Hello everyone, I was giving this old POWERDVR 200 unit the other day for free. I figured oh this might work with Zoneminder.
It has conexant fusion 878a chips on it. The card says 3R inc rev 1.35 and that is it boys and girls !
There are two cards. I take it one is a video coder or something? It has TechWell TW9903 on it. From what I found online.
So I attached some pictures of the cards.
Can I get this to work, or should I just give this thing away !
Thank You !!!!!!
https://drive.google.com/file/d/1BLF8Wg ... sp=sharing
https://drive.google.com/file/d/1pxnZ4O ... sp=sharing
https://drive.google.com/file/d/1GVw3gx ... sp=sharing
Hardware that I got for FREE !
Re: Hardware that I got for FREE !
I have the same card but the pci bridge is by PLX instead of HINT. Currently trying to get it to work with ZM1.29 on Ubuntu 16.04. Inputs are detected correctly but no signal. It might be working already but ATI video card doesnt have full acceleration, so overlay doesnt work. My powerdvr200 came with a much smaller overlay/output card with no encoder though. Just a single BT878A, and a 2 pin cable connected to J2 on the main card.
Any luck so far? Due to the input switch chip i assume the settings for a KCM4400r might work but cant confirm.
my relevent dmesg output:
options bttv card=133,132,133,133 tuner=4,4,4,4
[ 14.340299] bttv: driver version 0.9.19 loaded
[ 14.340305] bttv: using 32 buffers with 2080k (520 pages) each for capture
[ 14.342489] bttv: Bt8xx card found (0)
[ 14.342522] bttv: 0: Bt878 (rev 17) at 0000:05:00.0, irq: 20, latency: 32, mmio: 0xe7200000
[ 14.342539] bttv: 0: subsystem: 344a:1101 (UNKNOWN)
[ 14.342542] bttv: 0: using: IVC-200 [card=102,insmod option]
[ 14.366454] bttv: bttv0: i2c scan: found device @ 0x1c [lgdt330x]
[ 14.366474] bttv: bttv0: i2c scan: found device @ 0x30 [IR (hauppauge)]
[ 14.366554] bttv: bttv0: i2c scan: found device @ 0x80 [msp34xx]
[ 14.366560] bttv: bttv0: i2c scan: found device @ 0x86 [tda9887]
[ 14.366585] bttv: bttv0: i2c scan: found device @ 0xa0 [eeprom]
[ 14.366617] bttv: bttv0: i2c scan: found device @ 0xc0 [tuner (analog)]
[ 14.366619] bttv: bttv0: i2c scan: found device @ 0xc2 [tuner (analog)]
[ 14.366681] bttv: 0: tuner absent
[ 14.366735] bttv: 0: Setting PLL: 28636363 => 35468950 (needs up to 100ms)
[ 14.396021] bttv: PLL set ok
[ 14.396173] bttv: 0: registered device video0
[ 14.396248] bttv: 0: registered device vbi0
[ 14.396503] bttv: Bt8xx card found (1)
[ 14.396529] bttv: 1: Bt878 (rev 17) at 0000:05:04.0, irq: 20, latency: 32, mmio: 0xe7202000
[ 14.396550] bttv: 1: subsystem: 344b:1101 (UNKNOWN)
[ 14.396553] bttv: 1: using: IVC-200 [card=102,insmod option]
[ 14.396773] bttv: bttv1: i2c scan: found device @ 0x1c [lgdt330x]
[ 14.396806] bttv: bttv1: i2c scan: found device @ 0x30 [IR (hauppauge)]
[ 14.396886] bttv: bttv1: i2c scan: found device @ 0x80 [msp34xx]
[ 14.396892] bttv: bttv1: i2c scan: found device @ 0x86 [tda9887]
[ 14.396919] bttv: bttv1: i2c scan: found device @ 0xa0 [eeprom]
[ 14.396951] bttv: bttv1: i2c scan: found device @ 0xc0 [tuner (analog)]
[ 14.396953] bttv: bttv1: i2c scan: found device @ 0xc2 [tuner (analog)]
[ 14.397016] bttv: 1: tuner absent
[ 14.397063] bttv: 1: Setting PLL: 28636363 => 35468950 (needs up to 100ms)
[ 14.428022] bttv: PLL set ok
[ 14.428161] bttv: 1: registered device video1
[ 14.428241] bttv: 1: registered device vbi1
[ 14.428500] bttv: Bt8xx card found (2)
[ 14.428528] bttv: 2: Bt878 (rev 17) at 0000:05:08.0, irq: 20, latency: 32, mmio: 0xe7204000
[ 14.428547] bttv: 2: subsystem: 344c:1101 (UNKNOWN)
[ 14.428550] bttv: 2: using: IVC-200 [card=102,insmod option]
[ 14.428767] bttv: bttv2: i2c scan: found device @ 0x1c [lgdt330x]
[ 14.428787] bttv: bttv2: i2c scan: found device @ 0x30 [IR (hauppauge)]
[ 14.428867] bttv: bttv2: i2c scan: found device @ 0x80 [msp34xx]
[ 14.428873] bttv: bttv2: i2c scan: found device @ 0x86 [tda9887]
[ 14.428900] bttv: bttv2: i2c scan: found device @ 0xa0 [eeprom]
[ 14.428932] bttv: bttv2: i2c scan: found device @ 0xc0 [tuner (analog)]
[ 14.428934] bttv: bttv2: i2c scan: found device @ 0xc2 [tuner (analog)]
[ 14.428998] bttv: 2: tuner absent
[ 14.429045] bttv: 2: Setting PLL: 28636363 => 35468950 (needs up to 100ms)
[ 14.460022] bttv: PLL set ok
[ 14.460141] bttv: 2: registered device video2
[ 14.460223] bttv: 2: registered device vbi2
[ 14.460456] bttv: Bt8xx card found (3)
[ 14.460479] bttv: 3: Bt878 (rev 17) at 0000:05:0c.0, irq: 20, latency: 32, mmio: 0xe7206000
[ 14.460496] bttv: 3: subsystem: 344d:1101 (UNKNOWN)
[ 14.460499] bttv: 3: using: IVC-200 [card=102,insmod option]
[ 14.460707] bttv: bttv3: i2c scan: found device @ 0x1c [lgdt330x]
[ 14.460727] bttv: bttv3: i2c scan: found device @ 0x30 [IR (hauppauge)]
[ 14.460808] bttv: bttv3: i2c scan: found device @ 0x80 [msp34xx]
[ 14.460814] bttv: bttv3: i2c scan: found device @ 0x86 [tda9887]
[ 14.460841] bttv: bttv3: i2c scan: found device @ 0xa0 [eeprom]
[ 14.460873] bttv: bttv3: i2c scan: found device @ 0xc0 [tuner (analog)]
[ 14.460875] bttv: bttv3: i2c scan: found device @ 0xc2 [tuner (analog)]
[ 14.460937] bttv: 3: tuner absent
[ 14.460984] bttv: 3: Setting PLL: 28636363 => 35468950 (needs up to 100ms)
[ 14.492018] bttv: PLL set ok
[ 14.492145] bttv: 3: registered device video3
[ 14.492228] bttv: 3: registered device vbi3
Not yet, I had some bad captors on the motherboard that I had to repair.
Another discovery:
By default, recent versions of ZM do not come with V4L1 built in or enabled. This must be done manually. KCM-4400 and many similar cards do not work with V4L2. This probably is why xawtv did not work in overlay mode for me.
I have mapped out the GPIO pins on the 3R card, but DO NOT mess with them unless you know exactly what you are doing. Incorrectly reading/writing GPIO pins can permanently damage hardware.
bt878a-3 gpio0 r-330k control p1
bt878a-3 gpio1 r-330k control p3
bt878a-3 gpio2 r-330k control p5
bt878a-3 gpio3 r-330k control p7
bt878a-3 gpio4 r-330k control p9
bt878a-3 gpio5 r-330k control p11
bt878a-3 gpio6 r-330k control p13
bt878a-3 gpio7 r-330k control p15
bt878a-3 gpio16 r-330k control p17
bt878a-3 gpio17 r-330k control p19
bt878a-3 gpio18 r-330k control p21
bt878a-3 gpio19 r-330k control p23
bt878a-3 gpio20 r-330k control p25
bt878a-3 gpio21 r-330k control p27
bt878a-3 gpio22 r-330k control p29
bt878a-3 gpio23 r-330k control p31
bt878a-4 gpio0 r-330k sensor p1
bt878a-4 gpio1 r-330k sensor p3
bt878a-4 gpio2 r-330k sensor p5
bt878a-4 gpio3 r-330k sensor p7
bt878a-4 gpio4 r-330k sensor p9
bt878a-4 gpio5 r-330k sensor p11
bt878a-4 gpio6 r-330k sensor p13
bt878a-4 gpio7 r-330k sensor p15
bt878a-4 gpio16 r-330k sensor p17
bt878a-4 gpio17 r-330k sensor p19
bt878a-4 gpio18 r-330k sensor p21
bt878a-4 gpio19 r-330k sensor p23
bt878a-4 gpio20 r-330k sensor p25
bt878a-4 gpio21 r-330k sensor p27
bt878a-4 gpio22 r-330k sensor p29
bt878a-4 gpio23 r-330k sensor p31
Any luck? I went back to the vendor software on windows for a while but i cant get it to detect the card. Seems like zoneminder is the only way now. What are the pci vendor id and device id on your card? mine has the default ids for the hardware but the vendor drivers seems to expect 1234:1600.
Update: According to the vendor, the card 'should' be seen in windows as a single device with pci id 0123:1600. If you see that pci id in linux, the card will not work. putting it in another 'wrong' pci slot should expose the bt878a chips. Also, if the card is detected correctly but you get no input signal, there is a workaround I will try with mine and post here how it goes. Removing the matrix switch chip and manually wiring the inputs and outputs should help as its likely that it is waiting for some configuration command from the vendor software. I will try it on mine first though.
