Glad that it is finally working for you. I found another bug with the snapshot burst. When I was working with iOS, the bug showed up, but never affected my android. I cleaned it up and it should be good to go.
I would love to be able to add PTZ features to the app, but I do not have a PTZ camera to test with. I just spent a few minutes looking at the source code of the classic skin, but the PTZ parts didn't jump out at me. I would probably need to take a look at the rendered html code to see exactly what zoneminder is doing so that I can mimic it.
ZoneMinder Client Mobile Application for Android
Re: ZoneMinder Client Mobile Application for Android
Well, if you can stomach the idea of learning how to set up & use a PPTP VPN, offer is still open!
(I even use PTZ presets, ooOOoooOOoo!)
Hi Kevin, I'm new to zoneminder and want to thank you for your android app. Keep up the good work! Thanks, Russ
I have to tell you guys, i LOVE ZMC better than the web interface. I'm having all kinds of issues with the Web Interface but after following your directions this ZMC works like a champ. ALL THE TIME.
WONDERFUL application.. really.. you should charge for it, because i'd pay.
I just tried the old android app and old custom skin in a new install using ubuntu 15.10 and zoneminder 1.29 and it works, surprisingly. Live streaming 13 mjpeg streams. Maybe someday I will find my old code and rebuild the app. And sorry for never releasing my ios version, ran out of time to get it polished enough for public consumption, and then lost interest.
