API Problems, fresh install trusty
prozach
Post by prozach »
Fresh install of v1.29.0 on ubuntu 14.04.1 LTS
I followed the easy install instructions for trusty.
All of my cameras are working, auth works.
API page is throwing weird results:
I have tried following the instructions, but then I get the following:
I am still searching for what the DB should have in it...
asker
Re: API Problems, fresh install trusty
Post by asker »
There is no such class called ApiController - its not in the ZoneMinder code on github either.
Do this - go to /usr/share/zoneminder
then do
find . | xargs fgrep ApiController 2>/dev/null
tell me what you see
Please read before posting:
ES docs
zmNinja docs
prozach
Post by prozach »
And I should say fresh install of zoneminder.
root@mineserver:/usr/share/zoneminder# find . | xargs fgrep ApiController 2>/dev/null
./www/api/app/Controller/ApiController.php:class ApiController extends AppController {
So its there, but only because I added it like the error message said.
With the file there I get missing database table errors, if I delete the file, of course nothing is found and I go back to having the missing controller error. I suspect this is a problem with cakephp and not with zoneminder exactly.
I am following the instructions here: http://zoneminder.readthedocs.org/en/la ... buntu-14-x
everything else seems to work just fine.
asker
Post by asker »
which PHP version?
ES docs
zmNinja docs
prozach
Post by prozach »
5.5.9+dfsg-lub
asker
Post by asker »
So please don't add it - the error is ambiguous. The real reason is likely a misrouting
Please revert to original state, then please post a screenshot (including the URL you are going to) of the api page
There may also be an issue with your .htaccess files -and a misrouting. For example on my correctly configured system, instead of http://server/zm/api if I go to http://server/zm/api/api the same error for missing API controller shows. This can also happen if your htaccess routing is messed up
ES docs
zmNinja docs
prozach
Post by prozach »
The first screenshot is what I get from a vanilla install of zoneminder.
as a troubleshooting step I added file at one point and got the second screenshot.
I have since then removed it and I am back to the original screenshot.
I am hosting zoneminder on a secondary system and I have my webserver proxying requests from the cname I built for zoneminder.
You mentioned /api/api/ and I saw that at onepoint but can't remember the scenario.
and now looking at the configs, I think I know where the issue is.
if I goto localhost/zm/api everything is happy.
So now I just need to figure out the confilct between the alias and my virtualhosting documentroot.
asker
Post by asker »
if I goto panopticon.zachula.com/zm/api everything is happy.
sounds good.
ES docs
zmNinja docs
prozach
Post by prozach »
Thanks for the help!
These instructions may be more up to date:
If you are having issues with the API you may need to:
