How can I setup serial RS 422 PTZ in ZM
Re: How can I setup serial RS 422 PTZ in ZM
First, make sure the PelcoP script you are using has this important change in it:
https://github.com/ZoneMinder/ZoneMinde ... b549c5be7b
Second, scroll down to the point in the script that loops through the bytes in the message.
It looks like this:
https://github.com/ZoneMinder/ZoneMinde ... oP.pm#L137
Change the 1 in the for loop to a 0.
The line of code should look like this now:
for ( my $i = 0; $i < int(@$cmd); $i++ )
This should cause the script to include the STX sync packet in the checksum calculation.
And please report back success or failure. I have no way to test this myself.
Zmptz
Post by Zmptz »
thank you thank you thank you
Spot on!
The American dynamics camera moves including the STX byte into the calculation created the right checksum needed to move the PTZ camera.
I will share the script on this forum as a separate topic and title.
Once again thank you
I'll create a pull request on our github site so it gets fixed upstream.
https://github.com/ZoneMinder/ZoneMinder/pull/1249
Zmptz
Post by Zmptz »
Hello
Reporting back Pan Tilt controls are working fine.
I notice there are no function over Zoom and focus.
Same as before i can control by manually entering the commands. but no by ZM controls however Zoom wide does work.
what's the difference between SetZoomspeed and zoomcontele
reason I'm asking is when i do zoomwide the function work fine
2016-01-26 19:20:53.501660	zmcontrol		5226	DBG 	Tx: a0 00 00 25 00 00 af 2a [8]     zmcontrol.pl
2016-01-26 19:20:53.410240	zmcontrol		5226	DBG 	Set Zoom Speed 0	  zmcontrol.pl
2016-01-26 19:20:53.334040	zmcontrol		5226	DBG	        Tx: a0 00 00 00 00 00 af 0f [8]   zmcontrol.pl
2016-01-26 19:20:53.242230	zmcontrol		5226	DBG 	Stop                                          	zmcontrol.pl
2016-01-26 19:20:53.172270	zmcontrol		5226	DBG	        Zoom Stop	           zmcontrol.pl
2016-01-26 19:20:52.955150	zmcontrol		5226	DBG 	Tx: a0 00 00 20 00 00 af 2f [8]	zmcontrol.pl
2016-01-26 19:20:52.776880	zmcontrol		5226	DBG	        Tx: a0 00 00 25 00 1c af 36 [8]	zmcontrol.pl
2016-01-26 19:20:52.687570	zmcontrol		5226	DBG 	Set Zoom Speed 28	                zmcontrol.pl
2016-01-26 19:20:52.599430	zmcontrol		5226	DBG	        Zoom Wide
Zmptz
Post by Zmptz »
I've look at the Pelcop script over and over again but can not font a solution to this problem of tele zoom not working and zoom wide working. The coding is same as Pelcod. Is there anyone else using Pelcop script with zoom tell working?
Zmptz
Post by Zmptz »
hi I'm back on this zoom issue for the pelcop
I notice on the zmcontrol.pl file that with the file it doesnt mention any zoom command.
#!/usr/bin/perl -wT
# ZoneMinder Control Script, $Date$, $Revision$
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA  02111-1307, USA.
# This script continuously monitors the recorded events for the given
# monitor and applies any filters which would delete and/or upload
# matching events
use strict;
use lib '/usr/share/perl/5.20.2'; # Include custom perl install path
use ZoneMinder;
use Getopt::Long;
use POSIX qw/strftime EPIPE/;
use Socket;
#use Data::Dumper;
use Module::Load::Conditional qw{can_load};;
use constant MAX_CONNECT_DELAY => 10;
use constant MAX_COMMAND_WAIT => 1800;
$| = 1;
$ENV{PATH}  = '/bin:/usr/bin';
$ENV{SHELL} = '/bin/sh' if exists $ENV{SHELL};
delete @ENV{qw(IFS CDPATH ENV BASH_ENV)};
sub Usage
    print( "
Usage: zmcontrol.pl --id <monitor_id> --command=<command> <various options>
    exit();
logInit();
my $arg_string = join( " ", @ARGV );
my $id;
my %options;
if ( !GetOptions(
    'id=i'=>\$id,
    'command=s'=>\$options{command},
    'xcoord=i'=>\$options{xcoord},
    'ycoord=i'=>\$options{ycoord},
    'speed=i'=>\$options{speed},
    'step=i'=>\$options{step},
    'panspeed=i'=>\$options{panspeed},
    'tiltspeed=i'=>\$options{tiltspeed},
    'panstep=i'=>\$options{panstep},
    'tiltstep=i'=>\$options{tiltstep},
    'preset=i'=>\$options{preset},
    'autostop'=>\$options{autostop},
    Usage();
if ( !$id || !$options{command} )
    print( STDERR "Please give a valid monitor id and command\n" );
    Usage();
( $id ) = $id =~ /^(\w+)$/;
Debug( $arg_string );
my $sock_file = $Config{ZM_PATH_SOCKS}.'/zmcontrol-'.$id.'.sock';
socket( CLIENT, PF_UNIX, SOCK_STREAM, 0 ) or Fatal( "Can't open socket: $!" );
my $saddr = sockaddr_un( $sock_file );
my $server_up = connect( CLIENT, $saddr );
if ( !$server_up )
    # The server isn't there
    my $monitor = zmDbGetMonitorAndControl( $id );
    if ( !$monitor )
        Fatal( "Unable to load control data for monitor $id" );
    my $protocol = $monitor->{Protocol};
    if ( -x $protocol )
        # Protocol is actually a script!
        # Holdover from previous versions
        my $command .= $protocol.' '.$arg_string;
        Debug( $command."\n" );
        my $output = qx($command);
        my $status = $? >> 8;
        if ( $status || logDebugging() )
            chomp( $output );
            Debug( "Output: $output\n" );
        if ( $status )
            Error( "Command '$command' exited with status: $status\n" );
            exit( $status );
        exit( 0 );
    Info( "Starting control server $id/$protocol" );
    close( CLIENT );
	if ( ! can_load( modules => { "ZoneMinder::Control::$protocol" => undef } ) ) {
		Fatal("Can't load ZoneMinder::Control::$protocol");
    if ( my $cpid = fork() )
        logReinit();
        # Parent process just sleep and fall through
        socket( CLIENT, PF_UNIX, SOCK_STREAM, 0 ) or die( "Can't open socket: $!" );
        my $attempts = 0;
        while (!connect( CLIENT, $saddr ))
            $attempts++;
            Fatal( "Can't connect: $!" ) if ($attempts > MAX_CONNECT_DELAY);
            sleep(1);
    elsif ( defined($cpid) )
        close( STDOUT );
        close( STDERR );
        setpgrp();
        logReinit();
        Info( "Control server $id/$protocol starting at ".strftime( '%y/%m/%d %H:%M:%S', localtime() ) );
        $0 = $0." --id $id";
        my $control = "ZoneMinder::Control::$protocol"->new( $id );
        my $control_key = $control->getKey();
        $control->loadMonitor();
        $control->open();
        socket( SERVER, PF_UNIX, SOCK_STREAM, 0 ) or Fatal( "Can't open socket: $!" );
        unlink( $sock_file );
        bind( SERVER, $saddr ) or Fatal( "Can't bind: $!" );
        listen( SERVER, SOMAXCONN ) or Fatal( "Can't listen: $!" );
        my $rin = '';
        vec( $rin, fileno(SERVER), 1 ) = 1;
        my $win = $rin;
        my $ein = $win;
        my $timeout = MAX_COMMAND_WAIT;
        while( 1 )
            my $nfound = select( my $rout = $rin, undef, undef, $timeout );
            if ( $nfound > 0 )
                if ( vec( $rout, fileno(SERVER), 1 ) )
                    my $paddr = accept( CLIENT, SERVER );
                    my $message = <CLIENT>;
                    next if ( !$message );
                    my $params = jsonDecode( $message );
                    #Debug( Dumper( $params ) );
                    my $command = $params->{command};
                    $control->$command( $params );
                    close( CLIENT );
                else
                    Fatal( "Bogus descriptor" );
            elsif ( $nfound < 0 )
                if ( $! == EPIPE )
                    Error( "Can't select: $!" );
                else
                    Fatal( "Can't select: $!" );
            else
                #print( "Select timed out\n" );
                last;
        Info( "Control server $id/$protocol exiting at ".strftime( '%y/%m/%d %H:%M:%S', localtime() ) );
        $control->close();
        exit( 0 );
    else
        Fatal( "Can't fork: $!" );
# The server is there, connect to it
#print( "Writing commands\n" );
CLIENT->autoflush();
my $message = jsonEncode( \%options );
print( CLIENT $message );
shutdown( CLIENT, 1 );
exit( 0 );
Location Get Option
if ( !GetOptions(
'id=i'=>\$id,
Do I need to add something here to make it work?
