API
Ryuk
API
Post by Ryuk »
Hi, I have recently made a server for CCTV and i was wondering if there is a way to install APIs, I found something on the internet but not useful to me.
using 1.26 version.
SteveGilvarry
Re: API
Post by SteveGilvarry »
API was released in 1.29.0
Ryuk
Re: API
Post by Ryuk »
SteveGilvarry wrote:API was released in 1.29.0
So, there is a way to upgrade my zoneminder without losing configurations etc.. or just to install apis?
Re: API
Check the WIKI. If you use Ubuntu there are upgrade instructions to get you to 1.29.0
Ryuk
Re: API
Post by Ryuk »
bbunge wrote:Check the WIKI. If you use Ubuntu there are upgrade instructions to get you to 1.29.0
Alright! I found a solution right here -->http://blog.waldrondigital.com/tag/zoneminder-upgrade/
Thanks for the tips.
Re: API
I would advise against using that as it is old.
Look here: https://wiki.zoneminder.com/Ubuntu
