Clean Install API Permission Issues
asker
Re: Clean Install API Permission Issues
Post by asker »
so the problem is resolved (, I hope). We don't know _exactly_ how or why, but it works now.
Please read before posting:
ES docs
zmNinja docs
elvisimprsntr
Post by elvisimprsntr »
asker wrote:so the problem is resolved (, I hope). We don't know _exactly_ how or why, but it works now.
Not sure what we did, but it is working now. Thanks again for the help.
While I have your attention. Did the streaming URL change from 1.28.2 and 1.29.0?
1.29.0 seems to have broken iOS app zmView and a home automation app I had the developer add ZM camera server support to his app.
Is so, where is the new URL documented?
UPDATE: I see it has based on the instructions. Need to add the /zm/
http://localhost/zm/cgi-bin/nph-zms?mode=single&monitor=1&scale=100&user=username&pass=password
asker
Post by asker »
Yes, it has changed
https://github.com/pliablepixels/zmNinj ... nitor-view
BTW, have you tried zmNinja?
ES docs
zmNinja docs
elvisimprsntr
asker wrote:Yes, it has changed
Thanks. I've already sent a message to the zmView developer and my home automation app developer.
I'll take a look at zmNinja
asker
Post by asker »
I know zmView folks updated their code to work with 1.29 - there was a post here a few weeks ago, so you may need to update zmView
ES docs
zmNinja docs
elvisimprsntr
asker wrote:I know zmView folks updated their code to work with 1.29 - there was a post here a few weeks ago, so you may need to update zmView
Latest zmView change log says updates for 1.28.109
asker
Post by asker »
oh correct, sorry, it was 1.28.109.
ES docs
zmNinja docs
ZM View does work with 1.29.0 in both iOS and Android versions.
elvisimprsntr
bbunge wrote:ZM View does work with 1.29.0 in both iOS and Android versions.
It is not working on my existing iOS installations. I am using the same user ID/PW in my new ZM installation.
I can connect to the server, but the montage and individual views do not work in zmVIew. This seems to imply that my zmView is still using the old streaming URL, which is not a user setting.
Do I need to delete my existing ZM server in zmView and re-add to force re-authentication or use the new URL?
elvisimprsntr
Confirmed zmView will not bring up camera views or montage view if a port is specified in the URL.
See post: viewtopic.php?f=33&t=23796#p92619
Submitted ticket: https://html5cloudscom.freshdesk.com/su ... ickets/804
