Foscam problem
Foscam problem
I recently bought a camera. It says on the box it is a S06 1080PWIFI
It responds to the foscam command set, so I assume it is a foscam or equivalent.
I have tried to configure it using zoneminder to no avail. I set it as a remote camera, using HTTP/Simple, with the remote host name as the IP, the port as 80 and the path videostream.cgi?user=zoneminder&pwd=zoneminder
I also set up a user on the camera with the user details as above.
I tried also &rate=0
But nothing.
Can anyone shed some light?
If I go to http://ipaddress/get_params.cgi I get a listing of all the camera params, and I can see the user I set up.
But nothing.
Re: Foscam problem
2016-01-23 23:40:03.402785 zmc_m1 3261 WAR Unable to capture image, retrying zm_remote_camera_http.cpp 1105
2016-01-23 23:40:03.269905 zmc_m1 3261 ERR Connection dropped by remote end zm_remote_camera_http.cpp 933
2016-01-23 23:40:03.184559 zmc_m1 3261 WAR Select timed out zm_remote_camera_http.cpp 156
2016-01-23 23:40:00.616439 zmc_m1 3261 WAR Unable to capture image, retrying zm_remote_camera_http.cpp 1105
2016-01-23 23:40:00.583164 zmc_m1 3261 ERR Connection dropped by remote end zm_remote_camera_http.cpp 933
2016-01-23 23:40:00.516557 zmc_m1 3261 WAR Select timed out zm_remote_camera_http.cpp 156
Re: Foscam problem
Found this link, followed the instructions.
Monitor entry now goes green
But still nothing in the viewer. CGI is enabled on the web server.
Re: Foscam problem
Still getting those errors in the error log....
Can anyone help?
Can anyone help?
Re: Foscam problem
core debug: adding item `http://192.168.0.28/videostream.cgi?user=admin&pwd=' ( http://192.168.0.28/videostream.cgi?user=admin&pwd= )
core debug: processing request item: http://192.168.0.28/videostream.cgi?user=admin&pwd=, node: null, skip: 0
core debug: rebuilding array of current - root Playlist
core debug: rebuild done - 2 items, index 1
core debug: starting playback of the new playlist item
core debug: resyncing on http://192.168.0.28/videostream.cgi?user=admin&pwd=
core debug: http://192.168.0.28/videostream.cgi?user=admin&pwd= is at 1
core debug: creating new input thread
core debug: Creating an input for 'http://192.168.0.28/videostream.cgi?user=admin&pwd='
core debug: meta ok for (null), need to fetch art
core debug: looking for meta fetcher module matching "any": 1 candidates
core debug: requesting art for http://192.168.0.28/videostream.cgi?user=admin&pwd=
core debug: using timeshift granularity of 50 MiB, in path 'C:\Users\SUITY_~1\AppData\Local\Temp'
lua debug: Trying Lua scripts in C:\Users\suity_000\AppData\Roaming\vlc\lua\meta\fetcher
core debug: `http://192.168.0.28/videostream.cgi?user=admin&pwd=' gives access `http' demux `' path `192.168.0.28/videostream.cgi?user=admin&pwd='
core debug: specified demux `any'
lua debug: Trying Lua scripts in C:\Program Files\VideoLAN\VLC\lua\meta\fetcher
core debug: creating demux: access='http' demux='any' location='192.168.0.28/videostream.cgi?user=admin&pwd=' file='\\192.168.0.28\videostream.cgi?user=admin&pwd='
core debug: looking for access_demux module matching "http": 12 candidates
core debug: no access_demux modules matched
core debug: creating access 'http' location='192.168.0.28/videostream.cgi?user=admin&pwd=', path='\\192.168.0.28\videostream.cgi?user=admin&pwd='
core debug: looking for access module matching "http": 21 candidates
lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\fetcher\tvrage.luac
http debug: querying proxy for http://192.168.0.28/videostream.cgi?user=admin&pwd=
http debug: no proxy
http debug: http: server='192.168.0.28' port=80 file='/videostream.cgi?user=admin&pwd='
core debug: net: connecting to 192.168.0.28 port 80
lua debug: skipping script (unmatched scope) C:\Program Files\VideoLAN\VLC\lua\meta\fetcher\tvrage.luac
core debug: no meta fetcher modules matched
core debug: searching art for http://192.168.0.28/videostream.cgi?user=admin&pwd=
core debug: looking for art finder module matching "any": 2 candidates
lua debug: Trying Lua scripts in C:\Users\suity_000\AppData\Roaming\vlc\lua\meta\art
lua debug: Trying Lua scripts in C:\Program Files\VideoLAN\VLC\lua\meta\art
lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\art\00_musicbrainz.luac
lua debug: skipping script (unmatched scope) C:\Program Files\VideoLAN\VLC\lua\meta\art\00_musicbrainz.luac
lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\art\01_googleimage.luac
lua debug: skipping script (unmatched scope) C:\Program Files\VideoLAN\VLC\lua\meta\art\01_googleimage.luac
lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\art\02_frenchtv.luac
lua debug: skipping script (unmatched scope) C:\Program Files\VideoLAN\VLC\lua\meta\art\02_frenchtv.luac
lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\art\03_lastfm.luac
lua debug: skipping script (unmatched scope) C:\Program Files\VideoLAN\VLC\lua\meta\art\03_lastfm.luac
core debug: no art finder modules matched
core debug: using meta fetcher module "lua"
core debug: removing module "lua"
core debug: art not found for http://192.168.0.28/videostream.cgi?user=admin&pwd=
core debug: connection succeeded (socket = 1392)
http debug: protocol 'HTTP' answer code 200
http debug: Server: IPCamera
http error: malformed header line: GMT
http debug: switching to HTTP version 1.0
qt4 debug: IM: Setting an input
access_mms debug: HTTP reply 'HTTP/1.1 200 OK'
access_mms error: malformed header line: GMT
core debug: no access modules matched
core error: open of `http://192.168.0.28/videostream.cgi?user=admin&pwd=' failed
core debug: dead input
core debug: changing item without a request (current 1/2)
core debug: nothing to play
qt4 debug: IM: Deleting the input
Re: Foscam problem
OK so I have it working in VLC, very good quality video @ 1280x720px
The working URL is
Any idea how to hook this up in ZM?
I had a try and in the error log I am getting :
I checked in the settings and this string is set for FFMPEG_FORMATS
So it looks like it should be a recognised format. Where am I going wrong?
The working URL is
http://192.168.0.28:80/videostream.asf?user=admin&pwd=
2016-01-24 13:52:04.751183 zmc_m2 3286 ERR Unable to get response zm_remote_camera_http.cpp 1110
2016-01-24 13:52:04.723262 zmc_m2 3286 ERR Unrecognised content type 'video/x-ms-asf-stream' zm_remote_camera_http.cpp 812
2016-01-24 13:52:04.659204 zmc_m2 3286 ERR Unable to get response zm_remote_camera_http.cpp 1110
2016-01-24 13:52:04.630433 zmc_m2 3286 ERR Unrecognised content type 'video/x-ms-asf-stream' zm_remote_camera_http.cpp 812
2016-01-24 13:52:04.559237 zmc_m2 3286 ERR Unable to get response zm_remote_camera_http.cpp 1110
2016-01-24 13:52:04.521110 zmc_m2 3286 ERR Unrecognised content type 'video/x-ms-asf-stream' zm_remote_camera_http.cpp 812
2016-01-24 13:52:04.442362 zmc_m2 3286 ERR Unable to get response zm_remote_camera_http.cpp 1110
2016-01-24 13:52:04.415636 zmc_m2 3286 ERR Unrecognised content type 'video/x-ms-asf-stream' zm_remote_camera_http.cpp 812
2016-01-24 13:52:04.325257 zmc_m2 3286 ERR Unable to get response zm_remote_camera_http.cpp 1110
2016-01-24 13:52:04.240652 zmc_m2 3286 ERR Unrecognised content type 'video/x-ms-asf-stream' zm_remote_camera_http.cpp 812
mpg mpeg wmv [b]asf[/b] avi* mov swf 3gp**
Re: Foscam problem
Not getting much help ....
I changed the camera to ffmpeg, this is giving me different and more encouraging errors
The /tmp/zm directory does exist and is owned by www-data.
Why is this happening?
2016-01-24 15:01:12.857417 web_js 2379 ERR getStreamCmdResponse stream error: socket_sendto( /tmp/zm/zms-354415s.sock ) failed: No such file or directory ?view=watch
2016-01-24 15:01:12.444439 web_php 2379 ERR socket_sendto( /tmp/zm/zms-354415s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2344
2016-01-24 15:00:59.573301 web_js 2379 ERR getStreamCmdResponse stream error: socket_sendto( /tmp/zm/zms-354415s.sock ) failed: No such file or directory ?view=watch
2016-01-24 15:00:59.342875 web_php 2379 ERR socket_sendto( /tmp/zm/zms-354415s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2344
2016-01-24 15:00:58.259153 zma_m2 2733 INF FrontHall: 2000 - Processing at 2.95 fps zm_monitor.cpp 1147
2016-01-24 15:00:46.965345 zma_m2 2733 INF FrontHall: 1935 - Closing event 13, alarm end zm_monitor.cpp 1496
2016-01-24 15:00:46.880563 zma_m2 2733 INF FrontHall: 1935 - Left alarm state (13) - 65(8) images zm_monitor.cpp 1491
2016-01-24 15:00:46.539547 web_js 2379 ERR getStreamCmdResponse stream error: socket_sendto( /tmp/zm/zms-354415s.sock ) failed: No such file or directory ?view=watch
2016-01-24 15:00:46.218443 web_php 2379 ERR socket_sendto( /tmp/zm/zms-354415s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2344
2016-01-24 15:00:37.953528 zma_m2 2733 INF FrontHall: 1910 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:00:36.897928 zma_m2 2733 INF FrontHall: 1908 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:00:35.617671 zma_m2 2733 INF FrontHall: 1906 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:00:35.314385 zma_m2 2733 INF FrontHall: 1905 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:00:35.017004 zma_m2 2733 INF FrontHall: 1904 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:00:34.599036 zma_m2 2733 INF FrontHall: 1902 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:00:34.422309 zma_m2 2733 INF FrontHall: 1900 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:00:34.276517 zma_m2 2733 INF FrontHall: 1899 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:00:34.082631 zma_m2 2733 INF FrontHall: 1897 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:00:33.557844 zma_m2 2733 INF FrontHall: 1895 - Opening new event 13, alarm start zm_monitor.cpp 1448
2016-01-24 15:00:33.505394 zma_m2 2733 INF FrontHall: 1895 - Gone into alarm state zm_monitor.cpp 1428
2016-01-24 15:00:33.212653 web_js 2379 ERR getStreamCmdResponse stream error: socket_sendto( /tmp/zm/zms-354415s.sock ) failed: No such file or directory ?view=watch
Re: Foscam problem
I think it's nearly working.
I still don't see anything on the screen, broken img link, but I do see it capturing events.
Again, if anyone can help I would be grateful as I am now out of ideas having followed all the forum posts I can find in a google search for these errors.
System Log
Updated: Sun 24th Jan, 3:14pm State: alarm Total: 49623 Available: 49623 Displaying: 200
Filter log - Component -----web_jsweb_phpzmauditzma_m1zma_m2zmcontrolzmc_m1zmc_m2zmdczmfilterzmpkgzmszmupdatezmwatch PID -----163616401652165616661680168316871691169817021704171017131723173017331736174217511787183619611969197019711972213421512154217421802191220222092212222622452253226622722277228623182319232023212324237823792380238123822433243524392460247724912505250925202523256525792581258425862589259125922593259425952609261326222627263426442649265726612665268526862687269126982705270627082709272127262728273327442746274827622767276927752783278527872792280028022804280628122813281728182821282528262834283628412850285128532857286028672880288128832886290129022904290529132917292929312934294429492955297029712975298529902993299529973001300430063008301030283030303230343035303630373054305730603074307830893092309830993101310231043106310931113113311431153119312031213122314231473149316231643166316831693174318531883190319531993205320732083209321232143216321732183220322232233225322632273233324132443245325032613277327932863291329233023306331433163317332033213324333133363338334033553371339534003411341734193421342334253428343034323449345434613471347334883490350735123527352935313533353535373539356135663573358335853587358935913605360736243631364436463648365036673672368736893691369336953712371737213732373437483767377237733782379938023808381038123829383438463854385938663878388338843902390739153926393139323935396339653967397039873992399439964024404140464048405340704073408240844086408840904107411241274129413041494154415841614173417541774194419942014217421942604262426442664282428442884304430743114330433343374353435643604379438243864402440644214428443244474451445544704477448144964500450445194526453045454549455445694576458245974603460746224629463947124717472151105127514051645202522052255230524252445246524852515253525452755307532853785536557855835599948895219536956095669572124051240612407124091249312516125171251812519125591261612681126851270112705127081271012713127291273312749127501275312756127591276212765127681277112774127771278012783127861278912792127951279812801128041280712823128261282912832128351283812841128451284812864128671287012873128891289312910129111291412917129201293612939129421294512948129641296812982129851298812991129941299713000130031301913022130251302813031130341303713040130431304613049130521305513058130621306513068130711307513078130811308413100131031310613109131121312813132131461314913152131601317113174131771318013183131861318913192132081321413230132311323213248132521326613269132721327613279132821329813302133161331913334133371334013343133461335513358133611336713370133731337913382133981340113404134071341313416134191342213425134281343113434134371344013443134591346213465134681347113474134771348013483134861348913492134951349813514135171352013523135261352913545135491356313566135691357213575135781358113584135881359113594135971360113604136071361013613136161361913622136251362813631136341365013653136561365913662136651368113684136871369013693136961369913702137051370813711137141371713720137231372613729137321373513738137411374413747137631376613769137721377513778137941379713800138031380613809138131381613819138221383513838138411384413847138501385313856138591386213865138681387113887138901389313896138991390213918139211392413927139301393313936139391394213945139481395213955139581396113964139671397013973139761397913982139851400114005140081401114014140171403314036140391404214045140481405214055140581406114064140791408214085140881409114094140971410014103141061411114114141171413314136141391414614149141661417214175141781418414187141901419314196141991420214205142081421114214142171422014223142261422914232142351423814241142571426014263142661427214288142911429414297143001430314306143101431314316143191432314326143291433214335143381434114344143471436314369143701438414387143901439314410144131441614419144221442514428144311443414437144401444314446144491445214455144581446114464144671447014473144761447914482144851450114504145071452114527145301453314536145391454214545145481455114554145571456114564145671457014573145761459214598145991461514618146191462014623146261462914632146351463814641146441464714663146661466914672146751467814681146841468714690146931469614699147021470514708147121471614732147351473814741147441474714750147531475614759147621477814781147841478714790147931479614799148021480514808148241482814842148451484914852148551485814873148761487914882148851488814891148941489714900149031491914923149371494014943149601496314966149731497614979149841498814991149971500015003150061500915012150151501815021150241502715030150331503615039150421504515048150641506715070150861508915092150951509815101151041510715110151131511615120151241512715130151341513715140151431514615149151521515515158151611516415180151961520015216152171522015236152391525515259152751527915293152961529915302153051530815311153141531715320153231532615329153321533515338153411534415347153501535315356153591536215365153681537115388153911540715410154281544715448154491545215455154581546115464154681547115474154771548015483154861548915505155091552515526155291553215535155381554115544155471555015553155691557215575155781558115585155881559115607156111562515628156311563415637156401564315646156501566615670156861568715690156931569615699157021570515708157111571415717157201573615740157671577015786157891579215795157981580115804158071581015813158161582015823158261582915844158471585015853158561585915862158651586815875158801588315886159021592115924159271593015933159361593915942159451594815952159551595815961159641596715970159731597615979159821598516001160051600816022160251602816031160341603716053160561605916065160681607116074160771608016083160861609016093160961609916103161061610916112161281613116148161491615216168161721618816189161921620816212162281622916232162351623816241162441625016263162661626916272162751627816281162841628716290162941629716300163031630616309163121631516318163211632416327163431634616349163521635516358163611637716393163971641316414164171642016423164261642916432164351643816442164451644816451164541645716460164631646616469164721648816492165061650916512165151653116535165361653916549165541655716558165611656216563165661656716574165871659016593165941659716600166031660616609166121661516616166191662216625166281663216635166381664116644166471665016653166561665916662166651666616669166721667516691166941669716700167031670616709167121671516718167221672516728167311674616749167521675516758167611676416767167701677316776167791678216785167861678916805168081681116819168221682516828168331683716840168431684616849168521685516858168611686416867168701687316876168791688216885168881689116894168971691316916169191692216925169281693116934169371694016944169471695016953169571696016963169661696916972169751697816981169841698716990169931699616997170001701617019170221702517028170311703417037170401704317046170491705217055170581706117064170671707017073170761707917082170851708817091170941709717100171161711917123171261712917132171351713817141171441714817151171541715717173171761717917182171851718817191171941719717200172031720617209172121721317216172191723517238172411724417247172501725317256172591726217265172681727117287172911729417297173001730317306173091731217315173181732117324173271733017333173491735217355173581736117364173671737017373173771738017383173861741417417174201742317426174311743417437174401744717511 Level ---INFFATERRWAR File ------/usr/share/zoneminder/includes/functions.php?view=console?view=event?view=watchhttp://192.168.0.45/zm/skins/classic/js/skin.jszma.cppzmaudit.plzmc.cppzmcontrol.plzmdc.plzmfilter.plzmpkg.plzmupdate.plzmwatch.plzm_event.cppzm_ffmpeg_camera.cppzm_monitor.cppzm_remote_camera.cppzm_remote_camera_http.cppzm_signal.cpp Line ----40537798105106112115120137156162195260398478483556570614619726812933938108211051110114713121428144814751484149114962344275527834012
Date/Time
Component
PID
Level
Message
File
Line
2016-01-24 15:14:03.700157 zma_m2 3217 INF FrontHall: 1448 - Closing event 28, alarm end zm_monitor.cpp 1496
2016-01-24 15:14:03.591144 zma_m2 3217 INF FrontHall: 1448 - Left alarm state (28) - 53(2) images zm_monitor.cpp 1491
2016-01-24 15:14:01.846034 web_js 3314 ERR getStreamCmdResponse stream error: socket_sendto( /tmp/zm/zms-552616s.sock ) failed: No such file or directory ?view=watch
2016-01-24 15:14:01.541868 web_php 3314 ERR socket_sendto( /tmp/zm/zms-552616s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2344
2016-01-24 15:14:01.375292 zma_m2 3217 INF FrontHall: 1423 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:14:01.255531 zma_m2 3217 INF FrontHall: 1422 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:14:01.159114 zma_m2 3217 INF FrontHall: 1421 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:14:00.718826 zma_m2 3217 INF FrontHall: 1420 - Opening new event 28, alarm start zm_monitor.cpp 1448
2016-01-24 15:14:00.316915 zma_m2 3217 INF FrontHall: 1420 - Gone into alarm state zm_monitor.cpp 1428
2016-01-24 15:13:56.592887 zma_m2 3217 INF FrontHall: 1346 - Closing event 27, alarm end zm_monitor.cpp 1496
2016-01-24 15:13:56.558099 zma_m2 3217 INF FrontHall: 1346 - Left alarm state (27) - 117(23) images zm_monitor.cpp 1491
2016-01-24 15:13:54.563727 zma_m2 3217 INF FrontHall: 1321 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:54.120043 zma_m2 3217 INF FrontHall: 1319 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:53.846722 zma_m2 3217 INF FrontHall: 1316 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:53.477133 zma_m2 3217 INF FrontHall: 1313 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:53.033226 zma_m2 3217 INF FrontHall: 1311 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:52.893680 zma_m2 3217 INF FrontHall: 1310 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:52.810329 zma_m2 3217 INF FrontHall: 1309 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:52.584080 zma_m2 3217 INF FrontHall: 1307 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:52.432315 zma_m2 3217 INF FrontHall: 1306 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:52.198721 zma_m2 3217 INF FrontHall: 1305 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:51.961331 zma_m2 3217 INF FrontHall: 1302 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:51.630733 zma_m2 3217 INF FrontHall: 1300 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:51.476307 zma_m2 3217 INF FrontHall: 1298 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:51.355055 zma_m2 3217 INF FrontHall: 1297 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:51.189512 zma_m2 3217 INF FrontHall: 1296 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:51.087624 zma_m2 3217 INF FrontHall: 1295 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:51.011032 zma_m2 3217 INF FrontHall: 1294 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:50.903143 zma_m2 3217 INF FrontHall: 1293 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:49.493400 zma_m2 3217 INF FrontHall: 1272 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:49.375236 zma_m2 3217 INF FrontHall: 1271 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:49.278907 zma_m2 3217 INF FrontHall: 1270 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:49.090027 zma_m2 3217 INF FrontHall: 1269 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:48.828951 web_js 3277 ERR getStreamCmdResponse stream error: socket_sendto( /tmp/zm/zms-552616s.sock ) failed: No such file or directory ?view=watch
2016-01-24 15:13:48.788902 zma_m2 3217 INF FrontHall: 1268 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:48.461961 web_php 3277 ERR socket_sendto( /tmp/zm/zms-552616s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2344
2016-01-24 15:13:48.415629 zma_m2 3217 INF FrontHall: 1266 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:48.302818 zma_m2 3217 INF FrontHall: 1265 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:48.152354 zma_m2 3217 INF FrontHall: 1264 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:48.100210 zmc_m2 3212 INF FrontHall: 2000 - Capturing at 16.67 fps zm_monitor.cpp 2783
2016-01-24 15:13:48.060012 zma_m2 3217 INF FrontHall: 1263 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:47.933294 zma_m2 3217 INF FrontHall: 1262 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:47.735588 zma_m2 3217 INF FrontHall: 1259 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:47.624889 zma_m2 3217 INF FrontHall: 1258 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:47.516405 zma_m2 3217 INF FrontHall: 1257 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:47.399114 zma_m2 3217 INF FrontHall: 1256 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:47.315250 zma_m2 3217 INF FrontHall: 1255 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:46.714414 zma_m2 3217 INF FrontHall: 1254 - Opening new event 27, alarm start zm_monitor.cpp 1448
2016-01-24 15:13:46.535278 zma_m2 3217 INF FrontHall: 1254 - Gone into alarm state zm_monitor.cpp 1428
2016-01-24 15:13:45.121714 web_php 3292 ERR Timed out waiting for msg /usr/share/zoneminder/includes/functions.php 2344
2016-01-24 15:13:41.478927 zma_m2 3217 INF FrontHall: 1146 - Closing event 26, alarm end zm_monitor.cpp 1496
2016-01-24 15:13:41.449084 zma_m2 3217 INF FrontHall: 1146 - Left alarm state (26) - 59(5) images zm_monitor.cpp 1491
2016-01-24 15:13:39.922991 zma_m2 3217 INF FrontHall: 1121 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:39.808154 zma_m2 3217 INF FrontHall: 1120 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:39.700222 zma_m2 3217 INF FrontHall: 1119 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:39.526200 zma_m2 3217 INF FrontHall: 1118 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:38.804551 zma_m2 3217 INF FrontHall: 1116 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:38.687762 zma_m2 3217 INF FrontHall: 1115 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:38.572042 zma_m2 3217 INF FrontHall: 1114 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:38.120194 zma_m2 3217 INF FrontHall: 1112 - Opening new event 26, alarm start zm_monitor.cpp 1448
2016-01-24 15:13:38.053563 zma_m2 3217 INF FrontHall: 1112 - Gone into alarm state zm_monitor.cpp 1428
2016-01-24 15:13:37.953119 zma_m2 3217 INF FrontHall: 1111 - Closing event 25, alarm end zm_monitor.cpp 1496
2016-01-24 15:13:37.918907 zma_m2 3217 INF FrontHall: 1111 - Left alarm state (25) - 51(1) images zm_monitor.cpp 1491
2016-01-24 15:13:36.022869 zma_m2 3217 INF FrontHall: 1086 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:35.722228 zma_m2 3217 INF FrontHall: 1085 - Opening new event 25, alarm start zm_monitor.cpp 1448
2016-01-24 15:13:35.585784 zma_m2 3217 INF FrontHall: 1085 - Gone into alarm state zm_monitor.cpp 1428
2016-01-24 15:13:35.270355 zms 3331 ERR Unable to send raw frame 1: Broken pipe zm_event.cpp 1312
2016-01-24 15:13:35.052688 zms 3331 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-01-24 15:13:33.051138 web_js 3279 ERR getStreamCmdResponse stream error: socket_sendto( /tmp/zm/zms-552616s.sock ) failed: No such file or directory ?view=watch
2016-01-24 15:13:32.762644 web_php 3279 ERR socket_sendto( /tmp/zm/zms-552616s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2344
2016-01-24 15:13:31.413526 zma_m2 3217 INF FrontHall: 1000 - Processing at 8.70 fps zm_monitor.cpp 1147
2016-01-24 15:13:31.086218 zma_m2 3217 INF FrontHall: 991 - Closing event 24, alarm end zm_monitor.cpp 1496
2016-01-24 15:13:31.034702 zma_m2 3217 INF FrontHall: 991 - Left alarm state (24) - 51(1) images zm_monitor.cpp 1491
2016-01-24 15:13:28.958066 zma_m2 3217 INF FrontHall: 966 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:28.597403 zma_m2 3217 INF FrontHall: 965 - Opening new event 24, alarm start zm_monitor.cpp 1448
2016-01-24 15:13:28.520472 zma_m2 3217 INF FrontHall: 965 - Gone into alarm state zm_monitor.cpp 1428
2016-01-24 15:13:24.078116 zma_m2 3217 INF FrontHall: 900 - Closing event 23, alarm end zm_monitor.cpp 1496
2016-01-24 15:13:24.042995 zma_m2 3217 INF FrontHall: 900 - Left alarm state (23) - 233(79) images zm_monitor.cpp 1491
2016-01-24 15:13:21.894721 zma_m2 3217 INF FrontHall: 875 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:21.714598 zma_m2 3217 INF FrontHall: 874 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:21.465725 zma_m2 3217 INF FrontHall: 871 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:21.236391 zma_m2 3217 INF FrontHall: 870 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:21.139402 zma_m2 3217 INF FrontHall: 869 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:20.425785 zma_m2 3217 INF FrontHall: 868 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:20.185822 zma_m2 3217 INF FrontHall: 865 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:20.057993 zma_m2 3217 INF FrontHall: 864 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:19.907072 web_js 3279 ERR getStreamCmdResponse stream error: socket_sendto( /tmp/zm/zms-552616s.sock ) failed: No such file or directory ?view=watch
2016-01-24 15:13:19.812288 zma_m2 3217 INF FrontHall: 861 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:19.644408 zma_m2 3217 INF FrontHall: 860 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:19.578605 web_js 3314 ERR getCmdResponse stream error: socket_sendto( /tmp/zm/zms-604730s.sock ) failed: No such file or directory ?view=event
2016-01-24 15:13:19.545579 web_php 3279 ERR socket_sendto( /tmp/zm/zms-552616s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2344
2016-01-24 15:13:19.424977 zma_m2 3217 INF FrontHall: 857 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:19.105474 zma_m2 3217 INF FrontHall: 855 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:18.903255 zma_m2 3217 INF FrontHall: 853 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:18.797802 zma_m2 3217 INF FrontHall: 852 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:18.589087 zma_m2 3217 INF FrontHall: 849 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:18.489698 zma_m2 3217 INF FrontHall: 848 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:18.289345 zma_m2 3217 INF FrontHall: 845 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:18.137620 zma_m2 3217 INF FrontHall: 844 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:17.975593 zma_m2 3217 INF FrontHall: 843 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:17.853700 zma_m2 3217 INF FrontHall: 842 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:17.494675 zma_m2 3217 INF FrontHall: 841 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:16.959052 zma_m2 3217 INF FrontHall: 837 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:16.559259 zma_m2 3217 INF FrontHall: 832 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:16.039798 zma_m2 3217 INF FrontHall: 830 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:16.027156 web_php 3314 ERR socket_sendto( /tmp/zm/zms-604730s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2344
2016-01-24 15:13:15.947254 zma_m2 3217 INF FrontHall: 829 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:15.790517 zma_m2 3217 INF FrontHall: 828 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:15.696784 zma_m2 3217 INF FrontHall: 827 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:15.444116 zma_m2 3217 INF FrontHall: 825 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:15.362922 zma_m2 3217 INF FrontHall: 824 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:15.213779 zma_m2 3217 INF FrontHall: 823 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:15.127362 zma_m2 3217 INF FrontHall: 822 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:15.002081 zma_m2 3217 INF FrontHall: 821 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:14.907217 zma_m2 3217 INF FrontHall: 820 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:14.485639 zma_m2 3217 INF FrontHall: 816 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:14.386139 zma_m2 3217 INF FrontHall: 815 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:14.033214 zms 3324 INF addr2line -e /usr/lib/cgi-bin/nph-zms 0x4cb5ac 0x7fa50ce90340 0x7fa50bb3d517 0x42f389 0x430960 0x40713b 0x7fa50bb21ec5 0x4076cf zm_signal.cpp 106
2016-01-24 15:13:13.799087 zms 3324 INF Backtrace complete, please execute the following command for more information zm_signal.cpp 105
2016-01-24 15:13:13.709557 zms 3324 ERR Backtrace 7: /usr/lib/cgi-bin/nph-zms() [0x4076cf] zm_signal.cpp 98
2016-01-24 15:13:13.623978 zms 3324 ERR Backtrace 6: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7fa50bb21ec5] zm_signal.cpp 98
2016-01-24 15:13:13.557333 zms 3324 ERR Backtrace 5: /usr/lib/cgi-bin/nph-zms() [0x40713b] zm_signal.cpp 98
2016-01-24 15:13:13.521995 zma_m2 3217 INF FrontHall: 811 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:13.465243 zms 3324 ERR Backtrace 4: /usr/lib/cgi-bin/nph-zms() [0x430960] zm_signal.cpp 98
2016-01-24 15:13:13.398418 zms 3324 ERR Backtrace 3: /usr/lib/cgi-bin/nph-zms() [0x42f389] zm_signal.cpp 98
2016-01-24 15:13:13.383869 zma_m2 3217 INF FrontHall: 810 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:13.331293 zms 3324 ERR Backtrace 2: /lib/x86_64-linux-gnu/libc.so.6(+0x3d517) [0x7fa50bb3d517] zm_signal.cpp 98
2016-01-24 15:13:13.264398 zms 3324 ERR Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x10340) [0x7fa50ce90340] zm_signal.cpp 98
2016-01-24 15:13:13.193800 zms 3324 ERR Backtrace 0: /usr/lib/cgi-bin/nph-zms() [0x4cb5ac] zm_signal.cpp 98
2016-01-24 15:13:13.097495 zms 3324 ERR Signal address is (nil), from 0x7fa50bb3d517 zm_signal.cpp 77
2016-01-24 15:13:13.031581 zms 3324 ERR Got signal 11 (Segmentation fault), crashing zm_signal.cpp 53
2016-01-24 15:13:10.920063 zma_m2 3217 INF FrontHall: 794 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:10.773952 zma_m2 3217 INF FrontHall: 793 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:10.573621 zma_m2 3217 INF FrontHall: 792 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:10.346945 zma_m2 3217 INF FrontHall: 791 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:08.900560 zma_m2 3217 INF FrontHall: 787 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:08.798397 zma_m2 3217 INF FrontHall: 786 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:08.697307 zma_m2 3217 INF FrontHall: 785 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:08.618201 zma_m2 3217 INF FrontHall: 784 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:08.408215 zma_m2 3217 INF FrontHall: 782 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:08.246447 zma_m2 3217 INF FrontHall: 780 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:07.946802 zma_m2 3217 INF FrontHall: 779 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:07.575518 zma_m2 3217 INF FrontHall: 776 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:07.176671 zma_m2 3217 INF FrontHall: 774 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:06.993248 zma_m2 3217 INF FrontHall: 772 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:06.881451 zma_m2 3217 INF FrontHall: 771 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:06.524018 zma_m2 3217 INF FrontHall: 768 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:06.374872 zma_m2 3217 INF FrontHall: 767 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:06.004990 zma_m2 3217 INF FrontHall: 760 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:05.812692 zma_m2 3217 INF FrontHall: 759 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:05.716970 zma_m2 3217 INF FrontHall: 758 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:05.586082 web_js 3314 ERR getStreamCmdResponse stream error: socket_sendto( /tmp/zm/zms-552616s.sock ) failed: No such file or directory ?view=watch
2016-01-24 15:13:05.323969 zma_m2 3217 INF FrontHall: 755 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:05.302261 web_php 3314 ERR socket_sendto( /tmp/zm/zms-552616s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2344
2016-01-24 15:13:05.237324 zma_m2 3217 INF FrontHall: 754 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:04.985211 zma_m2 3217 INF FrontHall: 752 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:04.892848 zma_m2 3217 INF FrontHall: 751 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:04.441288 zma_m2 3217 INF FrontHall: 747 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:03.943692 zma_m2 3217 INF FrontHall: 745 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:01.970203 zma_m2 3217 INF FrontHall: 741 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:13:01.270915 zma_m2 3217 INF FrontHall: 730 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:13:01.132168 zma_m2 3217 INF FrontHall: 729 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:12:59.355023 zma_m2 3217 INF FrontHall: 704 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:12:59.237666 zma_m2 3217 INF FrontHall: 703 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:12:58.820687 zma_m2 3217 INF FrontHall: 698 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:12:58.328414 zma_m2 3217 INF FrontHall: 696 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:12:58.239706 zma_m2 3217 INF FrontHall: 695 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:12:58.114938 zma_m2 3217 INF FrontHall: 694 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:12:58.026107 zma_m2 3217 INF FrontHall: 693 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:12:57.742813 zms 3320 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-01-24 15:12:57.402947 zma_m2 3217 INF FrontHall: 692 - Opening new event 23, alarm start zm_monitor.cpp 1448
2016-01-24 15:12:57.137919 zma_m2 3217 INF FrontHall: 692 - Gone into alarm state zm_monitor.cpp 1428
2016-01-24 15:12:48.730915 zmc_m2 3212 INF FrontHall: 1000 - Capturing at 13.89 fps zm_monitor.cpp 2783
2016-01-24 15:12:39.762315 zma_m2 3217 INF FrontHall: 457 - Closing event 22, alarm end zm_monitor.cpp 1496
2016-01-24 15:12:39.730285 zma_m2 3217 INF FrontHall: 457 - Left alarm state (22) - 254(87) images zm_monitor.cpp 1491
2016-01-24 15:12:37.225696 zma_m2 3217 INF FrontHall: 432 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:12:37.096484 zma_m2 3217 INF FrontHall: 431 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:12:36.747574 zma_m2 3217 INF FrontHall: 424 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:12:36.577653 zma_m2 3217 INF FrontHall: 423 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:12:35.869819 zma_m2 3217 INF FrontHall: 417 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:12:35.704645 zma_m2 3217 INF FrontHall: 416 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:12:35.517404 zma_m2 3217 INF FrontHall: 414 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:12:35.394528 zma_m2 3217 INF FrontHall: 413 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:12:35.179029 zma_m2 3217 INF FrontHall: 410 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:12:35.052748 zma_m2 3217 INF FrontHall: 409 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:12:34.919130 zma_m2 3217 INF FrontHall: 408 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:12:34.749931 zma_m2 3217 INF FrontHall: 407 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:12:34.656657 zma_m2 3217 INF FrontHall: 406 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:12:34.465961 zma_m2 3217 INF FrontHall: 405 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:12:34.312891 zma_m2 3217 INF FrontHall: 404 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:12:34.197041 zma_m2 3217 INF FrontHall: 403 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:12:34.114955 zma_m2 3217 INF FrontHall: 402 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:12:33.978515 zma_m2 3217 INF FrontHall: 401 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:12:33.714818 zma_m2 3217 INF FrontHall: 400 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:12:33.602647 zma_m2 3217 INF FrontHall: 399 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:12:33.469623 zma_m2 3217 INF FrontHall: 398 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:12:33.303594 zma_m2 3217 INF FrontHall: 397 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:12:33.212993 zma_m2 3217 INF FrontHall: 396 - Gone into alert state zm_monitor.cpp 1484
2016-01-24 15:12:33.086276 zma_m2 3217 INF FrontHall: 395 - Gone back into alarm state zm_monitor.cpp 1475
2016-01-24 15:12:32.983760 zma_m2 3217 INF FrontHall: 394 - Gone into alert state zm_monitor.cpp 1484
Re: Foscam problem
Still no response. Not a great first impression.
Now, come on guys and gals, today's the day, come on and redeem yourselves with responding to a newcomer's request for help.
- knight-of-ni
Re: Foscam problem
You haven't received a response because you are using a version of ZoneMinder that is obsolete.
ZoneMinder has an incredibly large user base, but there are only a select few who choose to spend their time responding in the forum.
All the cool kids hang out in the 1.28.x forum, and are in the process of migrating to the 1.29.x forum.
You should consider upgrading, but you might want to want a couple more weeks until we release 1.29.0 so you don't have to upgrade twice.
If your camera really does have foscam firmware, then you should be looking at the Foscam documentation in the zoneminder wiki for help.
For an h264 stream, the ffmpeg source type is the one most likely to work. The Remote HTTP/simple method will only work for mjpeg streams.
This means the backend is working, which means whatever settings you were using at the time are the correct ones.2016-01-24 15:00:58.259153 zma_m2 2733 INF FrontHall: 2000 - Processing at 2.95 fps zm_monitor.cpp 1147
When the backend is working (previous message) and you see this error after attempting to open a stream, that means your Apache configuration is not correct. There is a misconfiguration between Apache's Alias directive, the Script Alias directive, and zoneminder's PATH_ZMS variable under options. Because you have not described your system and how you installed zoneminder, I can't tell you exactly how to fix it.2016-01-24 15:00:59.342875 web_php 2379 ERR socket_sendto( /tmp/zm/zms-354415s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2344
