"This XML file does not appear to have any style information associated with it."
How might I correct this error message in 'localhost/zm'?
Ubuntu 15.10 running on a Revo. ZM has worked in the past but this is updated software, probably built from source ( have tried various ways to install a current ZM, most of them curl up and die at some point).
Many thanks.
Console display in XML
- knight-of-ni
Re: Console display in XML
We can't possibly give you a detailed answer with what little you've told us.
Start by reading forum rules, which describe how to ask for help:
viewtopic.php?f=32&t=23808
Your likely next step will be to read the appropriate Ubuntu "easy way" documentation found in the Wiki.
In the event you are stuck with this message when you try and view your web console, try to put in the following url
http://your.server.com/zm/?skin=classic
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
That's what it needed.
http://localhost/zm/?skin=classic
results in the XML code being translated to the console display we all know and love, now I can move on to configuring ZM again.
Many thanks for bothering to respond to my question, I appreciate it.
In this case "Asker" is the "Answerer" - thanks.
