$command' exited with status: $status\n" );
exit( $status );
exit( 0 );
Info( "Starting control server $id/$protocol" );
close( CLIENT );
if ( ! can_load( modules => { "ZoneMinder::Control::$protocol" => undef } ) ) {
Fatal("Can't load ZoneMinder::Control::$protocol");
if ( my $cpid = fork() )
logReinit();
# Parent process just sleep and fall through
socket( CLIENT, PF_UNIX, SOCK_STREAM, 0 ) or die( "Can't open socket: $!" );
my $attempts = 0;
while (!connect( CLIENT, $saddr ))
$attempts++;
Fatal( "Can't connect: $!" ) if ($attempts > MAX_CONNECT_DELAY);
sleep(1);
elsif ( defined($cpid) )
close( STDOUT );
close( STDERR );
setpgrp();
logReinit();
Info( "Control server $id/$protocol starting at ".strftime( '%y/%m/%d %H:%M:%S', localtime() ) );
$0 = $0." --id $id";
my $control = "ZoneMinder::Control::$protocol"->new( $id );
my $control_key = $control->getKey();
$control->loadMonitor();
$control->open();
socket( SERVER, PF_UNIX, SOCK_STREAM, 0 ) or Fatal( "Can't open socket: $!" );
unlink( $sock_file );
bind( SERVER, $saddr ) or Fatal( "Can't bind: $!" );
listen( SERVER, SOMAXCONN ) or Fatal( "Can't listen: $!" );
my $rin = '';
vec( $rin, fileno(SERVER), 1 ) = 1;
my $win = $rin;
my $ein = $win;
my $timeout = MAX_COMMAND_WAIT;
while( 1 )
my $nfound = select( my $rout = $rin, undef, undef, $timeout );
if ( $nfound > 0 )
if ( vec( $rout, fileno(SERVER), 1 ) )
my $paddr = accept( CLIENT, SERVER );
my $message = <CLIENT>;
next if ( !$message );
my $params = jsonDecode( $message );
#Debug( Dumper( $params ) );
my $command = $params->{command};
$control->$command( $params );
close( CLIENT );
else
Fatal( "Bogus descriptor" );
elsif ( $nfound < 0 )
if ( $! == EPIPE )
Error( "Can't select: $!" );
else
Fatal( "Can't select: $!" );
else
#print( "Select timed out\n" );
last;
Info( "Control server $id/$protocol exiting at ".strftime( '%y/%m/%d %H:%M:%S', localtime() ) );
$control->close();
exit( 0 );
else
Fatal( "Can't fork: $!" );
# The server is there, connect to it
#print( "Writing commands\n" );
CLIENT->autoflush();
my $message = jsonEncode( \%options );
print( CLIENT $message );
shutdown( CLIENT, 1 );
exit( 0 );
Tx: a0 01 00 00 00 00 af ae [8] zmcontrol.pl
2016-01-02 11:18:47.476110 zmcontrol 13787 DBG Stop zmcontrol.pl
2016-01-02 11:18:46.919110 zmcontrol 13787 DBG Tx: a0 01 00 04 1b 00 af b1 [8] zmcontrol.pl
2016-01-02 11:18:46.861080 zmcontrol 13787 DBG Move Left zmcontrol.pl
2016-01-02 11:18:46.195870 zmcontrol 13787 DBG Tx: a0 01 00 00 00 00 af ae [8] zmcontrol.pl
2016-01-02 11:18:46.139910 zmcontrol 13787 DBG Stop zmcontrol.pl
2016-01-02 11:18:45.583770 zmcontrol 13787 DBG Tx: a0 01 00 10 00 25 af 9b [8] zmcontrol.pl
2016-01-02 11:18:45.535750 zmcontrol 13787 DBG Move Down zmcontrol.pl
2016-01-02 11:18:44.849310 zmcontrol 13787 DBG Tx: a0 01 00 00 00 00 af ae [8] zmcontrol.pl
2016-01-02 11:18:44.804430 zmcontrol 13787 DBG Stop zmcontrol.pl
2016-01-02 11:18:44.259450 zmcontrol 13787 DBG Tx: a0 01 00 02 1b 00 af b7 [8] zmcontrol.pl
2016-01-02 11:18:44.220340 zmcontrol 13787 DBG Move Right zmcontrol.pl
2016-01-02 11:18:43.858370 zmcontrol 13787 DBG Tx: a0 01 00 00 00 00 af ae [8] zmcontrol.pl
2016-01-02 11:18:43.802410 zmcontrol 13787 DBG Stop zmcontrol.pl
2016-01-02 11:18:43.246280 zmcontrol 13787 DBG Tx: a0 01 00 08 00 16 af b0 [8] zmcontrol.pl
2016-01-02 11:18:43.190940 zmcontrol 13787 DBG Move Up zmcontrol.pl
2016-01-02 11:09:13.819150 zmcontrol 13787 DBG Tx: a0 01 00 00 00 00 af ae [8]
Byte 1 STX
Byte 2 Camera Address
Byte 3 Data 1
Byte 4 Data 2
Byte 5 Data 3
Byte 6 Data 4
Byte 7 ETX
Byte 8 Checksum
Tx: a0 00 00 00 00 00 af af [8] zmcontrol.pl
2016-01-02 11:30:24.627610 zmcontrol 13932 DBG Stop zmcontrol.pl
2016-01-02 11:30:24.071370 zmcontrol 13932 DBG Tx: a0 00 00 04 19 00 af b2 [8] zmcontrol.pl
2016-01-02 11:30:24.015500 zmcontrol 13932 DBG Move Left zmcontrol.pl
2016-01-02 11:30:23.959360 zmcontrol 13932 DBG Tx: a0 00 00 00 00 00 af af [8] zmcontrol.pl
2016-01-02 11:30:23.903320 zmcontrol 13932 DBG Stop zmcontrol.pl
2016-01-02 11:30:23.347280 zmcontrol 13932 DBG Tx: a0 00 00 10 00 1d af a2 [8] zmcontrol.pl
2016-01-02 11:30:23.291380 zmcontrol 13932 DBG Move Down zmcontrol.pl
2016-01-02 11:30:23.235270 zmcontrol 13932 DBG Tx: a0 00 00 00 00 00 af af [8] zmcontrol.pl
2016-01-02 11:30:23.179260 zmcontrol 13932 DBG Stop zmcontrol.pl
2016-01-02 11:30:22.623080 zmcontrol 13932 DBG Tx: a0 00 00 02 27 00 af 8a [8] zmcontrol.pl
2016-01-02 11:30:22.567310 zmcontrol 13932 DBG Move Right zmcontrol.pl
2016-01-02 11:30:22.511140 zmcontrol 13932 DBG Tx: a0 00 00 00 00 00 af af [8] zmcontrol.pl
2016-01-02 11:30:22.455150 zmcontrol 13932 DBG Stop zmcontrol.pl
2016-01-02 11:30:21.898970 zmcontrol 13932 DBG Tx: a0 00 00 08 00 22 af 85 [8] zmcontrol.pl
2016-01-02 11:30:21.842220 zmcontrol 13932 DBG Move Up
sub sendCmd
my $self = shift;
my $cmd = shift;
my $result = undef;
$checksum &= 0xff;
if ( !$n_bytes )
if ( $ack )
my $max_wait = 3;
my $now = time();
while( 1 )
if ( $count )
$result = !undef;
else
last;
else
last;
