hi I'm back on this zoom issue for the pelcop
I notice on the zmcontrol.pl file that with the file it doesnt mention any zoom command.
#!/usr/bin/perl -wT
# ZoneMinder Control Script, $Date$, $Revision$
# This script continuously monitors the recorded events for the given
# monitor and applies any filters which would delete and/or upload
# matching events
use strict;
use lib '/usr/share/perl/5.20.2'; # Include custom perl install path
use ZoneMinder;
use Getopt::Long;
use POSIX qw/strftime EPIPE/;
use Socket;
#use Data::Dumper;
use Module::Load::Conditional qw{can_load};;
use constant MAX_CONNECT_DELAY => 10;
use constant MAX_COMMAND_WAIT => 1800;
$| = 1;
$ENV{PATH} = '/bin:/usr/bin';
$ENV{SHELL} = '/bin/sh' if exists $ENV{SHELL};
delete @ENV{qw(IFS CDPATH ENV BASH_ENV)};
sub Usage
print( "
Usage: zmcontrol.pl --id <monitor_id> --command=<command> <various options>
exit();
logInit();
my $arg_string = join( " ", @ARGV );
my $id;
my %options;
if ( !GetOptions(
'id=i'=>\$id,
'command=s'=>\$options{command},
'xcoord=i'=>\$options{xcoord},
'ycoord=i'=>\$options{ycoord},
'speed=i'=>\$options{speed},
'step=i'=>\$options{step},
'panspeed=i'=>\$options{panspeed},
'tiltspeed=i'=>\$options{tiltspeed},
'panstep=i'=>\$options{panstep},
'tiltstep=i'=>\$options{tiltstep},
'preset=i'=>\$options{preset},
'autostop'=>\$options{autostop},
Usage();
if ( !$id || !$options{command} )
print( STDERR "Please give a valid monitor id and command\n" );
Usage();
( $id ) = $id =~ /^(\w+)$/;
Debug( $arg_string );
my $sock_file = $Config{ZM_PATH_SOCKS}.'/zmcontrol-'.$id.'.sock';
socket( CLIENT, PF_UNIX, SOCK_STREAM, 0 ) or Fatal( "Can't open socket: $!" );
my $saddr = sockaddr_un( $sock_file );
my $server_up = connect( CLIENT, $saddr );
if ( !$server_up )
# The server isn't there
my $monitor = zmDbGetMonitorAndControl( $id );
if ( !$monitor )
Fatal( "Unable to load control data for monitor $id" );
my $protocol = $monitor->{Protocol};
if ( -x $protocol )
# Protocol is actually a script!
# Holdover from previous versions
my $command .= $protocol.' '.$arg_string;
Debug( $command."\n" );
my $output = qx($command);
my $status = $? >> 8;
if ( $status || logDebugging() )
chomp( $output );
Debug( "Output: $output\n" );
if ( $status )
Error( "Command '$command' exited with status: $status\n" );
exit( $status );
exit( 0 );
Info( "Starting control server $id/$protocol" );
close( CLIENT );
if ( ! can_load( modules => { "ZoneMinder::Control::$protocol" => undef } ) ) {
Fatal("Can't load ZoneMinder::Control::$protocol");
if ( my $cpid = fork() )
logReinit();
# Parent process just sleep and fall through
socket( CLIENT, PF_UNIX, SOCK_STREAM, 0 ) or die( "Can't open socket: $!" );
my $attempts = 0;
while (!connect( CLIENT, $saddr ))
$attempts++;
Fatal( "Can't connect: $!" ) if ($attempts > MAX_CONNECT_DELAY);
sleep(1);
elsif ( defined($cpid) )
close( STDOUT );
close( STDERR );
setpgrp();
logReinit();
Info( "Control server $id/$protocol starting at ".strftime( '%y/%m/%d %H:%M:%S', localtime() ) );
$0 = $0." --id $id";
my $control = "ZoneMinder::Control::$protocol"->new( $id );
my $control_key = $control->getKey();
$control->loadMonitor();
$control->open();
socket( SERVER, PF_UNIX, SOCK_STREAM, 0 ) or Fatal( "Can't open socket: $!" );
unlink( $sock_file );
bind( SERVER, $saddr ) or Fatal( "Can't bind: $!" );
listen( SERVER, SOMAXCONN ) or Fatal( "Can't listen: $!" );
my $rin = '';
vec( $rin, fileno(SERVER), 1 ) = 1;
my $win = $rin;
my $ein = $win;
my $timeout = MAX_COMMAND_WAIT;
while( 1 )
my $nfound = select( my $rout = $rin, undef, undef, $timeout );
if ( $nfound > 0 )
if ( vec( $rout, fileno(SERVER), 1 ) )
my $paddr = accept( CLIENT, SERVER );
my $message = <CLIENT>;
next if ( !$message );
my $params = jsonDecode( $message );
#Debug( Dumper( $params ) );
my $command = $params->{command};
$control->$command( $params );
close( CLIENT );
else
Fatal( "Bogus descriptor" );
elsif ( $nfound < 0 )
if ( $! == EPIPE )
Error( "Can't select: $!" );
else
Fatal( "Can't select: $!" );
else
#print( "Select timed out\n" );
last;
Info( "Control server $id/$protocol exiting at ".strftime( '%y/%m/%d %H:%M:%S', localtime() ) );
$control->close();
exit( 0 );
else
Fatal( "Can't fork: $!" );
# The server is there, connect to it
#print( "Writing commands\n" );
CLIENT->autoflush();
my $message = jsonEncode( \%options );
print( CLIENT $message );
shutdown( CLIENT, 1 );
exit( 0 );
Location Get Option
if ( !GetOptions(
'id=i'=>\$id,
Do I need to add something here to make it work?
